On a more serious note, would it be possible to make a contact ring with raised areas in the right places so flat tops would work in it too ?
Or am i overthinking again.
I think, flats tops will work with it now as is… sparkyDK.
EDIT: If they are of proper length. :+1:
FINAL EDIT: … Sanyo GA flat tops will work because they are raised flattops.
Q 30 flat tops or any cell with flat tops like them… WILL NOT work.
My apologies for the initial incorrect informatio I gave. :person_facepalming:
I’ve been watching this on and off since the beginning and it looks like it’s finally coming together into a really impressive light, well done and thanks to everyone involved in the design. Please put me down for one.
Do we have any rough timeframe on shipping the final version yet? Once approved are they ready to start manufacturing?
Sheriously, typical flat tops won't work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA's are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
Or, if you simply use protected cells with the button already attached. As I recollect, somewhere above, it was determined that protected GAs with a good protection circuit did not seem to impact the light output vs an unprotected QA. Unless you are trying to squeeze every last lumen out of the light. But if this a concern, there are other batteries with higher amp capabilities you can blob and people can mod the light to try to make the whole power train act like a room temperature superconductor.
yeah i figured it would take some figuring out where the drum stop to make sure the batteries land on a “hill” on the contact ring.
But with design ( not the Q8 ) then i am sure they could figure it out and so the resulting flashlight could use any battery.
I am fully aware this are a done deal for the Q8 and that’s just fine i will just do something to the flat tops i have gotten for it.
But in future flashlights ( not least multi cell like the Q8 ) it would be nice if they would work with any type of the particular cells its build for.
But i have been wondering even if the “hills” was smooth for the battery’s to climb easy, the design of flattops and their wrapping might suffer damage over time as the batteries would have to go up and over those “hills” several times before they land in the final resting place.
Also i have been thinking if you should lathe those hills in the contact ring, or you could make do with just punching dents into the ring.
Now i am thinking ( i know i should be sleeping now but my brain will just not allow for that it seem )
How about if the 4 batteries in a light like the Q8 was staggered in a drum around a central pillar onto which you then screw on the end cap ?
This way the batteries should be stationary when the flashlight are put together, a bonus might be you can use bigger O-rings where the battery “drum” seal onto the LED end and the tail cap end, making for a bigger chance of a waterproof light and using larger more forgiving O-rings.
Off course this design will mean that the battery drum will just be held on the LED end with the friction of the O-ring when the end cap are unscrewed for battery change.
Holy sh, ee now i better stop cuz now i have tail cap contact ideas too, i better go for a drive and get me some sugar water to get the creative juices going again.
sparkyDK, this is an already-solved issue which came up just a few pages ago. It simply requires a different design:
A few people at BLF have done it. The trick is to lock the battery tube in place and unscrew only the very tail end of the light, with posts built in to keep the rotation correct. For example: [image]
The Q8 will not use this method though; it uses a SRK style ring instead. So… make sure the positive terminal is higher than the cell wrapper.
PLEASE CHECK IF YOU ARE ON THE LIST OK
The Q8 list (from post #1) sorted alphabetically .
(As of post #8341)
2 DOGS | 186 | |||||||||
264 | 641 | |||||||||
2Ace | 165 | 1119 | ||||||||
5ar | 697 | |||||||||
7pot | 982 | |||||||||
a12luke | 932 | |||||||||
a_idiot | 740 | |||||||||
Aardvark Spleen | 253 | 402 | 403 | |||||||
Abe87 | 876 | |||||||||
Abqjohnny | 51 | 1169 | ||||||||
abril | 50 | |||||||||
adirondackdestroyer | 545 | |||||||||
adrianlights | 255 | |||||||||
AEDe | 923 | |||||||||
Ag76 | 1345 | |||||||||
aggillator | 458 | |||||||||
aginthelaw | 278 | |||||||||
Agiri | 110 | |||||||||
aim120 | 430 | |||||||||
AirBreaker | 155 | |||||||||
akhyar | 387 | |||||||||
akoposilester | 56 | 1111 | 1112 | |||||||
akovia | 937 | |||||||||
albertopnp | 365 | |||||||||
Alcius | 105 | |||||||||
alejandrov | 523 | |||||||||
alex64 | 1159 | |||||||||
AlexGT | 495 | |||||||||
Alkpwn77 | 204 | |||||||||
allthumbs | 218 | |||||||||
alphazeta | 335 | |||||||||
alternety | 564 | 565 | ||||||||
Alux | 702 | |||||||||
amplificus | 904 | 983 | 984 | |||||||
Andmiller | 1064 | 1065 | ||||||||
andrewmac | 407 | |||||||||
Andybibbville | 147 | |||||||||
Andyman? | 13 | |||||||||
Angel Martínez | 128 | |||||||||
ant0 | 1195 | |||||||||
Antenne | 801 | |||||||||
Anthon | 568 | |||||||||
antiparanoico | 32 | |||||||||
AppA | 1208 | |||||||||
aprendiz | 1160 | 1261 | ||||||||
apt323 | 47 | 544 | ||||||||
archi | 1157 | |||||||||
archimedes | 67 | |||||||||
aremihc | 910 | |||||||||
ARMS.AARON | 1089 | |||||||||
ARsee | 1228 | 1229 | ||||||||
Arufonsi | 921 | |||||||||
aslpg | 398 | |||||||||
asnidi2 | 1327 | |||||||||
asot | 690 | |||||||||
Astromanic | 424 | |||||||||
AsylumSweep | 863 | |||||||||
atbglenn | 567 | |||||||||
Atom00 | 358 | 359 | ||||||||
Autoclave | 1099 | |||||||||
Awdtsi | 1221 | |||||||||
Awkward Stretch | 619 | |||||||||
AwkwardPause | 464 | |||||||||
b1i1l1l1y1 | 1052 | |||||||||
B42 | 685 | 686 | 1019 | 1020 | ||||||
BackpackNY | 571 | 1084 | ||||||||
bakalakos | 202 | |||||||||
balazs1956 | 1341 | |||||||||
baldo21 | 260 | 261 | ||||||||
Bam35 | 1039 | |||||||||
bamawthu | 599 | |||||||||
banker | 1013 | |||||||||
basslovin808 | 446 | |||||||||
Bastarrdo | 117 | |||||||||
Batch1 | 293 | 344 | ||||||||
battletross | 809 | |||||||||
bawilson2 | 500 | 501 | ||||||||
Bc412 | 5 | |||||||||
bd52 | 399 | |||||||||
BDM | 1018 | |||||||||
BDWrabbit | 1244 | |||||||||
BeardedRaleigh | 662 | |||||||||
bella-headlight | 49 | 411 | 877 | |||||||
Bernard | 232 | |||||||||
Bevo | 1086 | |||||||||
bhuge00 | 1049 | |||||||||
bigpix | 84 | |||||||||
bigrick | 754 | |||||||||
bikedave99 | 1174 | |||||||||
bikenber73 | 14 | |||||||||
Bill 63 | 752 | 1296 | ||||||||
Bill_tong | 896 | |||||||||
Billcheese5 | 949 | |||||||||
bionictony | 1338 | |||||||||
bkling | 1067 | |||||||||
BlackList | 1350 | |||||||||
bladesmith3 | 607 | |||||||||
BLFD80 | 933 | |||||||||
BlindingL5s | 312 | |||||||||
blinker | 1306 | 1353 | ||||||||
blinky | 1209 | |||||||||
blueb8llz | 70 | 553 | 1120 | 1121 | 1122 | 1123 | ||||
Bluzie | 785 | |||||||||
bmaddison | 248 | |||||||||
Boaz | 391 | |||||||||
BobbyMK | 462 | |||||||||
bobdotorg | 1271 | 1272 | ||||||||
bobofire | 1313 | |||||||||
Bogdan | 370 | 371 | ||||||||
bogdanr | 466 | |||||||||
Bohemian | 775 | |||||||||
bonfire | 412 | |||||||||
Bong lick | 763 | 1075 | ||||||||
Bonham | 262 | |||||||||
borealis | 1098 | |||||||||
BorisBar | 575 | 1238 | ||||||||
Boro | 360 | 361 | ||||||||
bossf350 | 803 | |||||||||
Box | 671 | |||||||||
Brettg4215 | 864 | |||||||||
Brian Metcalfe | 318 | 319 | 374 | |||||||
BrianK | 447 | 560 | 1356 | |||||||
BrianTheJay | 950 | |||||||||
brightlights | 243 | |||||||||
brjones | 504 | |||||||||
brno602 | 913 | |||||||||
brted | 249 | |||||||||
Bruno28 | 513 | |||||||||
BT100 | 1087 | 1138 | ||||||||
Bungle88 | 610 | |||||||||
Buzzy243 | 1179 | |||||||||
bwl123 | 870 | |||||||||
cabfrank | 443 | 988 | ||||||||
Caleb | 203 | 547 | ||||||||
Caleb-v | 444 | |||||||||
Calmaja | 35 | |||||||||
Cano | 661 | 1151 | ||||||||
Captainvideo | 1302 | |||||||||
caramba | 748 | |||||||||
carmantl | 345 | 346 | ||||||||
casi29061965 | 467 | 490 | ||||||||
cavorite | 1028 | |||||||||
Cawi | 1276 | |||||||||
cbrake10 | 749 | |||||||||
cclight | 897 | |||||||||
cdjaney | 825 | |||||||||
Chadvone | 63 | 693 | ||||||||
Charga | 124 | |||||||||
charles lin | 1124 | |||||||||
CheapThrills | 469 | |||||||||
cheesecheeks | 816 | |||||||||
ChibiM | 1310 | 1321 | ||||||||
Chicken Drumstick | 131 | |||||||||
chinooker | 1260 | |||||||||
chooma | 210 | 351 | ||||||||
chrisc | 741 | 742 | ||||||||
churchilllafemme | 1230 | |||||||||
CircaM | 894 | |||||||||
Cjlee89 | 951 | |||||||||
cjoe7 | 146 | |||||||||
CJW | 367 | |||||||||
clagged | 991 | |||||||||
clange50 | 479 | 480 | ||||||||
clinicdoc | 1226 | |||||||||
Cliwilnew | 795 | |||||||||
cloggy | 404 | |||||||||
cmflippen | 83 | |||||||||
cnrffl1 | 577 | 1113 | ||||||||
cocoschnauzer | 363 | |||||||||
contigo | 1351 | |||||||||
Coolerness | 664 | |||||||||
coolriku | 517 | |||||||||
Corzy | 308 | |||||||||
Couchmaster | 245 | 551 | 552 | |||||||
cpd800t | 406 | |||||||||
CrashOne | 372 | 377 | ||||||||
Crazyeddie | 98 | 137 | 487 | |||||||
Creepo | 909 | |||||||||
cristhemuso | 388 | |||||||||
crx88ia | 683 | |||||||||
cujo255 | 1191 | |||||||||
cwb | 134 | |||||||||
cypher1024 | 973 | |||||||||
cypherz | 250 | |||||||||
Cythras | 956 | |||||||||
D10ten | 608 | |||||||||
Dadpool | 1161 | |||||||||
dafarui | 1339 | |||||||||
daninho | 468 | |||||||||
DarkerInSol | 615 | 616 | 617 | 618 | ||||||
darkpenguin | 718 | 719 | 735 | 736 | 737 | 738 | 739 | 860 | 861 | 862 |
darol | 798 | |||||||||
darrenm | 1054 | 1055 | ||||||||
darrylo | 507 | |||||||||
DarthTader | 830 | |||||||||
datiLED | 761 | |||||||||
dave101 | 1041 | |||||||||
DavidEF? | 7 | |||||||||
davidkappelt | 1026 | |||||||||
davidvns | 1128 | |||||||||
davos | 1062 | |||||||||
DB Custom | 713 | 722 | 997 | |||||||
dbesselt | 1156 | |||||||||
DBSAR | 136 | 169 | 1281 | |||||||
DBSS | 516 | 779 | ||||||||
deathless | 518 | |||||||||
Deep skull | 977 | |||||||||
DeJaVu | 669 | |||||||||
dekozn | 800 | |||||||||
Dennis | 934 | |||||||||
dentillozie | 488 | |||||||||
Dep668 | 687 | 688 | ||||||||
derfyled | 1237 | |||||||||
derpilgerer | 630 | |||||||||
Desmo | 805 | |||||||||
devdvr | 486 | |||||||||
dezoe | 1186 | |||||||||
dhsvcs | 265 | 1336 | 1337 | |||||||
dicksog | 559 | |||||||||
digitaltc | 1323 | |||||||||
Dimking | 425 | |||||||||
Dirt | 815 | |||||||||
Dirty_Pierre | 1045 | |||||||||
DiscoJoe | 1254 | |||||||||
djburkes | 188 | 878 | ||||||||
Djozz | 3 | 1115 | 1286 | |||||||
dmbaty | 1294 | |||||||||
Dobtruckers | 1058 | |||||||||
DOCFAR | 595 | |||||||||
Docp723 | 347 | 433 | 434 | |||||||
Doctawho | 440 | |||||||||
dodo | 88 | 274 | ||||||||
dogany | 813 | |||||||||
Dogsrule | 508 | |||||||||
donpachi | 1252 | |||||||||
dotBLF | 968 | |||||||||
doubleone44 | 887 | |||||||||
downlinx | 74 | 316 | ||||||||
doxerino | 1304 | |||||||||
Dr Forinor | 873 | |||||||||
Dradge | 1248 | |||||||||
Dralf | 1015 | |||||||||
Dregs | 172 | |||||||||
DrHook59 | 883 | |||||||||
driveX | 659 | |||||||||
DrJones | 75 | |||||||||
DT101 | 152 | |||||||||
dudunphy | 389 | |||||||||
Duke | 381 | |||||||||
dumptruck | 971 | |||||||||
Dusty | 327 | 328 | ||||||||
Dutcheee | 68 | 322 | ||||||||
duvallite | 889 | |||||||||
dw911 | 478 | |||||||||
Dwantink | 135 | |||||||||
e10sno | 405 | 1318 | 1319 | |||||||
Easyrr | 6 | |||||||||
eb1888 | 837 | 838 | 839 | |||||||
ebosh | 777 | |||||||||
ediaz | 906 | |||||||||
eebowler | 774 | |||||||||
Eggun | 1104 | 1312 | ||||||||
egrep | 594 | |||||||||
Eivwer | 171 | |||||||||
electricjelly | 237 | 256 | ||||||||
ElginAgain | 1204 | |||||||||
emarkd | 109 | |||||||||
embee | 511 | |||||||||
Enelooper | 417 | |||||||||
engber | 947 | |||||||||
ERDOS | 1150 | |||||||||
Erethryn | 1259 | |||||||||
erikk365 | 648 | |||||||||
Esskay | 995 | |||||||||
Etex | 829 | |||||||||
euphxenos | 408 | |||||||||
everydaysurvivalgear | 103 | |||||||||
Evilc | 65 | |||||||||
EyeballFryer | 189 | |||||||||
Fadetoblack | 1295 | |||||||||
fantomR | 636 | |||||||||
Far Thrower | 148 | 197 | ||||||||
Farmboy24 | 1234 | |||||||||
Farns | 277 | |||||||||
Fatlight | 663 | |||||||||
fatsteve0 | 1361 | |||||||||
FBsLights | 790 | |||||||||
fcrespi | 1262 | |||||||||
fed893 | 307 | |||||||||
fedcas | 902 | |||||||||
feralcomprehension | 1194 | 1311 | ||||||||
finges | 561 | |||||||||
fireblade893 | 209 | |||||||||
firedome | 324 | 711 | ||||||||
Firelight2 | 397 | |||||||||
fishlite5 | 1046 | |||||||||
fixed it | 78 | 1097 | ||||||||
fixvid | 1264 | |||||||||
Flash Voyager | 652 | |||||||||
flashination | 87 | |||||||||
FlashMax | 1225 | |||||||||
Flashy Mike | 239 | 410 | 448 | 449 | ||||||
Flifish48 | 806 | 1096 | ||||||||
Flintrock | 629 | |||||||||
fluffman86 | 958 | |||||||||
FmC | 1182 | |||||||||
fonfan | 234 | 1023 | 1024 | |||||||
fonLED | 725 | |||||||||
Ford Prefect | 1068 | |||||||||
Foston Pete | 453 | 454 | 644 | |||||||
foton | 1030 | |||||||||
Fozzy-SP | 317 | |||||||||
Frank A. | 1172 | |||||||||
Frankie Baby | 342 | |||||||||
Franz | 788 | |||||||||
Freddy61069 | 282 | |||||||||
Fredylee | 223 | 1329 | ||||||||
FreeMagenta | 1050 | |||||||||
freeme | 514 | |||||||||
Fritz t. Cat | 484 | |||||||||
Funzel67 | 990 | |||||||||
fuzun | 1074 | |||||||||
fyesilova | 535 | |||||||||
g60 | 290 | |||||||||
g_sintornillos | 126 | |||||||||
gamezawy | 38 | 336 | ||||||||
gangstead | 53 | 922 | ||||||||
garrybunk | 254 | |||||||||
gboss | 832 | |||||||||
gds95 | 1199 | |||||||||
gedasd | 1309 | |||||||||
geepaw | 1038 | |||||||||
gehrmo | 289 | |||||||||
geo1952 | 455 | 457 | ||||||||
ger-slash | 416 | |||||||||
Gerrh | 531 | 1163 | 1164 | 1285 | ||||||
Gerrit | 106 | |||||||||
getbully | 609 | 1263 | ||||||||
Gilatabar | 638 | |||||||||
giorgoskok | 306 | 493 | 1092 | |||||||
GIR | 804 | 818 | ||||||||
gisewhcs | 384 | |||||||||
Gj | 580 | 581 | ||||||||
gleamer | 432 | |||||||||
GlinnDamar | 1342 | |||||||||
gnatx | 588 | 824 | ||||||||
goatfarmer | 770 | |||||||||
GoldenBatt | 383 | 589 | 590 | |||||||
gorb507 | 811 | 812 | ||||||||
goshdogit | 11 | 12 | 40 | 120 | 121 | 543 | 556 | 928 | ||
gpapa693 | 79 | |||||||||
gravelmonkey | 1027 | |||||||||
green_comet | 601 | |||||||||
GreenShrike | 190 | |||||||||
gregor | 215 | |||||||||
GTsuperheros | 179 | |||||||||
Gtt980 | 936 | |||||||||
guerrilla154 | 1316 | |||||||||
Guggga | 538 | |||||||||
GulfCoast | 880 | |||||||||
gungoat | 44 | |||||||||
Gunnerboy | 252 | 967 | ||||||||
Guns712 | 1300 | 1301 | ||||||||
h2o | 181 | 476 | ||||||||
Hairy_Steve | 340 | |||||||||
hank | 258 | |||||||||
Hardware | 1071 | 1200 | ||||||||
Hauwexis | 845 | 846 | 847 | 848 | ||||||
haxquiz | 226 | 927 | ||||||||
headburger | 592 | |||||||||
heatwaves | 994 | 1265 | ||||||||
hein11ag | 183 | |||||||||
Herb Tarlek | 931 | |||||||||
Hestbech | 994 | 995 | ||||||||
hexcode | 503 | 672 | ||||||||
Hezekiah | 286 | 759 | ||||||||
hideehoo | 859 | |||||||||
HighCaliber | 177 | 178 | ||||||||
hmihaylov | 502 | |||||||||
Hobo | 220 | |||||||||
hunter1 | 116 | 720 | 721 | |||||||
hurleyy | 993 | |||||||||
I_like_lamb | 915 | |||||||||
Ian2381 | 150 | |||||||||
igeigeige | 890 | |||||||||
IH8MYX | 546 | |||||||||
ii_pennies | 481 | |||||||||
ikaruz_500 | 989 | |||||||||
Illumenated | 426 | |||||||||
illusioned | 954 | |||||||||
Ilmatic | 1253 | 1332 | ||||||||
ilovejesuschrist | 294 | 295 | ||||||||
ImA4Wheelr | 19 | |||||||||
ISO | 705 | 734 | 929 | 930 | ||||||
iwandutchy | 1047 | |||||||||
J-Dub74 | 461 | |||||||||
J_R_J | 675 | |||||||||
jack-bkk | 356 | |||||||||
jacktheclipper | 1108 | |||||||||
Jailbrake | 1034 | 1090 | ||||||||
JakeDjanitor | 46 | |||||||||
Jalben | 187 | |||||||||
jama | 635 | |||||||||
Jambo | 912 | |||||||||
james y | 1043 | 1044 | ||||||||
javipiloto | 1154 | |||||||||
jaynick | 1048 | |||||||||
JayT | 62 | |||||||||
Jayzed | 1214 | |||||||||
jb1 | 224 | |||||||||
jdunlap27284 | 164 | |||||||||
jealous57 | 81 | |||||||||
Jensa41 | 731 | 732 | ||||||||
Jerommel | 637 | |||||||||
jerrod | 512 | |||||||||
jescereal | 228 | |||||||||
Jesjes | 153 | 154 | ||||||||
jfalk1 | 918 | |||||||||
jhalb | 297 | |||||||||
jhullin | 159 | 751 | ||||||||
jingleberry | 1022 | |||||||||
Jinx | 93 | |||||||||
jkbam | 550 | |||||||||
jmoots | 268 | |||||||||
jmpaul320 | 95 | 299 | ||||||||
jmwhite151 | 482 | 851 | 852 | 853 | ||||||
Joat | 184 | |||||||||
JockRobbins | 717 | |||||||||
Joe Darkness | 620 | |||||||||
joe1512 | 534 | |||||||||
joeangi | 756 | |||||||||
joechina | 633 | |||||||||
Joey Adams | 1021 | 1132 | ||||||||
John-Galt | 463 | |||||||||
Johnhywash1 | 966 | |||||||||
johnnydoe | 1227 | |||||||||
JohnnyMac | 496 | |||||||||
johnpc | 955 | |||||||||
johny723 | 1082 | |||||||||
Jonandreadolan | 1072 | |||||||||
JonnyC | 576 | |||||||||
JordanZHP | 1078 | 1196 | ||||||||
josephqool | 1061 | |||||||||
jpcuba | 684 | |||||||||
JPLight | 23 | 646 | ||||||||
JPM3 | 263 | 264 | ||||||||
JS721 | 216 | |||||||||
jsmn4vu | 793 | |||||||||
Jtm94 | 1035 | |||||||||
Juanesdan | 118 | |||||||||
juaquin | 219 | |||||||||
Juggeli | 745 | |||||||||
jurasik1 | 1231 | |||||||||
justanotherguy | 541 | 712 | 1080 | |||||||
Jvrthp321 | 691 | |||||||||
jycheang | 1009 | |||||||||
k-wong | 542 | 1005 | ||||||||
Kafar | 9 | |||||||||
kahvitahra | 796 | |||||||||
Kalchev | 400 | |||||||||
kali stupa | 1217 | |||||||||
Kalihi | 836 | |||||||||
KawiBoy1428 | 230 | |||||||||
kaybi | 1033 | |||||||||
Kazik | 1315 | |||||||||
kbro | 168 | |||||||||
keengeorge | 309 | 310 | ||||||||
KeepingItLight | 992 | |||||||||
Keepitsharp | 175 | |||||||||
Keisari | 1211 | 1212 | ||||||||
keithd | 753 | |||||||||
KenE | 355 | |||||||||
Kenjii | 385 | |||||||||
Kentuckywindage | 797 | 872 | ||||||||
Kepling | 333 | |||||||||
KFulton | 1331 | |||||||||
khas | 628 | |||||||||
Khuan | 1148 | |||||||||
KIKY | 1340 | |||||||||
Killforfood | 272 | 379 | ||||||||
Kindle | 698 | |||||||||
KingSmono | 578 | |||||||||
kiriba-ru | 525 | |||||||||
Kiukas | 640 | |||||||||
KiwiKane | 174 | |||||||||
Kkelleher | 99 | 100 | 101 | 102 | ||||||
Kloepper Knife Works | 194 | 195 | 196 | |||||||
knightstalker | 1219 | |||||||||
kntx | 1073 | 1116 | 1189 | |||||||
knudsengj | 1106 | |||||||||
Koaksijalac | 104 | |||||||||
Kodachrome40 | 170 | 1282 | ||||||||
KoekieMonster | 161 | |||||||||
kommessy | 108 | |||||||||
korpzgrinda | 1029 | 1133 | ||||||||
kotobuki | 799 | 1143 | 1144 | |||||||
koyotee | 276 | |||||||||
Kozy | 58 | 129 | ||||||||
krutone | 1298 | |||||||||
Kulumatic | 914 | |||||||||
Kurt_Norway | 593 | |||||||||
Kusie | 8 | 17 | ||||||||
KutKhemist | 123 | |||||||||
Kysumi | 925 | |||||||||
LAB | 259 | |||||||||
lachesis | 673 | |||||||||
lalomt | 1167 | |||||||||
Lamont56 | 808 | |||||||||
lamper | 727 | 1171 | ||||||||
lanceb1b | 884 | |||||||||
laststance | 972 | |||||||||
lawallac | 393 | 394 | ||||||||
Lazy-R-us | 25 | 900 | 1249 | 1250 | ||||||
Le_Zouave | 71 | |||||||||
leaftye | 694 | 1103 | 1183 | 1184 | ||||||
LEDtec | 823 | |||||||||
legan710 | 1088 | |||||||||
Legolas Jr. | 130 | |||||||||
leroycp | 236 | 266 | 450 | 451 | ||||||
Lexel | 696 | 1287 | ||||||||
Lfatman | 707 | |||||||||
Liber8 | 537 | |||||||||
lichtpfadfinder | 1292 | |||||||||
Light of Earendil | 700 | |||||||||
lightbulb | 281 | |||||||||
lightknot | 471 | 492 | 598 | |||||||
lightlight22 | 772 | 920 | 1040 | 1328 | ||||||
lightmog | 72 | |||||||||
lightx | 757 | |||||||||
Lilien | 978 | |||||||||
Lion42 | 246 | |||||||||
lionheart_2281 | 33 | |||||||||
litcrit | 871 | |||||||||
Litefighter | 1320 | 1334 | 1335 | |||||||
LloydV | 767 | |||||||||
Loneman | 510 | 903 | ||||||||
longmire | 1256 | |||||||||
Lopan | 1069 | |||||||||
lovetheguitar | 981 | |||||||||
Lowtech | 1042 | 1193 | ||||||||
ludolf | 348 | |||||||||
luisgcan | 1162 | |||||||||
Lumenmaster17 | 1145 | 1146 | 1147 | |||||||
Lumens Industry | 634 | |||||||||
lumiere | 231 | |||||||||
Lund1660 | 64 | 439 | ||||||||
luxlad | 831 | |||||||||
lyse99 | 1012 | |||||||||
Lyubo Yanev | 427 | 428 | 429 | 536 | ||||||
M4D M4X | 350 | |||||||||
M78 | 157 | 337 | 1007 | |||||||
MACS0647 | 313 | |||||||||
MAD TM26 | 656 | 657 | ||||||||
Magbrite | 584 | |||||||||
magnet | 302 | |||||||||
MagPap | 794 | |||||||||
Maiden666 | 92 | |||||||||
maildroid | 331 | |||||||||
Majoroverkill | 919 | |||||||||
malamask | 113 | |||||||||
mandala | 952 | 953 | ||||||||
manithree | 1255 | |||||||||
Manulous | 1270 | |||||||||
ManWithoutShadow | 1100 | 1299 | ||||||||
Mapache | 4 | |||||||||
markalike | 602 | |||||||||
Marothar | 1236 | |||||||||
marsalla | 475 | |||||||||
Martini | 82 | 726 | ||||||||
martook | 48 | |||||||||
martytown | 976 | |||||||||
Masejoer | 842 | |||||||||
Matchoo | 905 | |||||||||
matkovicha | 1185 | |||||||||
Matomoto | 1324 | |||||||||
mattlward | 16 | 34 | 214 | |||||||
MauiSon | 42 | 979 | ||||||||
maukka | 225 | 627 | ||||||||
Maxxsounds | 681 | |||||||||
MBuitendorp | 1210 | |||||||||
mcfarlie6996 | 964 | 965 | ||||||||
MCT | 162 | |||||||||
Mecallie | 1051 | |||||||||
MechEngVictor | 275 | |||||||||
Medvegy | 660 | |||||||||
Melven | 167 | |||||||||
meti | 470 | |||||||||
metz3006 | 843 | |||||||||
Meyer | 138 | |||||||||
MG | 353 | |||||||||
mhanlen | 77 | |||||||||
mi bill | 127 | |||||||||
Micael | 858 | |||||||||
Miguel_79 | 1114 | 1129 | ||||||||
Miguelintegral | 1175 | |||||||||
mikeyx | 622 | |||||||||
Mindaugass | 769 | 1081 | ||||||||
Minimoke | 30 | 975 | ||||||||
miswas | 760 | |||||||||
Mitko | 26 | 27 | ||||||||
mitrhandir | 1303 | |||||||||
mizjif | 714 | |||||||||
Mkduffer | 600 | |||||||||
mlodyulek | 1283 | |||||||||
moemin | 375 | |||||||||
MontyPyfon | 66 | |||||||||
moridin | 907 | |||||||||
Morpheus | 613 | |||||||||
MorpheusT1 | 762 | |||||||||
MortyDuck | 764 | |||||||||
MountainKing | 438 | 445 | ||||||||
MountainMan | 786 | 787 | ||||||||
mozart.f | 314 | |||||||||
Mr.Poppy | 192 | 267 | 1247 | 1308 | ||||||
Mr.Scott | 251 | 1077 | ||||||||
mrheosuper | 1110 | |||||||||
mrkelvin | 606 | |||||||||
MRsDNF | 325 | 326 | ||||||||
mrstealyourgains | 1014 | |||||||||
msg1285 | 173 | |||||||||
Mstevens113 | 114 | |||||||||
Mt.B | 392 | |||||||||
MtnDon | 158 | 498 | ||||||||
mud_muncher | 624 | |||||||||
mudguts | 680 | 716 | ||||||||
Muto | 20 | 242 | 689 | |||||||
mutts13 | 1343 | 1348 | ||||||||
muzzleblast? | 89 | |||||||||
mxlu | 396 | |||||||||
MyDangus | 1181 | |||||||||
myowin | 213 | 1235 | ||||||||
myst999 | 198 | 728 | 1266 | 1267 | ||||||
nanojack | 1036 | |||||||||
narin000 | 524 | |||||||||
Nathan42 | 946 | 987 | 1365 | |||||||
Navin_R_Johnson | 817 | |||||||||
neckbear | 935 | |||||||||
needmorlts | 911 | |||||||||
Neilyboy | 1307 | |||||||||
netprince | 176 | 378 | ||||||||
nexrace1 | 579 | |||||||||
nfetterly | 362 | 366 | ||||||||
Nguyen | 1277 | 1293 | ||||||||
nickdude | 591 | |||||||||
Nickke | 604 | |||||||||
Nicolaas | 857 | |||||||||
Nicolicous | 270 | |||||||||
Night Light | 1093 | |||||||||
NightLight | 369 | |||||||||
Nightshade | 574 | |||||||||
niktak11 | 782 | |||||||||
Nil | 959 | 960 | ||||||||
Nite Shadow | 1001 | |||||||||
Nitetime | 163 | |||||||||
nitrader0 | 1203 | |||||||||
nnmnu1 | 1349 | |||||||||
No Agenda | 431 | |||||||||
nofear87 | 382 | |||||||||
Noki | 573 | |||||||||
noob | 828 | 833 | 1025 | |||||||
Nord | 1170 | |||||||||
Nortson | 810 | |||||||||
novice1 | 338 | |||||||||
nqcken | 119 | 241 | ||||||||
nskn71 | 1136 | |||||||||
NuggetMcNugget | 166 | 332 | ||||||||
ObiWan-Kenobi | 422 | 423 | ||||||||
octav | 666 | |||||||||
OdorlessCurves | 529 | 530 | ||||||||
ohnonothimagain | 1357 | |||||||||
olivedrab | 658 | |||||||||
OrangePeel | 1275 | 1288 | ||||||||
orinjuse | 835 | |||||||||
Orionz23 | 1168 | |||||||||
osb40000 | 193 | |||||||||
OscarM | 1290 | |||||||||
Oswald3211 | 724 | |||||||||
oto | 888 | |||||||||
Ozythemandias | 625 | |||||||||
Pablogy | 441 | |||||||||
PabloVerde | 1037 | |||||||||
pacbough | 149 | |||||||||
papaslightsaber | 583 | 1125 | 1126 | |||||||
patchythepirate | 704 | 1364 | ||||||||
patmet | 1347 | |||||||||
patmurris | 55 | |||||||||
patmurris | 1355 | |||||||||
Paul321 | 139 | |||||||||
pawwright | 151 | |||||||||
PBWilson | 557 | 558 | ||||||||
peabody | 207 | |||||||||
Peetz | 311 | |||||||||
Pegaso | 122 | |||||||||
Peho | 112 | |||||||||
pepe2017 | 1305 | |||||||||
pepinfaxera | 1158 | |||||||||
perche | 1155 | |||||||||
peterlcole | 924 | |||||||||
peteybaby | 549 | |||||||||
petr9999 | 1137 | |||||||||
Petroleum Lantern Guy | 891 | |||||||||
Phoenix_FIN | 395 | |||||||||
Pidro | 465 | |||||||||
pieman7 | 670 | |||||||||
pirate joe 22 | 678 | 679 | 783 | 784 | ||||||
piyoman | 840 | |||||||||
plntigrado | 1153 | |||||||||
pommie | 54 | |||||||||
pook | 330 | |||||||||
pooptoast | 519 | |||||||||
powerfultorches | 569 | |||||||||
praveendk | 437 | |||||||||
presterjohn | 586 | 715 | ||||||||
Presumptuous | 653 | 654 | 655 | |||||||
Primal | 364 | |||||||||
prisma | 401 | |||||||||
Prometheus | 1149 | |||||||||
ProtaBLF | 419 | |||||||||
pscal | 376 | |||||||||
puccio1969 | 76 | |||||||||
Pukachi | 205 | |||||||||
pukoid | 868 | |||||||||
Pulsar13 | 288 | |||||||||
qandeel | 631 | 632 | ||||||||
R.D. | 974 | |||||||||
radb | 856 | |||||||||
rag | 283 | 298 | ||||||||
Ragsy | 499 | 1117 | ||||||||
raiko | 570 | |||||||||
rajun50 | 651 | |||||||||
Randolph | 212 | |||||||||
RapidLux | 1346 | 1360 | ||||||||
Rat_Racer | 999 | |||||||||
RaVeN | 160 | |||||||||
raynman | 706 | |||||||||
rdoc613 | 879 | |||||||||
red72vw | 521 | |||||||||
redrider706 | 1359 | |||||||||
regaia | 1008 | |||||||||
reliant_turbo | 710 | 850 | ||||||||
ReManG | 320 | |||||||||
reno | 1118 | |||||||||
retiro675 | 352 | 826 | ||||||||
rexdog | 442 | 515 | ||||||||
rfd673 | 747 | |||||||||
ricardon | 300 | |||||||||
Ricflair | 323 | |||||||||
Rick | 199 | |||||||||
rjorge | 708 | |||||||||
rmkline | 436 | |||||||||
Rob_K | 244 | |||||||||
robbobus | 233 | |||||||||
Roberrt777 | 185 | |||||||||
RobertB | 140 | |||||||||
RocketTomato | 766 | |||||||||
RockHugger | 1173 | |||||||||
Romey310 | 969 | 970 | ||||||||
RonMuller | 111 | |||||||||
Roter | 649 | |||||||||
RotorHead64 | 1284 | |||||||||
Rpdos | 1180 | |||||||||
Rska | 650 | |||||||||
Rsqweezy | 814 | |||||||||
rufrydr | 765 | |||||||||
Rufusbduck | 60 | |||||||||
Rxich | 866 | |||||||||
ryukin2000 | 1220 | |||||||||
sac02 | 645 | 908 | 1215 | 1216 | ||||||
saf99 | 755 | |||||||||
Saigon | 247 | |||||||||
SamHaLeKe | 485 | |||||||||
samis | 509 | |||||||||
samnavy | 73 | |||||||||
san san | 926 | 1130 | 1131 | |||||||
sandanbob | 532 | |||||||||
Sarge930 | 86 | |||||||||
Savydude | 1222 | |||||||||
SawMaster | 45 | |||||||||
saypat | 141 | |||||||||
sb56637 | 191 | |||||||||
scarnific | 566 | |||||||||
scdaf | 271 | 296 | ||||||||
Schkü | 614 | |||||||||
schlockproof | 612 | |||||||||
Sciencetists | 257 | |||||||||
SciFiFreak | 31 | |||||||||
Scooby | 582 | |||||||||
Scooter000 | 315 | |||||||||
scootypuffjr | 844 | |||||||||
Scorpia | 596 | |||||||||
scotlarock | 329 | 1085 | ||||||||
Scottland | 334 | |||||||||
Scotty | 746 | |||||||||
scs | 80 | |||||||||
sebastiang | 611 | |||||||||
SebaZ74 | 1239 | 1240 | ||||||||
SeenTheLight | 301 | 819 | ||||||||
SFB | 1109 | |||||||||
Sgtpev | 206 | |||||||||
Shadowcactus | 916 | |||||||||
Shadowfax | 341 | |||||||||
Sharpie | 354 | |||||||||
shimano3000 | 409 | |||||||||
shimey | 211 | |||||||||
shirnask | 61 | 733 | ||||||||
Shoe | 957 | |||||||||
shogan | 227 | |||||||||
Shur | 284 | |||||||||
SIGShooter | 368 | |||||||||
Silent_Star | 1190 | |||||||||
Silentcropduster | 667 | |||||||||
Simplelight | 961 | 962 | ||||||||
slackwolf | 885 | 886 | ||||||||
slackwolf 3rd | 1000 | |||||||||
Sledge | 980 | 985 | 986 | 1326 | ||||||
Sledgestone | 677 | 841 | ||||||||
slickpenguin | 643 | 854 | ||||||||
slimkango | 52 | 1207 | ||||||||
slow2go | 221 | 222 | 692 | 1139 | 1140 | 1141 | 1278 | 1279 | 1280 | |
smed1275 | 494 | |||||||||
Smittymojo | 768 | 1142 | ||||||||
SmokinH | 855 | |||||||||
Snoballz | 1031 | |||||||||
SoCalTiger | 1344 | |||||||||
sochi111 | 1032 | |||||||||
Sofa | 834 | |||||||||
sol | 291 | 292 | ||||||||
SolarLumen | 776 | |||||||||
solRNY | 1291 | |||||||||
somnambulism | 562 | |||||||||
Sonpham | 621 | |||||||||
southland | 142 | 143 | 144 | 145 | ||||||
sp5it | 94 | 1201 | ||||||||
spade413 | 1178 | |||||||||
sparkyDK | 1188 | |||||||||
specialk | 865 | |||||||||
Speed4goal | 413 | |||||||||
Speedsix | 1083 | |||||||||
spkzzz | 474 | 526 | ||||||||
Sprinkles | 279 | 778 | 901 | |||||||
srs2000 | 1187 | |||||||||
stanley-beamish | 107 | |||||||||
starcrazed | 1330 | |||||||||
stareye | 540 | |||||||||
staticx57 | 238 | |||||||||
steel_1024 | 709 | |||||||||
Steenbhg | 701 | 1205 | 1206 | 1268 | ||||||
steepdrop | 435 | 497 | ||||||||
Stephen Elliott | 1322 | |||||||||
stephenk | 269 | |||||||||
steve42 | 1016 | |||||||||
Stevejj | 1218 | |||||||||
SteveMidwest | 1289 | |||||||||
stevez32 | 822 | |||||||||
Stittville Ed | 85 | 998 | ||||||||
Stoneface | 758 | 1127 | ||||||||
strango | 96 | |||||||||
strayz | 505 | |||||||||
Streamer | 1246 | |||||||||
strmix | 676 | |||||||||
Subterrestrial | 1003 | |||||||||
Sukoi | 642 | 1010 | ||||||||
Sullysat | 418 | |||||||||
Suncoaster | 682 | |||||||||
Swennie | 895 | |||||||||
Syncmasterklop | 867 | |||||||||
syracuse | 349 | |||||||||
T-boon | 304 | |||||||||
T18 | 390 | 1257 | ||||||||
t3rminal | 1213 | |||||||||
tapir | 489 | |||||||||
tarver | 132 | 229 | ||||||||
Tarvos | 15 | |||||||||
tas69 | 380 | |||||||||
tatasal | 506 | |||||||||
teacher | 321 | 1134 | ||||||||
tebeve | 893 | |||||||||
techieman33 | 456 | |||||||||
Tecmo | 57 | |||||||||
tekwyzrd | 37 | |||||||||
tenohfive | 802 | |||||||||
Tete | 217 | |||||||||
Texas_Ace | 472 | 473 | ||||||||
The Burgh | 235 | |||||||||
The Grand Pooh-Bah | 1056 | 1057 | ||||||||
The Imp | 1242 | |||||||||
The Jinx | 522 | 699 | ||||||||
The Last Katun | 90 | |||||||||
The Miller | 1 | 2 | ||||||||
The_Driver | 1352 | |||||||||
thebaum | 585 | 807 | ||||||||
thecrc | 1177 | |||||||||
TheDude | 415 | |||||||||
TheHebrewHammer | 820 | 821 | ||||||||
TheJo | 1053 | |||||||||
TheMadcap | 97 | |||||||||
themaindude | 343 | 1094 | 1095 | |||||||
Theodore41 | 520 | |||||||||
theoldbill | 59 | |||||||||
TheOnlyDocc | 1135 | |||||||||
thijsco19 | 24 | |||||||||
tigris99 | 603 | |||||||||
timcodes | 1004 | 1017 | ||||||||
tindrum42 | 1059 | 1060 | ||||||||
tinowrx | 572 | |||||||||
Tixx | 371 | |||||||||
Tjhosan | 273 | |||||||||
Tjohn | 940 | 941 | 942 | 943 | 944 | |||||
Tmik | 287 | |||||||||
tmxod | 771 | |||||||||
Toccata | 1241 | |||||||||
tocirahl | 1362 | |||||||||
Tom E | 28 | 29 | 874 | 875 | 1223 | 1224 | ||||
Tom_182 | 695 | 780 | ||||||||
tomtaylor | 201 | |||||||||
tonylim | 43 | |||||||||
torchjunkie | 483 | 597 | ||||||||
toxiccoccyx | 1107 | |||||||||
ToyKeeper | 339 | |||||||||
tracerfire | 1317 | |||||||||
Trashman531 | 285 | |||||||||
Trasnodel | 729 | |||||||||
trevglas | 200 | |||||||||
trevize | 1165 | |||||||||
treysoucie | 789 | |||||||||
tristanxoxo | 240 | 1070 | ||||||||
troisanh | 91 | |||||||||
tronx | 674 | |||||||||
TRoPHeuS | 1152 | |||||||||
tru3s1lv3r | 39 | |||||||||
Tunerman | 1002 | |||||||||
tungkon | 1011 | |||||||||
TurboLion | 917 | |||||||||
turbopscl | 892 | |||||||||
turpulator | 1066 | 1363 | ||||||||
tzmxxhh | 21 | |||||||||
Ulric | 1198 | |||||||||
unit311 | 849 | |||||||||
unknown00101 | 548 | |||||||||
uqs1000 | 357 | |||||||||
Vagany | 647 | |||||||||
VaKo | 208 | |||||||||
Valdorg | 1202 | |||||||||
Van | 491 | |||||||||
Vanq86 | 1176 | |||||||||
vas | 133 | |||||||||
vasa_visost | 668 | |||||||||
Vattern | 18 | |||||||||
velocraig | 781 | |||||||||
vex_zg | 730 | |||||||||
Viamede | 948 | |||||||||
vinte77 | 414 | |||||||||
Volks1973 | 743 | |||||||||
vulpes | 539 | |||||||||
vwpieces | 881 | |||||||||
Wackyvegan | 156 | |||||||||
walty | 280 | |||||||||
WarHawk-AVG | 420 | 421 | ||||||||
warzi1975 | 528 | |||||||||
wattstar | 791 | |||||||||
websterjody | 996 | 1105 | ||||||||
weklund | 460 | |||||||||
Werner | 10 | |||||||||
WestBam | 1333 | |||||||||
westcoastwonders | 639 | |||||||||
whitecitadel | 1354 | |||||||||
Wieselflinkpro | 125 | 750 | 1079 | |||||||
Wildcat | 827 | 945 | ||||||||
wildmermaid | 1091 | |||||||||
Wildthing | 533 | |||||||||
willmo | 605 | 882 | ||||||||
WillyD | 303 | |||||||||
wilwok | 1076 | 1258 | ||||||||
Wineslurper | 554 | 555 | ||||||||
wisefire | 869 | |||||||||
wishiwereaskibum | 587 | |||||||||
wkhchin81 | 477 | |||||||||
Wojto | 1325 | |||||||||
WolfA | 69 | |||||||||
Wrathbringer27 | 41 | |||||||||
wunderhe | 115 | |||||||||
Wyre | 1269 | |||||||||
Xandre | 527 | |||||||||
xCentrino | 1314 | 1358 | ||||||||
xed888 | 305 | |||||||||
xelario | 773 | |||||||||
xjsnake | 36 | |||||||||
xray291 | 1192 | |||||||||
xtrosity | 723 | |||||||||
XXX-Man | 1197 | |||||||||
xzel87 | 665 | |||||||||
yasenf | 1006 | 1232 | 1233 | 1273 | 1274 | |||||
yclongthrow | 898 | 899 | ||||||||
YoFlash | 744 | |||||||||
Yokiamy | 1245 | |||||||||
Yourrid | 1101 | 1102 | ||||||||
zachary6227 | 1297 | |||||||||
zak.wilson | 182 | |||||||||
Zanders | 792 | |||||||||
zara | 180 | |||||||||
zelee | 22 | |||||||||
Zeratull | 703 | |||||||||
zeroair | 452 | |||||||||
zifzif | 1243 | |||||||||
zipelgas | 386 | |||||||||
zoysiamo | 1251 | |||||||||
ZozzV6 | 626 | |||||||||
×73rmin8r | 1063 |
1008 names
1360 lights
teacher: sparkyDK:On a more serious note, would it be possible to make a contact ring with raised areas in the right places so flat tops would work in it too ? Or am i overthinking again.
I think, flats tops will work with it now as is… sparkyDK. EDIT: If they are of proper length. :+1:
Sheriously, typical flat tops won’t work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA’s are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
:+1: …. My apologies sparky. I was thinking only of the GA’s and totally left out the test of the important facts about most all other flat tops. :person_facepalming:
Again… my apologies. I shall now put on the Dunce Hat & sit myself in the corner the remainder of the night for the incorrect info I gave… that in all likelyhood could create confusion…… :person_facepalming: … :cry:
Thank goodness Tom caught it quickly & posted the correct info.
I’ll edit my post also…
Thats okay and not the cells i got for the Q8, i have a set of Sony’s VTC6 and a Set of the brown LG’s ( HG2 ), both flat top style i will have to do something about.
I am not quite sure if the GAs will be good without something done to them, as they have no button the spring should squease them less tight, so maybe a thud on the end cap would make connection go.
Then again as i understand the Q8 that shouldent matter if one or two cells momentarily get disconnected.
Man i cant wait to get my hands on this thing, just ordered a new sleeping bag tonight, so aside for a pice of tarp i am ready to go play survivalist in the forests of Denmark.
Forrest’s that will not be so dark when i am around, with or without the Q8
Yay! An updated list. Thanks.
Doh, just read about the switch to 3 LEDs, thats not happening is it? I certainly would vote against it but looks like I didn’t check back and see it in time to vote…
Thanks Mr.Scott. :+1:
What are you referring to might I ask?
+1 to that. Your a life saver Mr. Scott……
Yeah thanks again so much Mr.Scott!!
Wit? No switch to 3 LEDs
Modders have made smart modifications to the tail PCB so the tail can be used to load cells
The Boss1 had nubs and a good alignment where other companies go for a rotating tail PCB
I’m number 340 on the list.
Someone from work wants a stupidly bright light and I think will qualify.
Can I be added again so I get another one?
Thanks
I am happy that the light is “finished”!
But now that the luminus sst-40 is out (with real low Vf) i find it really a pity that we did not go for the dualfoodprint leadboard. Is there a plan for a GB in place for a dual leadboard?
You can make a plan, I once had a quote from Kerui Electronics for about 8 euro per board, 50 minimum. The contact is Sundy and she is on BLF under the name “leo ou”. The boards that they make seem high quality (my N119 boards come from there).
