< Am I seeing things or is TK wearing glasses?
Button tops are typically spot welded (I believe), and the metal - not sure how good the conductivity, so totally up to the mysterious 3rd party that installs the button tops. Solder, though supposed not great conductivity, is solid to the battery top. I would think/guess solder boobs will always do better, and my testing seems to prove that out compared to the button tops I have, and tested.
For durability, reliability, button tops win out every time - solder is soft, subject to going flat over time (not drooping), plus the metal could be rubbing off on the brass contact ring over time - bad if it fragments, but not sure bout that. I think I've seen this occurring though - probably best if the brass ring is polished smooth.
To fix this, could solder brass buttons to the top of the batteries. I've done this several times as well. I haven't had one fail yet, but never used them in an SRK style light (contact ring). I'd be concerned about the quality of the solder bond, if the brass button is at risk of falling off over time. Probably dependent on how well the solder job is done - clean surfaced, good amt of flux, etc. If you do use brass buttons, I'd say the contact surface should be sanded down on the edges so there's smooth contact - most of these buttons come with sharp edges. Brass will hold up better than solder for sure, but brass is relatively soft compared to steel for example, but it would be brass to brass contact so maybe that's good.
I dunno if all these concerns are warranted - I got limited long term experience with these usages.
I refer you to kramer5150’s avatar from July 2015:
So… you’re saying the softness of boobs might make them lose their zing after menOhmpause?
Let’s not even start on the puns related to electrical conductivity being measured in siemens.
In practical terms though, solder blobs are relatively easy to rejuvenate when necessary. Just re-melt it, maybe add a little solder, or file down the tip a bit (ouch), and it should be good as new. I’ve had to do this occasionally on blobbed drivers when the contact surface gets dirty. It may also be a good idea to clean the contact ring on a SRK-style light once in a while.
This kind of thing isn’t limited to just solder though. I also have to clean the battery (steel? zinc? nickel?) and contact post (aluminum) on L3 L10 lights periodically, since it gets thoroughly blackened during use.
I’m glad the Q8 has a thick contact ring, since it’s going to get worn over time regardless of what the battery tops are made of. With a thin ring like a regular PCB copper pour, wear is visible after just one use… but this thick brass ring will likely last pretty much forever.
I would not know, i rarely get to know one from the other sex good enough for me to ask for permission to examine her features that close.
And i am not the kind that jump at every little chance he get, that actually make me suspicious and work like a bucket of ice-water on me.
On a more serious note, would it be possible to make a contact ring with raised areas in the right places so flat tops would work in it too ?
Or am i overthinking again.
I think, flats tops will work with it now as is… sparkyDK.
EDIT: If they are of proper length. :+1:
FINAL EDIT: … Sanyo GA flat tops will work because they are raised flattops.
Q 30 flat tops or any cell with flat tops like them… WILL NOT work.
My apologies for the initial incorrect informatio I gave. :person_facepalming:
I’ve been watching this on and off since the beginning and it looks like it’s finally coming together into a really impressive light, well done and thanks to everyone involved in the design. Please put me down for one.
Do we have any rough timeframe on shipping the final version yet? Once approved are they ready to start manufacturing?
Sheriously, typical flat tops won't work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA's are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
Or, if you simply use protected cells with the button already attached. As I recollect, somewhere above, it was determined that protected GAs with a good protection circuit did not seem to impact the light output vs an unprotected QA. Unless you are trying to squeeze every last lumen out of the light. But if this a concern, there are other batteries with higher amp capabilities you can blob and people can mod the light to try to make the whole power train act like a room temperature superconductor.
yeah i figured it would take some figuring out where the drum stop to make sure the batteries land on a “hill” on the contact ring.
But with design ( not the Q8 ) then i am sure they could figure it out and so the resulting flashlight could use any battery.
I am fully aware this are a done deal for the Q8 and that’s just fine i will just do something to the flat tops i have gotten for it.
But in future flashlights ( not least multi cell like the Q8 ) it would be nice if they would work with any type of the particular cells its build for.
But i have been wondering even if the “hills” was smooth for the battery’s to climb easy, the design of flattops and their wrapping might suffer damage over time as the batteries would have to go up and over those “hills” several times before they land in the final resting place.
Also i have been thinking if you should lathe those hills in the contact ring, or you could make do with just punching dents into the ring.
Now i am thinking ( i know i should be sleeping now but my brain will just not allow for that it seem )
How about if the 4 batteries in a light like the Q8 was staggered in a drum around a central pillar onto which you then screw on the end cap ?
This way the batteries should be stationary when the flashlight are put together, a bonus might be you can use bigger O-rings where the battery “drum” seal onto the LED end and the tail cap end, making for a bigger chance of a waterproof light and using larger more forgiving O-rings.
Off course this design will mean that the battery drum will just be held on the LED end with the friction of the O-ring when the end cap are unscrewed for battery change.
Holy sh, ee now i better stop cuz now i have tail cap contact ideas too, i better go for a drive and get me some sugar water to get the creative juices going again.
sparkyDK, this is an already-solved issue which came up just a few pages ago. It simply requires a different design:
A few people at BLF have done it. The trick is to lock the battery tube in place and unscrew only the very tail end of the light, with posts built in to keep the rotation correct. For example: [image]
The Q8 will not use this method though; it uses a SRK style ring instead. So… make sure the positive terminal is higher than the cell wrapper.
PLEASE CHECK IF YOU ARE ON THE LIST OK
The Q8 list (from post #1) sorted alphabetically .
(As of post #8341)
2 DOGS | 186 | |||||||||
264 | 641 | |||||||||
2Ace | 165 | 1119 | ||||||||
5ar | 697 | |||||||||
7pot | 982 | |||||||||
a12luke | 932 | |||||||||
a_idiot | 740 | |||||||||
Aardvark Spleen | 253 | 402 | 403 | |||||||
Abe87 | 876 | |||||||||
Abqjohnny | 51 | 1169 | ||||||||
abril | 50 | |||||||||
adirondackdestroyer | 545 | |||||||||
adrianlights | 255 | |||||||||
AEDe | 923 | |||||||||
Ag76 | 1345 | |||||||||
aggillator | 458 | |||||||||
aginthelaw | 278 | |||||||||
Agiri | 110 | |||||||||
aim120 | 430 | |||||||||
AirBreaker | 155 | |||||||||
akhyar | 387 | |||||||||
akoposilester | 56 | 1111 | 1112 | |||||||
akovia | 937 | |||||||||
albertopnp | 365 | |||||||||
Alcius | 105 | |||||||||
alejandrov | 523 | |||||||||
alex64 | 1159 | |||||||||
AlexGT | 495 | |||||||||
Alkpwn77 | 204 | |||||||||
allthumbs | 218 | |||||||||
alphazeta | 335 | |||||||||
alternety | 564 | 565 | ||||||||
Alux | 702 | |||||||||
amplificus | 904 | 983 | 984 | |||||||
Andmiller | 1064 | 1065 | ||||||||
andrewmac | 407 | |||||||||
Andybibbville | 147 | |||||||||
Andyman? | 13 | |||||||||
Angel Martínez | 128 | |||||||||
ant0 | 1195 | |||||||||
Antenne | 801 | |||||||||
Anthon | 568 | |||||||||
antiparanoico | 32 | |||||||||
AppA | 1208 | |||||||||
aprendiz | 1160 | 1261 | ||||||||
apt323 | 47 | 544 | ||||||||
archi | 1157 | |||||||||
archimedes | 67 | |||||||||
aremihc | 910 | |||||||||
ARMS.AARON | 1089 | |||||||||
ARsee | 1228 | 1229 | ||||||||
Arufonsi | 921 | |||||||||
aslpg | 398 | |||||||||
asnidi2 | 1327 | |||||||||
asot | 690 | |||||||||
Astromanic | 424 | |||||||||
AsylumSweep | 863 | |||||||||
atbglenn | 567 | |||||||||
Atom00 | 358 | 359 | ||||||||
Autoclave | 1099 | |||||||||
Awdtsi | 1221 | |||||||||
Awkward Stretch | 619 | |||||||||
AwkwardPause | 464 | |||||||||
b1i1l1l1y1 | 1052 | |||||||||
B42 | 685 | 686 | 1019 | 1020 | ||||||
BackpackNY | 571 | 1084 | ||||||||
bakalakos | 202 | |||||||||
balazs1956 | 1341 | |||||||||
baldo21 | 260 | 261 | ||||||||
Bam35 | 1039 | |||||||||
bamawthu | 599 | |||||||||
banker | 1013 | |||||||||
basslovin808 | 446 | |||||||||
Bastarrdo | 117 | |||||||||
Batch1 | 293 | 344 | ||||||||
battletross | 809 | |||||||||
bawilson2 | 500 | 501 | ||||||||
Bc412 | 5 | |||||||||
bd52 | 399 | |||||||||
BDM | 1018 | |||||||||
BDWrabbit | 1244 | |||||||||
BeardedRaleigh | 662 | |||||||||
bella-headlight | 49 | 411 | 877 | |||||||
Bernard | 232 | |||||||||
Bevo | 1086 | |||||||||
bhuge00 | 1049 | |||||||||
bigpix | 84 | |||||||||
bigrick | 754 | |||||||||
bikedave99 | 1174 | |||||||||
bikenber73 | 14 | |||||||||
Bill 63 | 752 | 1296 | ||||||||
Bill_tong | 896 | |||||||||
Billcheese5 | 949 | |||||||||
bionictony | 1338 | |||||||||
bkling | 1067 | |||||||||
BlackList | 1350 | |||||||||
bladesmith3 | 607 | |||||||||
BLFD80 | 933 | |||||||||
BlindingL5s | 312 | |||||||||
blinker | 1306 | 1353 | ||||||||
blinky | 1209 | |||||||||
blueb8llz | 70 | 553 | 1120 | 1121 | 1122 | 1123 | ||||
Bluzie | 785 | |||||||||
bmaddison | 248 | |||||||||
Boaz | 391 | |||||||||
BobbyMK | 462 | |||||||||
bobdotorg | 1271 | 1272 | ||||||||
bobofire | 1313 | |||||||||
Bogdan | 370 | 371 | ||||||||
bogdanr | 466 | |||||||||
Bohemian | 775 | |||||||||
bonfire | 412 | |||||||||
Bong lick | 763 | 1075 | ||||||||
Bonham | 262 | |||||||||
borealis | 1098 | |||||||||
BorisBar | 575 | 1238 | ||||||||
Boro | 360 | 361 | ||||||||
bossf350 | 803 | |||||||||
Box | 671 | |||||||||
Brettg4215 | 864 | |||||||||
Brian Metcalfe | 318 | 319 | 374 | |||||||
BrianK | 447 | 560 | 1356 | |||||||
BrianTheJay | 950 | |||||||||
brightlights | 243 | |||||||||
brjones | 504 | |||||||||
brno602 | 913 | |||||||||
brted | 249 | |||||||||
Bruno28 | 513 | |||||||||
BT100 | 1087 | 1138 | ||||||||
Bungle88 | 610 | |||||||||
Buzzy243 | 1179 | |||||||||
bwl123 | 870 | |||||||||
cabfrank | 443 | 988 | ||||||||
Caleb | 203 | 547 | ||||||||
Caleb-v | 444 | |||||||||
Calmaja | 35 | |||||||||
Cano | 661 | 1151 | ||||||||
Captainvideo | 1302 | |||||||||
caramba | 748 | |||||||||
carmantl | 345 | 346 | ||||||||
casi29061965 | 467 | 490 | ||||||||
cavorite | 1028 | |||||||||
Cawi | 1276 | |||||||||
cbrake10 | 749 | |||||||||
cclight | 897 | |||||||||
cdjaney | 825 | |||||||||
Chadvone | 63 | 693 | ||||||||
Charga | 124 | |||||||||
charles lin | 1124 | |||||||||
CheapThrills | 469 | |||||||||
cheesecheeks | 816 | |||||||||
ChibiM | 1310 | 1321 | ||||||||
Chicken Drumstick | 131 | |||||||||
chinooker | 1260 | |||||||||
chooma | 210 | 351 | ||||||||
chrisc | 741 | 742 | ||||||||
churchilllafemme | 1230 | |||||||||
CircaM | 894 | |||||||||
Cjlee89 | 951 | |||||||||
cjoe7 | 146 | |||||||||
CJW | 367 | |||||||||
clagged | 991 | |||||||||
clange50 | 479 | 480 | ||||||||
clinicdoc | 1226 | |||||||||
Cliwilnew | 795 | |||||||||
cloggy | 404 | |||||||||
cmflippen | 83 | |||||||||
cnrffl1 | 577 | 1113 | ||||||||
cocoschnauzer | 363 | |||||||||
contigo | 1351 | |||||||||
Coolerness | 664 | |||||||||
coolriku | 517 | |||||||||
Corzy | 308 | |||||||||
Couchmaster | 245 | 551 | 552 | |||||||
cpd800t | 406 | |||||||||
CrashOne | 372 | 377 | ||||||||
Crazyeddie | 98 | 137 | 487 | |||||||
Creepo | 909 | |||||||||
cristhemuso | 388 | |||||||||
crx88ia | 683 | |||||||||
cujo255 | 1191 | |||||||||
cwb | 134 | |||||||||
cypher1024 | 973 | |||||||||
cypherz | 250 | |||||||||
Cythras | 956 | |||||||||
D10ten | 608 | |||||||||
Dadpool | 1161 | |||||||||
dafarui | 1339 | |||||||||
daninho | 468 | |||||||||
DarkerInSol | 615 | 616 | 617 | 618 | ||||||
darkpenguin | 718 | 719 | 735 | 736 | 737 | 738 | 739 | 860 | 861 | 862 |
darol | 798 | |||||||||
darrenm | 1054 | 1055 | ||||||||
darrylo | 507 | |||||||||
DarthTader | 830 | |||||||||
datiLED | 761 | |||||||||
dave101 | 1041 | |||||||||
DavidEF? | 7 | |||||||||
davidkappelt | 1026 | |||||||||
davidvns | 1128 | |||||||||
davos | 1062 | |||||||||
DB Custom | 713 | 722 | 997 | |||||||
dbesselt | 1156 | |||||||||
DBSAR | 136 | 169 | 1281 | |||||||
DBSS | 516 | 779 | ||||||||
deathless | 518 | |||||||||
Deep skull | 977 | |||||||||
DeJaVu | 669 | |||||||||
dekozn | 800 | |||||||||
Dennis | 934 | |||||||||
dentillozie | 488 | |||||||||
Dep668 | 687 | 688 | ||||||||
derfyled | 1237 | |||||||||
derpilgerer | 630 | |||||||||
Desmo | 805 | |||||||||
devdvr | 486 | |||||||||
dezoe | 1186 | |||||||||
dhsvcs | 265 | 1336 | 1337 | |||||||
dicksog | 559 | |||||||||
digitaltc | 1323 | |||||||||
Dimking | 425 | |||||||||
Dirt | 815 | |||||||||
Dirty_Pierre | 1045 | |||||||||
DiscoJoe | 1254 | |||||||||
djburkes | 188 | 878 | ||||||||
Djozz | 3 | 1115 | 1286 | |||||||
dmbaty | 1294 | |||||||||
Dobtruckers | 1058 | |||||||||
DOCFAR | 595 | |||||||||
Docp723 | 347 | 433 | 434 | |||||||
Doctawho | 440 | |||||||||
dodo | 88 | 274 | ||||||||
dogany | 813 | |||||||||
Dogsrule | 508 | |||||||||
donpachi | 1252 | |||||||||
dotBLF | 968 | |||||||||
doubleone44 | 887 | |||||||||
downlinx | 74 | 316 | ||||||||
doxerino | 1304 | |||||||||
Dr Forinor | 873 | |||||||||
Dradge | 1248 | |||||||||
Dralf | 1015 | |||||||||
Dregs | 172 | |||||||||
DrHook59 | 883 | |||||||||
driveX | 659 | |||||||||
DrJones | 75 | |||||||||
DT101 | 152 | |||||||||
dudunphy | 389 | |||||||||
Duke | 381 | |||||||||
dumptruck | 971 | |||||||||
Dusty | 327 | 328 | ||||||||
Dutcheee | 68 | 322 | ||||||||
duvallite | 889 | |||||||||
dw911 | 478 | |||||||||
Dwantink | 135 | |||||||||
e10sno | 405 | 1318 | 1319 | |||||||
Easyrr | 6 | |||||||||
eb1888 | 837 | 838 | 839 | |||||||
ebosh | 777 | |||||||||
ediaz | 906 | |||||||||
eebowler | 774 | |||||||||
Eggun | 1104 | 1312 | ||||||||
egrep | 594 | |||||||||
Eivwer | 171 | |||||||||
electricjelly | 237 | 256 | ||||||||
ElginAgain | 1204 | |||||||||
emarkd | 109 | |||||||||
embee | 511 | |||||||||
Enelooper | 417 | |||||||||
engber | 947 | |||||||||
ERDOS | 1150 | |||||||||
Erethryn | 1259 | |||||||||
erikk365 | 648 | |||||||||
Esskay | 995 | |||||||||
Etex | 829 | |||||||||
euphxenos | 408 | |||||||||
everydaysurvivalgear | 103 | |||||||||
Evilc | 65 | |||||||||
EyeballFryer | 189 | |||||||||
Fadetoblack | 1295 | |||||||||
fantomR | 636 | |||||||||
Far Thrower | 148 | 197 | ||||||||
Farmboy24 | 1234 | |||||||||
Farns | 277 | |||||||||
Fatlight | 663 | |||||||||
fatsteve0 | 1361 | |||||||||
FBsLights | 790 | |||||||||
fcrespi | 1262 | |||||||||
fed893 | 307 | |||||||||
fedcas | 902 | |||||||||
feralcomprehension | 1194 | 1311 | ||||||||
finges | 561 | |||||||||
fireblade893 | 209 | |||||||||
firedome | 324 | 711 | ||||||||
Firelight2 | 397 | |||||||||
fishlite5 | 1046 | |||||||||
fixed it | 78 | 1097 | ||||||||
fixvid | 1264 | |||||||||
Flash Voyager | 652 | |||||||||
flashination | 87 | |||||||||
FlashMax | 1225 | |||||||||
Flashy Mike | 239 | 410 | 448 | 449 | ||||||
Flifish48 | 806 | 1096 | ||||||||
Flintrock | 629 | |||||||||
fluffman86 | 958 | |||||||||
FmC | 1182 | |||||||||
fonfan | 234 | 1023 | 1024 | |||||||
fonLED | 725 | |||||||||
Ford Prefect | 1068 | |||||||||
Foston Pete | 453 | 454 | 644 | |||||||
foton | 1030 | |||||||||
Fozzy-SP | 317 | |||||||||
Frank A. | 1172 | |||||||||
Frankie Baby | 342 | |||||||||
Franz | 788 | |||||||||
Freddy61069 | 282 | |||||||||
Fredylee | 223 | 1329 | ||||||||
FreeMagenta | 1050 | |||||||||
freeme | 514 | |||||||||
Fritz t. Cat | 484 | |||||||||
Funzel67 | 990 | |||||||||
fuzun | 1074 | |||||||||
fyesilova | 535 | |||||||||
g60 | 290 | |||||||||
g_sintornillos | 126 | |||||||||
gamezawy | 38 | 336 | ||||||||
gangstead | 53 | 922 | ||||||||
garrybunk | 254 | |||||||||
gboss | 832 | |||||||||
gds95 | 1199 | |||||||||
gedasd | 1309 | |||||||||
geepaw | 1038 | |||||||||
gehrmo | 289 | |||||||||
geo1952 | 455 | 457 | ||||||||
ger-slash | 416 | |||||||||
Gerrh | 531 | 1163 | 1164 | 1285 | ||||||
Gerrit | 106 | |||||||||
getbully | 609 | 1263 | ||||||||
Gilatabar | 638 | |||||||||
giorgoskok | 306 | 493 | 1092 | |||||||
GIR | 804 | 818 | ||||||||
gisewhcs | 384 | |||||||||
Gj | 580 | 581 | ||||||||
gleamer | 432 | |||||||||
GlinnDamar | 1342 | |||||||||
gnatx | 588 | 824 | ||||||||
goatfarmer | 770 | |||||||||
GoldenBatt | 383 | 589 | 590 | |||||||
gorb507 | 811 | 812 | ||||||||
goshdogit | 11 | 12 | 40 | 120 | 121 | 543 | 556 | 928 | ||
gpapa693 | 79 | |||||||||
gravelmonkey | 1027 | |||||||||
green_comet | 601 | |||||||||
GreenShrike | 190 | |||||||||
gregor | 215 | |||||||||
GTsuperheros | 179 | |||||||||
Gtt980 | 936 | |||||||||
guerrilla154 | 1316 | |||||||||
Guggga | 538 | |||||||||
GulfCoast | 880 | |||||||||
gungoat | 44 | |||||||||
Gunnerboy | 252 | 967 | ||||||||
Guns712 | 1300 | 1301 | ||||||||
h2o | 181 | 476 | ||||||||
Hairy_Steve | 340 | |||||||||
hank | 258 | |||||||||
Hardware | 1071 | 1200 | ||||||||
Hauwexis | 845 | 846 | 847 | 848 | ||||||
haxquiz | 226 | 927 | ||||||||
headburger | 592 | |||||||||
heatwaves | 994 | 1265 | ||||||||
hein11ag | 183 | |||||||||
Herb Tarlek | 931 | |||||||||
Hestbech | 994 | 995 | ||||||||
hexcode | 503 | 672 | ||||||||
Hezekiah | 286 | 759 | ||||||||
hideehoo | 859 | |||||||||
HighCaliber | 177 | 178 | ||||||||
hmihaylov | 502 | |||||||||
Hobo | 220 | |||||||||
hunter1 | 116 | 720 | 721 | |||||||
hurleyy | 993 | |||||||||
I_like_lamb | 915 | |||||||||
Ian2381 | 150 | |||||||||
igeigeige | 890 | |||||||||
IH8MYX | 546 | |||||||||
ii_pennies | 481 | |||||||||
ikaruz_500 | 989 | |||||||||
Illumenated | 426 | |||||||||
illusioned | 954 | |||||||||
Ilmatic | 1253 | 1332 | ||||||||
ilovejesuschrist | 294 | 295 | ||||||||
ImA4Wheelr | 19 | |||||||||
ISO | 705 | 734 | 929 | 930 | ||||||
iwandutchy | 1047 | |||||||||
J-Dub74 | 461 | |||||||||
J_R_J | 675 | |||||||||
jack-bkk | 356 | |||||||||
jacktheclipper | 1108 | |||||||||
Jailbrake | 1034 | 1090 | ||||||||
JakeDjanitor | 46 | |||||||||
Jalben | 187 | |||||||||
jama | 635 | |||||||||
Jambo | 912 | |||||||||
james y | 1043 | 1044 | ||||||||
javipiloto | 1154 | |||||||||
jaynick | 1048 | |||||||||
JayT | 62 | |||||||||
Jayzed | 1214 | |||||||||
jb1 | 224 | |||||||||
jdunlap27284 | 164 | |||||||||
jealous57 | 81 | |||||||||
Jensa41 | 731 | 732 | ||||||||
Jerommel | 637 | |||||||||
jerrod | 512 | |||||||||
jescereal | 228 | |||||||||
Jesjes | 153 | 154 | ||||||||
jfalk1 | 918 | |||||||||
jhalb | 297 | |||||||||
jhullin | 159 | 751 | ||||||||
jingleberry | 1022 | |||||||||
Jinx | 93 | |||||||||
jkbam | 550 | |||||||||
jmoots | 268 | |||||||||
jmpaul320 | 95 | 299 | ||||||||
jmwhite151 | 482 | 851 | 852 | 853 | ||||||
Joat | 184 | |||||||||
JockRobbins | 717 | |||||||||
Joe Darkness | 620 | |||||||||
joe1512 | 534 | |||||||||
joeangi | 756 | |||||||||
joechina | 633 | |||||||||
Joey Adams | 1021 | 1132 | ||||||||
John-Galt | 463 | |||||||||
Johnhywash1 | 966 | |||||||||
johnnydoe | 1227 | |||||||||
JohnnyMac | 496 | |||||||||
johnpc | 955 | |||||||||
johny723 | 1082 | |||||||||
Jonandreadolan | 1072 | |||||||||
JonnyC | 576 | |||||||||
JordanZHP | 1078 | 1196 | ||||||||
josephqool | 1061 | |||||||||
jpcuba | 684 | |||||||||
JPLight | 23 | 646 | ||||||||
JPM3 | 263 | 264 | ||||||||
JS721 | 216 | |||||||||
jsmn4vu | 793 | |||||||||
Jtm94 | 1035 | |||||||||
Juanesdan | 118 | |||||||||
juaquin | 219 | |||||||||
Juggeli | 745 | |||||||||
jurasik1 | 1231 | |||||||||
justanotherguy | 541 | 712 | 1080 | |||||||
Jvrthp321 | 691 | |||||||||
jycheang | 1009 | |||||||||
k-wong | 542 | 1005 | ||||||||
Kafar | 9 | |||||||||
kahvitahra | 796 | |||||||||
Kalchev | 400 | |||||||||
kali stupa | 1217 | |||||||||
Kalihi | 836 | |||||||||
KawiBoy1428 | 230 | |||||||||
kaybi | 1033 | |||||||||
Kazik | 1315 | |||||||||
kbro | 168 | |||||||||
keengeorge | 309 | 310 | ||||||||
KeepingItLight | 992 | |||||||||
Keepitsharp | 175 | |||||||||
Keisari | 1211 | 1212 | ||||||||
keithd | 753 | |||||||||
KenE | 355 | |||||||||
Kenjii | 385 | |||||||||
Kentuckywindage | 797 | 872 | ||||||||
Kepling | 333 | |||||||||
KFulton | 1331 | |||||||||
khas | 628 | |||||||||
Khuan | 1148 | |||||||||
KIKY | 1340 | |||||||||
Killforfood | 272 | 379 | ||||||||
Kindle | 698 | |||||||||
KingSmono | 578 | |||||||||
kiriba-ru | 525 | |||||||||
Kiukas | 640 | |||||||||
KiwiKane | 174 | |||||||||
Kkelleher | 99 | 100 | 101 | 102 | ||||||
Kloepper Knife Works | 194 | 195 | 196 | |||||||
knightstalker | 1219 | |||||||||
kntx | 1073 | 1116 | 1189 | |||||||
knudsengj | 1106 | |||||||||
Koaksijalac | 104 | |||||||||
Kodachrome40 | 170 | 1282 | ||||||||
KoekieMonster | 161 | |||||||||
kommessy | 108 | |||||||||
korpzgrinda | 1029 | 1133 | ||||||||
kotobuki | 799 | 1143 | 1144 | |||||||
koyotee | 276 | |||||||||
Kozy | 58 | 129 | ||||||||
krutone | 1298 | |||||||||
Kulumatic | 914 | |||||||||
Kurt_Norway | 593 | |||||||||
Kusie | 8 | 17 | ||||||||
KutKhemist | 123 | |||||||||
Kysumi | 925 | |||||||||
LAB | 259 | |||||||||
lachesis | 673 | |||||||||
lalomt | 1167 | |||||||||
Lamont56 | 808 | |||||||||
lamper | 727 | 1171 | ||||||||
lanceb1b | 884 | |||||||||
laststance | 972 | |||||||||
lawallac | 393 | 394 | ||||||||
Lazy-R-us | 25 | 900 | 1249 | 1250 | ||||||
Le_Zouave | 71 | |||||||||
leaftye | 694 | 1103 | 1183 | 1184 | ||||||
LEDtec | 823 | |||||||||
legan710 | 1088 | |||||||||
Legolas Jr. | 130 | |||||||||
leroycp | 236 | 266 | 450 | 451 | ||||||
Lexel | 696 | 1287 | ||||||||
Lfatman | 707 | |||||||||
Liber8 | 537 | |||||||||
lichtpfadfinder | 1292 | |||||||||
Light of Earendil | 700 | |||||||||
lightbulb | 281 | |||||||||
lightknot | 471 | 492 | 598 | |||||||
lightlight22 | 772 | 920 | 1040 | 1328 | ||||||
lightmog | 72 | |||||||||
lightx | 757 | |||||||||
Lilien | 978 | |||||||||
Lion42 | 246 | |||||||||
lionheart_2281 | 33 | |||||||||
litcrit | 871 | |||||||||
Litefighter | 1320 | 1334 | 1335 | |||||||
LloydV | 767 | |||||||||
Loneman | 510 | 903 | ||||||||
longmire | 1256 | |||||||||
Lopan | 1069 | |||||||||
lovetheguitar | 981 | |||||||||
Lowtech | 1042 | 1193 | ||||||||
ludolf | 348 | |||||||||
luisgcan | 1162 | |||||||||
Lumenmaster17 | 1145 | 1146 | 1147 | |||||||
Lumens Industry | 634 | |||||||||
lumiere | 231 | |||||||||
Lund1660 | 64 | 439 | ||||||||
luxlad | 831 | |||||||||
lyse99 | 1012 | |||||||||
Lyubo Yanev | 427 | 428 | 429 | 536 | ||||||
M4D M4X | 350 | |||||||||
M78 | 157 | 337 | 1007 | |||||||
MACS0647 | 313 | |||||||||
MAD TM26 | 656 | 657 | ||||||||
Magbrite | 584 | |||||||||
magnet | 302 | |||||||||
MagPap | 794 | |||||||||
Maiden666 | 92 | |||||||||
maildroid | 331 | |||||||||
Majoroverkill | 919 | |||||||||
malamask | 113 | |||||||||
mandala | 952 | 953 | ||||||||
manithree | 1255 | |||||||||
Manulous | 1270 | |||||||||
ManWithoutShadow | 1100 | 1299 | ||||||||
Mapache | 4 | |||||||||
markalike | 602 | |||||||||
Marothar | 1236 | |||||||||
marsalla | 475 | |||||||||
Martini | 82 | 726 | ||||||||
martook | 48 | |||||||||
martytown | 976 | |||||||||
Masejoer | 842 | |||||||||
Matchoo | 905 | |||||||||
matkovicha | 1185 | |||||||||
Matomoto | 1324 | |||||||||
mattlward | 16 | 34 | 214 | |||||||
MauiSon | 42 | 979 | ||||||||
maukka | 225 | 627 | ||||||||
Maxxsounds | 681 | |||||||||
MBuitendorp | 1210 | |||||||||
mcfarlie6996 | 964 | 965 | ||||||||
MCT | 162 | |||||||||
Mecallie | 1051 | |||||||||
MechEngVictor | 275 | |||||||||
Medvegy | 660 | |||||||||
Melven | 167 | |||||||||
meti | 470 | |||||||||
metz3006 | 843 | |||||||||
Meyer | 138 | |||||||||
MG | 353 | |||||||||
mhanlen | 77 | |||||||||
mi bill | 127 | |||||||||
Micael | 858 | |||||||||
Miguel_79 | 1114 | 1129 | ||||||||
Miguelintegral | 1175 | |||||||||
mikeyx | 622 | |||||||||
Mindaugass | 769 | 1081 | ||||||||
Minimoke | 30 | 975 | ||||||||
miswas | 760 | |||||||||
Mitko | 26 | 27 | ||||||||
mitrhandir | 1303 | |||||||||
mizjif | 714 | |||||||||
Mkduffer | 600 | |||||||||
mlodyulek | 1283 | |||||||||
moemin | 375 | |||||||||
MontyPyfon | 66 | |||||||||
moridin | 907 | |||||||||
Morpheus | 613 | |||||||||
MorpheusT1 | 762 | |||||||||
MortyDuck | 764 | |||||||||
MountainKing | 438 | 445 | ||||||||
MountainMan | 786 | 787 | ||||||||
mozart.f | 314 | |||||||||
Mr.Poppy | 192 | 267 | 1247 | 1308 | ||||||
Mr.Scott | 251 | 1077 | ||||||||
mrheosuper | 1110 | |||||||||
mrkelvin | 606 | |||||||||
MRsDNF | 325 | 326 | ||||||||
mrstealyourgains | 1014 | |||||||||
msg1285 | 173 | |||||||||
Mstevens113 | 114 | |||||||||
Mt.B | 392 | |||||||||
MtnDon | 158 | 498 | ||||||||
mud_muncher | 624 | |||||||||
mudguts | 680 | 716 | ||||||||
Muto | 20 | 242 | 689 | |||||||
mutts13 | 1343 | 1348 | ||||||||
muzzleblast? | 89 | |||||||||
mxlu | 396 | |||||||||
MyDangus | 1181 | |||||||||
myowin | 213 | 1235 | ||||||||
myst999 | 198 | 728 | 1266 | 1267 | ||||||
nanojack | 1036 | |||||||||
narin000 | 524 | |||||||||
Nathan42 | 946 | 987 | 1365 | |||||||
Navin_R_Johnson | 817 | |||||||||
neckbear | 935 | |||||||||
needmorlts | 911 | |||||||||
Neilyboy | 1307 | |||||||||
netprince | 176 | 378 | ||||||||
nexrace1 | 579 | |||||||||
nfetterly | 362 | 366 | ||||||||
Nguyen | 1277 | 1293 | ||||||||
nickdude | 591 | |||||||||
Nickke | 604 | |||||||||
Nicolaas | 857 | |||||||||
Nicolicous | 270 | |||||||||
Night Light | 1093 | |||||||||
NightLight | 369 | |||||||||
Nightshade | 574 | |||||||||
niktak11 | 782 | |||||||||
Nil | 959 | 960 | ||||||||
Nite Shadow | 1001 | |||||||||
Nitetime | 163 | |||||||||
nitrader0 | 1203 | |||||||||
nnmnu1 | 1349 | |||||||||
No Agenda | 431 | |||||||||
nofear87 | 382 | |||||||||
Noki | 573 | |||||||||
noob | 828 | 833 | 1025 | |||||||
Nord | 1170 | |||||||||
Nortson | 810 | |||||||||
novice1 | 338 | |||||||||
nqcken | 119 | 241 | ||||||||
nskn71 | 1136 | |||||||||
NuggetMcNugget | 166 | 332 | ||||||||
ObiWan-Kenobi | 422 | 423 | ||||||||
octav | 666 | |||||||||
OdorlessCurves | 529 | 530 | ||||||||
ohnonothimagain | 1357 | |||||||||
olivedrab | 658 | |||||||||
OrangePeel | 1275 | 1288 | ||||||||
orinjuse | 835 | |||||||||
Orionz23 | 1168 | |||||||||
osb40000 | 193 | |||||||||
OscarM | 1290 | |||||||||
Oswald3211 | 724 | |||||||||
oto | 888 | |||||||||
Ozythemandias | 625 | |||||||||
Pablogy | 441 | |||||||||
PabloVerde | 1037 | |||||||||
pacbough | 149 | |||||||||
papaslightsaber | 583 | 1125 | 1126 | |||||||
patchythepirate | 704 | 1364 | ||||||||
patmet | 1347 | |||||||||
patmurris | 55 | |||||||||
patmurris | 1355 | |||||||||
Paul321 | 139 | |||||||||
pawwright | 151 | |||||||||
PBWilson | 557 | 558 | ||||||||
peabody | 207 | |||||||||
Peetz | 311 | |||||||||
Pegaso | 122 | |||||||||
Peho | 112 | |||||||||
pepe2017 | 1305 | |||||||||
pepinfaxera | 1158 | |||||||||
perche | 1155 | |||||||||
peterlcole | 924 | |||||||||
peteybaby | 549 | |||||||||
petr9999 | 1137 | |||||||||
Petroleum Lantern Guy | 891 | |||||||||
Phoenix_FIN | 395 | |||||||||
Pidro | 465 | |||||||||
pieman7 | 670 | |||||||||
pirate joe 22 | 678 | 679 | 783 | 784 | ||||||
piyoman | 840 | |||||||||
plntigrado | 1153 | |||||||||
pommie | 54 | |||||||||
pook | 330 | |||||||||
pooptoast | 519 | |||||||||
powerfultorches | 569 | |||||||||
praveendk | 437 | |||||||||
presterjohn | 586 | 715 | ||||||||
Presumptuous | 653 | 654 | 655 | |||||||
Primal | 364 | |||||||||
prisma | 401 | |||||||||
Prometheus | 1149 | |||||||||
ProtaBLF | 419 | |||||||||
pscal | 376 | |||||||||
puccio1969 | 76 | |||||||||
Pukachi | 205 | |||||||||
pukoid | 868 | |||||||||
Pulsar13 | 288 | |||||||||
qandeel | 631 | 632 | ||||||||
R.D. | 974 | |||||||||
radb | 856 | |||||||||
rag | 283 | 298 | ||||||||
Ragsy | 499 | 1117 | ||||||||
raiko | 570 | |||||||||
rajun50 | 651 | |||||||||
Randolph | 212 | |||||||||
RapidLux | 1346 | 1360 | ||||||||
Rat_Racer | 999 | |||||||||
RaVeN | 160 | |||||||||
raynman | 706 | |||||||||
rdoc613 | 879 | |||||||||
red72vw | 521 | |||||||||
redrider706 | 1359 | |||||||||
regaia | 1008 | |||||||||
reliant_turbo | 710 | 850 | ||||||||
ReManG | 320 | |||||||||
reno | 1118 | |||||||||
retiro675 | 352 | 826 | ||||||||
rexdog | 442 | 515 | ||||||||
rfd673 | 747 | |||||||||
ricardon | 300 | |||||||||
Ricflair | 323 | |||||||||
Rick | 199 | |||||||||
rjorge | 708 | |||||||||
rmkline | 436 | |||||||||
Rob_K | 244 | |||||||||
robbobus | 233 | |||||||||
Roberrt777 | 185 | |||||||||
RobertB | 140 | |||||||||
RocketTomato | 766 | |||||||||
RockHugger | 1173 | |||||||||
Romey310 | 969 | 970 | ||||||||
RonMuller | 111 | |||||||||
Roter | 649 | |||||||||
RotorHead64 | 1284 | |||||||||
Rpdos | 1180 | |||||||||
Rska | 650 | |||||||||
Rsqweezy | 814 | |||||||||
rufrydr | 765 | |||||||||
Rufusbduck | 60 | |||||||||
Rxich | 866 | |||||||||
ryukin2000 | 1220 | |||||||||
sac02 | 645 | 908 | 1215 | 1216 | ||||||
saf99 | 755 | |||||||||
Saigon | 247 | |||||||||
SamHaLeKe | 485 | |||||||||
samis | 509 | |||||||||
samnavy | 73 | |||||||||
san san | 926 | 1130 | 1131 | |||||||
sandanbob | 532 | |||||||||
Sarge930 | 86 | |||||||||
Savydude | 1222 | |||||||||
SawMaster | 45 | |||||||||
saypat | 141 | |||||||||
sb56637 | 191 | |||||||||
scarnific | 566 | |||||||||
scdaf | 271 | 296 | ||||||||
Schkü | 614 | |||||||||
schlockproof | 612 | |||||||||
Sciencetists | 257 | |||||||||
SciFiFreak | 31 | |||||||||
Scooby | 582 | |||||||||
Scooter000 | 315 | |||||||||
scootypuffjr | 844 | |||||||||
Scorpia | 596 | |||||||||
scotlarock | 329 | 1085 | ||||||||
Scottland | 334 | |||||||||
Scotty | 746 | |||||||||
scs | 80 | |||||||||
sebastiang | 611 | |||||||||
SebaZ74 | 1239 | 1240 | ||||||||
SeenTheLight | 301 | 819 | ||||||||
SFB | 1109 | |||||||||
Sgtpev | 206 | |||||||||
Shadowcactus | 916 | |||||||||
Shadowfax | 341 | |||||||||
Sharpie | 354 | |||||||||
shimano3000 | 409 | |||||||||
shimey | 211 | |||||||||
shirnask | 61 | 733 | ||||||||
Shoe | 957 | |||||||||
shogan | 227 | |||||||||
Shur | 284 | |||||||||
SIGShooter | 368 | |||||||||
Silent_Star | 1190 | |||||||||
Silentcropduster | 667 | |||||||||
Simplelight | 961 | 962 | ||||||||
slackwolf | 885 | 886 | ||||||||
slackwolf 3rd | 1000 | |||||||||
Sledge | 980 | 985 | 986 | 1326 | ||||||
Sledgestone | 677 | 841 | ||||||||
slickpenguin | 643 | 854 | ||||||||
slimkango | 52 | 1207 | ||||||||
slow2go | 221 | 222 | 692 | 1139 | 1140 | 1141 | 1278 | 1279 | 1280 | |
smed1275 | 494 | |||||||||
Smittymojo | 768 | 1142 | ||||||||
SmokinH | 855 | |||||||||
Snoballz | 1031 | |||||||||
SoCalTiger | 1344 | |||||||||
sochi111 | 1032 | |||||||||
Sofa | 834 | |||||||||
sol | 291 | 292 | ||||||||
SolarLumen | 776 | |||||||||
solRNY | 1291 | |||||||||
somnambulism | 562 | |||||||||
Sonpham | 621 | |||||||||
southland | 142 | 143 | 144 | 145 | ||||||
sp5it | 94 | 1201 | ||||||||
spade413 | 1178 | |||||||||
sparkyDK | 1188 | |||||||||
specialk | 865 | |||||||||
Speed4goal | 413 | |||||||||
Speedsix | 1083 | |||||||||
spkzzz | 474 | 526 | ||||||||
Sprinkles | 279 | 778 | 901 | |||||||
srs2000 | 1187 | |||||||||
stanley-beamish | 107 | |||||||||
starcrazed | 1330 | |||||||||
stareye | 540 | |||||||||
staticx57 | 238 | |||||||||
steel_1024 | 709 | |||||||||
Steenbhg | 701 | 1205 | 1206 | 1268 | ||||||
steepdrop | 435 | 497 | ||||||||
Stephen Elliott | 1322 | |||||||||
stephenk | 269 | |||||||||
steve42 | 1016 | |||||||||
Stevejj | 1218 | |||||||||
SteveMidwest | 1289 | |||||||||
stevez32 | 822 | |||||||||
Stittville Ed | 85 | 998 | ||||||||
Stoneface | 758 | 1127 | ||||||||
strango | 96 | |||||||||
strayz | 505 | |||||||||
Streamer | 1246 | |||||||||
strmix | 676 | |||||||||
Subterrestrial | 1003 | |||||||||
Sukoi | 642 | 1010 | ||||||||
Sullysat | 418 | |||||||||
Suncoaster | 682 | |||||||||
Swennie | 895 | |||||||||
Syncmasterklop | 867 | |||||||||
syracuse | 349 | |||||||||
T-boon | 304 | |||||||||
T18 | 390 | 1257 | ||||||||
t3rminal | 1213 | |||||||||
tapir | 489 | |||||||||
tarver | 132 | 229 | ||||||||
Tarvos | 15 | |||||||||
tas69 | 380 | |||||||||
tatasal | 506 | |||||||||
teacher | 321 | 1134 | ||||||||
tebeve | 893 | |||||||||
techieman33 | 456 | |||||||||
Tecmo | 57 | |||||||||
tekwyzrd | 37 | |||||||||
tenohfive | 802 | |||||||||
Tete | 217 | |||||||||
Texas_Ace | 472 | 473 | ||||||||
The Burgh | 235 | |||||||||
The Grand Pooh-Bah | 1056 | 1057 | ||||||||
The Imp | 1242 | |||||||||
The Jinx | 522 | 699 | ||||||||
The Last Katun | 90 | |||||||||
The Miller | 1 | 2 | ||||||||
The_Driver | 1352 | |||||||||
thebaum | 585 | 807 | ||||||||
thecrc | 1177 | |||||||||
TheDude | 415 | |||||||||
TheHebrewHammer | 820 | 821 | ||||||||
TheJo | 1053 | |||||||||
TheMadcap | 97 | |||||||||
themaindude | 343 | 1094 | 1095 | |||||||
Theodore41 | 520 | |||||||||
theoldbill | 59 | |||||||||
TheOnlyDocc | 1135 | |||||||||
thijsco19 | 24 | |||||||||
tigris99 | 603 | |||||||||
timcodes | 1004 | 1017 | ||||||||
tindrum42 | 1059 | 1060 | ||||||||
tinowrx | 572 | |||||||||
Tixx | 371 | |||||||||
Tjhosan | 273 | |||||||||
Tjohn | 940 | 941 | 942 | 943 | 944 | |||||
Tmik | 287 | |||||||||
tmxod | 771 | |||||||||
Toccata | 1241 | |||||||||
tocirahl | 1362 | |||||||||
Tom E | 28 | 29 | 874 | 875 | 1223 | 1224 | ||||
Tom_182 | 695 | 780 | ||||||||
tomtaylor | 201 | |||||||||
tonylim | 43 | |||||||||
torchjunkie | 483 | 597 | ||||||||
toxiccoccyx | 1107 | |||||||||
ToyKeeper | 339 | |||||||||
tracerfire | 1317 | |||||||||
Trashman531 | 285 | |||||||||
Trasnodel | 729 | |||||||||
trevglas | 200 | |||||||||
trevize | 1165 | |||||||||
treysoucie | 789 | |||||||||
tristanxoxo | 240 | 1070 | ||||||||
troisanh | 91 | |||||||||
tronx | 674 | |||||||||
TRoPHeuS | 1152 | |||||||||
tru3s1lv3r | 39 | |||||||||
Tunerman | 1002 | |||||||||
tungkon | 1011 | |||||||||
TurboLion | 917 | |||||||||
turbopscl | 892 | |||||||||
turpulator | 1066 | 1363 | ||||||||
tzmxxhh | 21 | |||||||||
Ulric | 1198 | |||||||||
unit311 | 849 | |||||||||
unknown00101 | 548 | |||||||||
uqs1000 | 357 | |||||||||
Vagany | 647 | |||||||||
VaKo | 208 | |||||||||
Valdorg | 1202 | |||||||||
Van | 491 | |||||||||
Vanq86 | 1176 | |||||||||
vas | 133 | |||||||||
vasa_visost | 668 | |||||||||
Vattern | 18 | |||||||||
velocraig | 781 | |||||||||
vex_zg | 730 | |||||||||
Viamede | 948 | |||||||||
vinte77 | 414 | |||||||||
Volks1973 | 743 | |||||||||
vulpes | 539 | |||||||||
vwpieces | 881 | |||||||||
Wackyvegan | 156 | |||||||||
walty | 280 | |||||||||
WarHawk-AVG | 420 | 421 | ||||||||
warzi1975 | 528 | |||||||||
wattstar | 791 | |||||||||
websterjody | 996 | 1105 | ||||||||
weklund | 460 | |||||||||
Werner | 10 | |||||||||
WestBam | 1333 | |||||||||
westcoastwonders | 639 | |||||||||
whitecitadel | 1354 | |||||||||
Wieselflinkpro | 125 | 750 | 1079 | |||||||
Wildcat | 827 | 945 | ||||||||
wildmermaid | 1091 | |||||||||
Wildthing | 533 | |||||||||
willmo | 605 | 882 | ||||||||
WillyD | 303 | |||||||||
wilwok | 1076 | 1258 | ||||||||
Wineslurper | 554 | 555 | ||||||||
wisefire | 869 | |||||||||
wishiwereaskibum | 587 | |||||||||
wkhchin81 | 477 | |||||||||
Wojto | 1325 | |||||||||
WolfA | 69 | |||||||||
Wrathbringer27 | 41 | |||||||||
wunderhe | 115 | |||||||||
Wyre | 1269 | |||||||||
Xandre | 527 | |||||||||
xCentrino | 1314 | 1358 | ||||||||
xed888 | 305 | |||||||||
xelario | 773 | |||||||||
xjsnake | 36 | |||||||||
xray291 | 1192 | |||||||||
xtrosity | 723 | |||||||||
XXX-Man | 1197 | |||||||||
xzel87 | 665 | |||||||||
yasenf | 1006 | 1232 | 1233 | 1273 | 1274 | |||||
yclongthrow | 898 | 899 | ||||||||
YoFlash | 744 | |||||||||
Yokiamy | 1245 | |||||||||
Yourrid | 1101 | 1102 | ||||||||
zachary6227 | 1297 | |||||||||
zak.wilson | 182 | |||||||||
Zanders | 792 | |||||||||
zara | 180 | |||||||||
zelee | 22 | |||||||||
Zeratull | 703 | |||||||||
zeroair | 452 | |||||||||
zifzif | 1243 | |||||||||
zipelgas | 386 | |||||||||
zoysiamo | 1251 | |||||||||
ZozzV6 | 626 | |||||||||
×73rmin8r | 1063 |
1008 names
1360 lights
- 2 DOGS, 264, 2Ace, 5ar, 7pot, a12luke, a_idiot, Aardvark Spleen, Abe87, Abqjohnny
- abril, adirondackdestroyer, adrianlights, AEDe, Ag76, aggillator, aginthelaw, Agiri, aim120, AirBreaker
- akhyar, akoposilester, akovia, albertopnp, Alcius, alejandrov, alex64, AlexGT, Alkpwn77, allthumbs
- alphazeta, alternety, Alux, amplificus, Andmiller, andrewmac, Andybibbville, Andyman?, Angel Martínez, ant0
- Antenne, Anthon, antiparanoico, AppA, aprendiz, apt323, archi, archimedes, aremihc, ARMS.AARON
- ARsee, Arufonsi, aslpg, asnidi2, asot, Astromanic, AsylumSweep, atbglenn, Atom00, Autoclave
- Awdtsi, Awkward Stretch, AwkwardPause, b1i1l1l1y1, B42, BackpackNY, bakalakos, balazs1956, baldo21, Bam35
- bamawthu, banker, basslovin808, Bastarrdo, Batch1, battletross, bawilson2, Bc412, bd52, BDM
- BDWrabbit, BeardedRaleigh, bella-headlight, Bernard, Bevo, bhuge00, bigpix, bigrick, bikedave99, bikenber73
- Bill 63, Bill_tong, Billcheese5, bionictony, bkling, BlackList, bladesmith3, BLFD80, BlindingL5s, blinker
- blinky, blueb8llz, Bluzie, bmaddison, Boaz, BobbyMK, bobdotorg, bobofire, Bogdan, bogdanr
- Bohemian, bonfire, Bong lick, Bonham, borealis, BorisBar, Boro, bossf350, Box, Brettg4215
- Brian Metcalfe, BrianK, BrianTheJay, brightlights, brjones, brno602, brted, Bruno28, BT100, Bungle88
- Buzzy243, bwl123, cabfrank, Caleb, Caleb-v, Calmaja, Cano, Captainvideo, caramba, carmantl
- casi29061965, cavorite, Cawi, cbrake10, cclight, cdjaney, Chadvone, Charga, charles lin, CheapThrills
- cheesecheeks, ChibiM, Chicken Drumstick, chinooker, chooma, chrisc, churchilllafemme, CircaM, Cjlee89, cjoe7
- CJW, clagged, clange50, clinicdoc, Cliwilnew, cloggy, cmflippen, cnrffl1, cocoschnauzer, contigo
- Coolerness, coolriku, Corzy, Couchmaster, cpd800t, CrashOne, Crazyeddie, Creepo, cristhemuso, crx88ia
- cujo255, cwb, cypher1024, cypherz, Cythras, D10ten, Dadpool, dafarui, daninho, DarkerInSol
- darkpenguin, darol, darrenm, darrylo, DarthTader, datiLED, dave101, DavidEF?, davidkappelt, davidvns
- davos, DB Custom, dbesselt, DBSAR, DBSS, deathless, Deep skull, DeJaVu, dekozn, Dennis
- dentillozie, Dep668, derfyled, derpilgerer, Desmo, devdvr, dezoe, dhsvcs, dicksog, digitaltc
- Dimking, Dirt, Dirty_Pierre, DiscoJoe, djburkes, Djozz, dmbaty, Dobtruckers, DOCFAR, Docp723
- Doctawho, dodo, dogany, Dogsrule, donpachi, dotBLF, doubleone44, downlinx, doxerino, Dr Forinor
- Dradge, Dralf, Dregs, DrHook59, driveX, DrJones, DT101, dudunphy, Duke, dumptruck
- Dusty, Dutcheee, duvallite, dw911, Dwantink, e10sno, Easyrr, eb1888, ebosh, ediaz
- eebowler, Eggun, egrep, Eivwer, electricjelly, ElginAgain, emarkd, embee, Enelooper, engber
- ERDOS, Erethryn, erikk365, Esskay, Etex, euphxenos, everydaysurvivalgear, Evilc, EyeballFryer, Fadetoblack
- fantomR, Far Thrower, Farmboy24, Farns, Fatlight, fatsteve0, FBsLights, fcrespi, fed893, fedcas
- feralcomprehension, finges, fireblade893, firedome, Firelight2, fishlite5, fixed it, fixvid, Flash Voyager, flashination
- FlashMax, Flashy Mike, Flifish48, Flintrock, fluffman86, FmC, fonfan, fonLED, Ford Prefect, Foston Pete
- foton, Fozzy-SP, Frank A., Frankie Baby, Franz, Freddy61069, Fredylee, FreeMagenta, freeme, Fritz t. Cat
- Funzel67, fuzun, fyesilova, g60, g_sintornillos, gamezawy, gangstead, garrybunk, gboss, gds95
- gedasd, geepaw, gehrmo, geo1952, ger-slash, Gerrh, Gerrit, getbully, Gilatabar, giorgoskok
- GIR, gisewhcs, Gj, gleamer, GlinnDamar, gnatx, goatfarmer, GoldenBatt, gorb507, goshdogit
- gpapa693, gravelmonkey, green_comet, GreenShrike, gregor, GTsuperheros, Gtt980, guerrilla154, Guggga, GulfCoast
- gungoat, Gunnerboy, Guns712, h2o, Hairy_Steve, hank, Hardware, Hauwexis, haxquiz, headburger
- heatwaves, hein11ag, Herb Tarlek, Hestbech, hexcode, Hezekiah, hideehoo, HighCaliber, hmihaylov, Hobo
- hunter1, hurleyy, I_like_lamb, Ian2381, igeigeige, IH8MYX, ii_pennies, ikaruz_500, Illumenated, illusioned
- Ilmatic, ilovejesuschrist, ImA4Wheelr, ISO, iwandutchy, J-Dub74, J_R_J, jack-bkk, jacktheclipper, Jailbrake
- JakeDjanitor, Jalben, jama, Jambo, james y, javipiloto, jaynick, JayT, Jayzed, jb1
- jdunlap27284, jealous57, Jensa41, Jerommel, jerrod, jescereal, Jesjes, jfalk1, jhalb, jhullin
- jingleberry, Jinx, jkbam, jmoots, jmpaul320, jmwhite151, Joat, JockRobbins, Joe Darkness, joe1512
- joeangi, joechina, Joey Adams, John-Galt, Johnhywash1, johnnydoe, JohnnyMac, johnpc, johny723, Jonandreadolan
- JonnyC, JordanZHP, josephqool, jpcuba, JPLight, JPM3, JS721, jsmn4vu, Jtm94, Juanesdan
- juaquin, Juggeli, jurasik1, justanotherguy, Jvrthp321, jycheang, k-wong, Kafar, kahvitahra, Kalchev
- kali stupa, Kalihi, KawiBoy1428, kaybi, Kazik, kbro, keengeorge, KeepingItLight, Keepitsharp, Keisari
- keithd, KenE, Kenjii, Kentuckywindage, Kepling, KFulton, khas, Khuan, KIKY, Killforfood
- Kindle, KingSmono, kiriba-ru, Kiukas, KiwiKane, Kkelleher, Kloepper Knife Works, knightstalker, kntx, knudsengj
- Koaksijalac, Kodachrome40, KoekieMonster, kommessy, korpzgrinda, kotobuki, koyotee, Kozy, krutone, Kulumatic
- Kurt_Norway, Kusie, KutKhemist, Kysumi, LAB, lachesis, lalomt, Lamont56, lamper, lanceb1b
- laststance, lawallac, Lazy-R-us, Le_Zouave, leaftye, LEDtec, legan710, Legolas Jr., leroycp, Lexel
- Lfatman, Liber8, lichtpfadfinder, Light of Earendil, lightbulb, lightknot, lightlight22, lightmog, lightx, Lilien
- Lion42, lionheart_2281, litcrit, Litefighter, LloydV, Loneman, longmire, Lopan, lovetheguitar, Lowtech
- ludolf, luisgcan, Lumenmaster17, Lumens Industry, lumiere, Lund1660, luxlad, lyse99, Lyubo Yanev, M4D M4X
- M78, MACS0647, MAD TM26, Magbrite, magnet, MagPap, Maiden666, maildroid, Majoroverkill, malamask
- mandala, manithree, Manulous, ManWithoutShadow, Mapache, markalike, Marothar, marsalla, Martini, martook
- martytown, Masejoer, Matchoo, matkovicha, Matomoto, mattlward, MauiSon, maukka, Maxxsounds, MBuitendorp
- mcfarlie6996, MCT, Mecallie, MechEngVictor, Medvegy, Melven, meti, metz3006, Meyer, MG
- mhanlen, mi bill, Micael, Miguel_79, Miguelintegral, mikeyx, Mindaugass, Minimoke, miswas, Mitko
- mitrhandir, mizjif, Mkduffer, mlodyulek, moemin, MontyPyfon, moridin, Morpheus, MorpheusT1, MortyDuck
- MountainKing, MountainMan, mozart.f, Mr.Poppy, Mr.Scott, mrheosuper, mrkelvin, MRsDNF, mrstealyourgains, msg1285
- Mstevens113, Mt.B, MtnDon, mud_muncher, mudguts, Muto, mutts13, muzzleblast?, mxlu, MyDangus
- myowin, myst999, nanojack, narin000, Nathan42, Navin_R_Johnson, neckbear, needmorlts, Neilyboy, netprince
- nexrace1, nfetterly, Nguyen, nickdude, Nickke, Nicolaas, Nicolicous, Night Light, NightLight, Nightshade
- niktak11, Nil, Nite Shadow, Nitetime, nitrader0, nnmnu1, No Agenda, nofear87, Noki, noob
- Nord, Nortson, novice1, nqcken, nskn71, NuggetMcNugget, ObiWan-Kenobi, octav, OdorlessCurves, ohnonothimagain
- olivedrab, OrangePeel, orinjuse, Orionz23, osb40000, OscarM, Oswald3211, oto, Ozythemandias, Pablogy
- PabloVerde, pacbough, papaslightsaber, patchythepirate, patmet, patmurris, patmurris , Paul321, pawwright, PBWilson
- peabody, Peetz, Pegaso, Peho, pepe2017, pepinfaxera, perche, peterlcole, peteybaby, petr9999
- Petroleum Lantern Guy, Phoenix_FIN, Pidro, pieman7, pirate joe 22, piyoman, plntigrado, pommie, pook, pooptoast
- powerfultorches, praveendk, presterjohn, Presumptuous, Primal, prisma, Prometheus, ProtaBLF, pscal, puccio1969
- Pukachi, pukoid, Pulsar13, qandeel, R.D., radb, rag, Ragsy, raiko, rajun50
- Randolph, RapidLux, Rat_Racer, RaVeN, raynman, rdoc613, red72vw, redrider706, regaia, reliant_turbo
- ReManG, reno, retiro675, rexdog, rfd673, ricardon, Ricflair, Rick, rjorge, rmkline
- Rob_K, robbobus, Roberrt777, RobertB, RocketTomato, RockHugger, Romey310, RonMuller, Roter, RotorHead64
- Rpdos, Rska, Rsqweezy, rufrydr, Rufusbduck, Rxich, ryukin2000, sac02, saf99, Saigon
- SamHaLeKe, samis, samnavy, san san, sandanbob, Sarge930, Savydude, SawMaster, saypat, sb56637
- scarnific, scdaf, Schkü, schlockproof, Sciencetists, SciFiFreak, Scooby, Scooter000, scootypuffjr, Scorpia
- scotlarock, Scottland, Scotty, scs, sebastiang, SebaZ74, SeenTheLight, SFB, Sgtpev, Shadowcactus
- Shadowfax, Sharpie, shimano3000, shimey, shirnask, Shoe, shogan, Shur, SIGShooter, Silent_Star
- Silentcropduster, Simplelight, slackwolf, slackwolf 3rd, Sledge, Sledgestone, slickpenguin, slimkango, slow2go, smed1275
- Smittymojo, SmokinH, Snoballz, SoCalTiger, sochi111, Sofa, sol, SolarLumen, solRNY, somnambulism
- Sonpham, southland, sp5it, spade413, sparkyDK, specialk, Speed4goal, Speedsix, spkzzz, Sprinkles
- srs2000, stanley-beamish, starcrazed, stareye, staticx57, steel_1024, Steenbhg, steepdrop, Stephen Elliott, stephenk
- steve42, Stevejj, SteveMidwest, stevez32, Stittville Ed, Stoneface, strango, strayz, Streamer, strmix
- Subterrestrial, Sukoi, Sullysat, Suncoaster, Swennie, Syncmasterklop, syracuse, T-boon, T18, t3rminal
- tapir, tarver, Tarvos, tas69, tatasal, teacher, tebeve, techieman33, Tecmo, tekwyzrd
- tenohfive, Tete, Texas_Ace, The Burgh, The Grand Pooh-Bah, The Imp, The Jinx, The Last Katun, The Miller, The_Driver
- thebaum, thecrc, TheDude, TheHebrewHammer, TheJo, TheMadcap, themaindude, Theodore41, theoldbill, TheOnlyDocc
- thijsco19, tigris99, timcodes, tindrum42, tinowrx, Tixx, Tjhosan, Tjohn, Tmik, tmxod
- Toccata, tocirahl, Tom E, Tom_182, tomtaylor, tonylim, torchjunkie, toxiccoccyx, ToyKeeper, tracerfire
- Trashman531, Trasnodel, trevglas, trevize, treysoucie, tristanxoxo, troisanh, tronx, TRoPHeuS, tru3s1lv3r
- Tunerman, tungkon, TurboLion, turbopscl, turpulator, tzmxxhh, Ulric, unit311, unknown00101, uqs1000
- Vagany, VaKo, Valdorg, Van, Vanq86, vas, vasa_visost, Vattern, velocraig, vex_zg
- Viamede, vinte77, Volks1973, vulpes, vwpieces, Wackyvegan, walty, WarHawk-AVG, warzi1975, wattstar
- websterjody, weklund, Werner, WestBam, westcoastwonders, whitecitadel, Wieselflinkpro, Wildcat, wildmermaid, Wildthing
- willmo, WillyD, wilwok, Wineslurper, wisefire, wishiwereaskibum, wkhchin81, Wojto, WolfA, Wrathbringer27
- wunderhe, Wyre, Xandre, xCentrino, xed888, xelario, xjsnake, xray291, xtrosity, XXX-Man
- xzel87, yasenf, yclongthrow, YoFlash, Yokiamy, Yourrid, zachary6227, zak.wilson, Zanders, zara
- zelee, Zeratull, zeroair, zifzif, zipelgas, zoysiamo, ZozzV6, ×73rmin8r,
teacher: sparkyDK:On a more serious note, would it be possible to make a contact ring with raised areas in the right places so flat tops would work in it too ? Or am i overthinking again.
I think, flats tops will work with it now as is… sparkyDK. EDIT: If they are of proper length. :+1:
Sheriously, typical flat tops won’t work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA’s are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
:+1: …. My apologies sparky. I was thinking only of the GA’s and totally left out the test of the important facts about most all other flat tops. :person_facepalming:
Again… my apologies. I shall now put on the Dunce Hat & sit myself in the corner the remainder of the night for the incorrect info I gave… that in all likelyhood could create confusion…… :person_facepalming: … :cry:
Thank goodness Tom caught it quickly & posted the correct info.
I’ll edit my post also…
Thats okay and not the cells i got for the Q8, i have a set of Sony’s VTC6 and a Set of the brown LG’s ( HG2 ), both flat top style i will have to do something about.
I am not quite sure if the GAs will be good without something done to them, as they have no button the spring should squease them less tight, so maybe a thud on the end cap would make connection go.
Then again as i understand the Q8 that shouldent matter if one or two cells momentarily get disconnected.
Man i cant wait to get my hands on this thing, just ordered a new sleeping bag tonight, so aside for a pice of tarp i am ready to go play survivalist in the forests of Denmark.
Forrest’s that will not be so dark when i am around, with or without the Q8
Yay! An updated list. Thanks.
Doh, just read about the switch to 3 LEDs, thats not happening is it? I certainly would vote against it but looks like I didn’t check back and see it in time to vote…
Thanks Mr.Scott. :+1:
What are you referring to might I ask?
