Besides heat from the LEDs, running at 3A at 9V output is also impractical from a single 18650 cell drive in most flashlights as well. The 27W output will require at least 30W input or more, which for most 18650 cells will require about >=10A input current which will be just about too much for the driver to handle safely. Contact and switch resistance will also lead to significant losses. However, 9V at 2A or so is completely OK (at least for the GXB20) :)
I didn’t see this in the OP. Curious what are the limits of this driver when it comes to power. I assume that the true limits lie in the input current?
I assume this could boost power to an 12v XHP35 as well with some component changes, what kind of output current would be possible?
Also, did you ever say what components you are using for this driver? I never saw a parts list, curious what boost IC you are using along with the rest of the parts.
If this could be shrunk to 17mm an xhp35 S2+ could be a really interesting EDC light (or xhp50.2 for that matter).
A TPS61088 is used as the boost converter, here is the website, even with a schematic: loneoceans labs | GXB20 v1 LED Driver PCB
I currently try to get it shrunk to 17mm (with a few modifications to the circuit).
Very soon! Layout for GXB17 is basically done. Just need to order a few PCBs and to fine tune everything (render above is not final yet, was taken during initial design). The hardest part is designing within the 6/6mil constraints of OSHpark and using 2 layers with no air-wires, though I've fabricated 5/5mil with them and they seem.. just fine. I suspect even 4/4mill will still be OK!
There are several aspects to the limits, but not hitting on the more nuanced ones would be the maximum input current of 10A. In addition, making the driver efficient at different output / input voltages requires fine-tuning the component choices such as the switch frequency, inductor and error compensation network - i.e. one cannot just run the driver for a different output configuration while expecting similarly high-efficiency output. However, if one is willing to sacrifice a bit of performance, then changing it should be fairly straightforward.
I'm still in the process of writing up a page for it but my 'sales' page has a decent overview of the BOM and Schematics. http://loneoceans.com/labs/sales/gxb20v1/ Note the V2 version is fairly different with some enhancements.
Finally there are obviously other limits to the other components such as minimum voltage input required for proper operation, thermals (getting pretty warm already at ~18W output) as well as boost inductor. Trade-offs I suppose between cost, size, efficiency, performance and features :)
So it is setup for a 7A input, thats pretty darn good. What is the limiting factor? I see the inductor is rated at 11A but didn’t take the time to look up everything else.
With a 7A input limit, that would be around 1.75-2A to an xhp35, which is pretty darn good. If it could drive it a bit harder to 2.25 - 2.5A it would be perfect.
Yeah, heat buildup should be the limiting factor, the question is which component? If you stuck the driver with thermal cubes you can usually get some more out of it if you know where the heat is coming from.
It’s either the coil or the converter itself. It’s difficult to say because the converter works a little different and has like a “built-in diode”. The diode is replaced with a mosfet controlled by a deadtime
control logic.
It’s really annoying that I spent all the time fiddling around with the 17mm board (probably finished by tomorrow), but loneoceans did it already :person_facepalming: .
I hope my version isn’t completely wasted time
I’m a driver but not a driver expert nor tweaked any LED drivers (resistor stacking doesn’t count) before. My question is: from all those components cramped in a tiny 17mm which one is the hottest one? I usually find the big square box is the hottest one, am I wrong?
Can we remotely place it somewhere else (near the tailcap perhaps) to save space and distribute the heat better?
Typically with how the drivers are placed (right behind the LED in the same thermal block), the major heat producer is the LED itself! However you are right that the next main heat producer is typically the inductor. However moving it far away from the LED (e.g. at the tailcap) isn't typically a good idea, since a significant amount of parasitic inductance is added, not to mention very large DC restive losses (since the inductor current is typically very high), as well as skin-effect losses at high switching frequencies. The ideal layout is to keep the inductor as close to the power circuit as possible.
Practically speaking, I think for most single-cell flashlights (esp. 18650), the maximum reasonable power one can expect is about 25-30W for short durations and <20W for any reasonable run-time. Anything longer than that would require a fairly large host with cooling fins, which I suppose defeats the 1-cell form factor (i.e. desirable to be small); not to mention DC power losses. For example, just 50mR DC losses from a single 4V cell outputting 30W would lead to 2.815W lost in just the wiring/switch/spring, a loss of almost 10%.
As a side note, the GXB17 is well underway - follow it here: https://budgetlightforum.com/t/-/46062
"The test [of which the results were plotted above] was conducted as follows. The driver was hooked up to a constant voltage programmable Agilent power supply. In this case I conducted the test at 3.7V in across the range (driver was also tested at a variety of input voltage from 4.5V to <3V but less comprehensively). Input current and voltage was measured via Kelvin terminals to avoid errors due to lead resistances. Output current was measured across the load resistor as well as the output to find total driver efficiency. A total of 20 constant current levels were tested and measurements taken. "
I understand the efficiency may vary across different input voltages but a quick test from around 4.2 to 3.5V for a few different output levels seemed to yield comparable efficiency.
3.5 to 4.2V is nowhere near the real voltage window of a fully loaded li-ion cell for all of its discharge curve, and that's not to say the driver sees less voltage due to contact losses. As an advocate of worst case scenario conditions, for me the input voltage value which really matters is the one which makes the driver's life harder, so I'd also test with the possible voltages coming from a nearly depleted fully loaded li-ion cell in an overdriven driver: 2.7 - 2.8V.
It depend significantly on what cell is being used, how fresh the batteries are, and at what sort of operating limits one will tolerate the driver at. I designed the driver without really expecting to push LEDs to their absolute limits - this places not only significant thermal stress to the LEDs, but also the batteries etc and affects long term reliable operation. You are right to say that the driver input voltage will be closer to 3V- on a depleted overdriven cell - at this point the driver will try to draw even more current from the battery causing the voltage to drop even further, until low-voltage protection kicks in. That said, I'm currently limited in my bench power supplies to provide sufficient current at such low voltages, so it's also a limit to my test gear for proper characterization :)
As a side now, I'll be focusing my efforts on the GXB17 development, so expect to see less updates over here (since the GXB20 V2 is essentially complete and is working happily in 2 of my flashlights!), and I'll be focusing on the GXB17 over here: https://budgetlightforum.com/t/-/46062
I see the trend in FL manufacturers is keep pushing the limit until the efficiency is just a bit better than xenon bulb torches years ago.
Higher voltage LED and lower current applications is now becoming more mainstream to boost overall efficiency. Boost drivers have to keep up sooner or later.
