Hey they came in stock. They didn’t send me a notification email but I just bought two with the code Thanks!! Pretty much 2 for one!! I used your email link like you said to do
Hey mate, did the Nichia version came back in stock too then got sold out again or just the XPG versions get back in stock?
Got the XPG3 version anyways. Will get the Nichia when it gets back in stock
The Nichia version says it should be in June 11th…I got the xpg 3 … I was trying to see the difference between the 3 as I’m new to all the led names… maybe you can explain the differences… thanks
Both the XPG2 and XPG3 are made by Cree. 3 being the newer version than 2. The XPG’s in this light are around 6500k/Cool White (the colour temperature of the LED) .
219C is made by Nichia and the colour temperature is 5000k/Neutral White. Usually the warmer the colour the better CRI (Colour Rendering Index). Objects look how they are supposed to look.
Cooler colour temp LED usually produce more lumens but people on here pick CRI over an extra few lumens. Guess that’s why the Nichia version are always sold out before the cool white lights.
Thanks I’m trying to learn these led’s … I know about the colors they produce by the k number … I would of wanted the neutral white as well… but I’m ok with the cool white I ordered too…I realized the 18650 tube doesn’t come with it and I have to wait for it to come back in stock… I’m sure this has really really low run time on turbo with the 16340s …
If I remember correctly. The S41 on a 18350 runs 8 mins on turbo lol
So this light would be somewhere similar
I had the extension tube in my cart two days ago. Went to add some other stuff to the cart. Went to pay and it was out of stock again. Annoyed at myself I wasn’t faster. Next time is comes back in stock. Buying it straight away lol
Oh damn you have to buy quicker lol I just seen a post a couple days on a16340 with 1300mah … I want to find a way to buy them … that will defiantly help the run time on my on the road m3 and this light if I decide to use that configuration … Test/review of Aspire INR18350 1300mAh (Black-yellow)
Astrolux S41 S1 luz LED accesorios de iluminación de la lámpara de la Linterna de la antorcha 18650 Tubo Del Cuerpo cuerpo de la linterna http://s.aliexpress.com/aEzayQzE
(from AliExpress Android)
FWIW, more mAh does not necessarily mean more runtime on turbo, in high-powered lights like this. Batteries tend to come in either high-mAh or high-current varieties, and the high-current ones tend to perform better (and longer) on high modes even though their mAh rating is lower.
However, the high-mAh batteries (if they’re legit) should have more runtime at lower modes.
Effective capacity changes with the amount of current being pulled. This effect is smaller on the high-current cells though, and can give a high-current cell more effective capacity (relatively) if the current is high enough.
If a battery’s specs are unusually high, there is a good chance it’s fake. Normally if I saw “16340 with 1300mAh” I would expect it to be fake, since those don’t really exist yet. HKJ’s measurements suggest that one is only exaggerating a little though, making it the first 18350 with ~1200 mAh.
That’s interesting, I’m somewhat new to detailed info on lights …I just thought mah would mean the more power it can store, so no matter if running turbo or low mode it would run longer then a battery with lower mah… I need to look into this it’s interesting thanks for the info … but sorry for getting off topic of the s42…
It depends, and the only way to get good numbers is to measure… but, fortunately, HKJ measured.
On that particular cell, it looks like ~1170 mAh on low modes, ~1100 mAh on medium modes, and about ~1000 mAh on high/turbo. Which really isn’t bad at all.
On 18650 lights, it’s common for a 3000 mAh high-amp cell to last longer than a 3500 mAh high-capacity cell on turbo. The cells optimized for capacity tend to have much more voltage sag under load, and also much more capacity reduction under load, which makes them dimmer with output dropping faster… while the high-amp ones stay closer to their rated voltage and capacity.
Sometimes voltage sag can be a good thing though, like when direct-driving a Nichia 219c from an 18650 cell. A high-amp cell can fry the emitter, while an older saggier cell is safe to use. But this is kind of an unusual case.
