I’ve been watching this on and off since the beginning and it looks like it’s finally coming together into a really impressive light, well done and thanks to everyone involved in the design. Please put me down for one.
Do we have any rough timeframe on shipping the final version yet? Once approved are they ready to start manufacturing?
Tom_E
(Tom E)
June 5, 2017, 11:09pm
8347
Sheriously, typical flat tops won't work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA's are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
alternety
(alternety)
June 5, 2017, 11:26pm
8348
Or, if you simply use protected cells with the button already attached. As I recollect, somewhere above, it was determined that protected GAs with a good protection circuit did not seem to impact the light output vs an unprotected QA. Unless you are trying to squeeze every last lumen out of the light. But if this a concern, there are other batteries with higher amp capabilities you can blob and people can mod the light to try to make the whole power train act like a room temperature superconductor.
sparkyDK
(sparkyDK)
June 5, 2017, 11:32pm
8349
yeah i figured it would take some figuring out where the drum stop to make sure the batteries land on a “hill” on the contact ring.
But with design ( not the Q8 ) then i am sure they could figure it out and so the resulting flashlight could use any battery.
I am fully aware this are a done deal for the Q8 and that’s just fine i will just do something to the flat tops i have gotten for it.
But in future flashlights ( not least multi cell like the Q8 ) it would be nice if they would work with any type of the particular cells its build for.
But i have been wondering even if the “hills” was smooth for the battery’s to climb easy, the design of flattops and their wrapping might suffer damage over time as the batteries would have to go up and over those “hills” several times before they land in the final resting place.
Also i have been thinking if you should lathe those hills in the contact ring, or you could make do with just punching dents into the ring.
sparkyDK
(sparkyDK)
June 5, 2017, 11:45pm
8350
Now i am thinking ( i know i should be sleeping now but my brain will just not allow for that it seem )
How about if the 4 batteries in a light like the Q8 was staggered in a drum around a central pillar onto which you then screw on the end cap ?
This way the batteries should be stationary when the flashlight are put together, a bonus might be you can use bigger O-rings where the battery “drum” seal onto the LED end and the tail cap end, making for a bigger chance of a waterproof light and using larger more forgiving O-rings.
Off course this design will mean that the battery drum will just be held on the LED end with the friction of the O-ring when the end cap are unscrewed for battery change.
Holy sh, ee now i better stop cuz now i have tail cap contact ideas too, i better go for a drive and get me some sugar water to get the creative juices going again.
sparkyDK, this is an already-solved issue which came up just a few pages ago. It simply requires a different design:
A few people at BLF have done it. The trick is to lock the battery tube in place and unscrew only the very tail end of the light, with posts built in to keep the rotation correct. For example:
[image]
The Q8 will not use this method though; it uses a SRK style ring instead. So… make sure the positive terminal is higher than the cell wrapper.
Mr.Scott
(Mr.Scott)
June 6, 2017, 2:21am
8352
The Q8 list (from post #1) sorted alphabetically .
(As of post #8341)
2 DOGS
186
264
641
2Ace
165
1119
5ar
697
7pot
982
a12luke
932
a_idiot
740
Aardvark Spleen
253
402
403
Abe87
876
Abqjohnny
51
1169
abril
50
adirondackdestroyer
545
adrianlights
255
AEDe
923
Ag76
1345
aggillator
458
aginthelaw
278
Agiri
110
aim120
430
AirBreaker
155
akhyar
387
akoposilester
56
1111
1112
akovia
937
albertopnp
365
Alcius
105
alejandrov
523
alex64
1159
AlexGT
495
Alkpwn77
204
allthumbs
218
alphazeta
335
alternety
564
565
Alux
702
amplificus
904
983
984
Andmiller
1064
1065
andrewmac
407
Andybibbville
147
Andyman?
13
Angel Martínez
128
ant0
1195
Antenne
801
Anthon
568
antiparanoico
32
AppA
1208
aprendiz
1160
1261
apt323
47
544
archi
1157
archimedes
67
aremihc
910
ARMS.AARON
1089
ARsee
1228
1229
Arufonsi
921
aslpg
398
asnidi2
1327
asot
690
Astromanic
424
AsylumSweep
863
atbglenn
567
Atom00
358
359
Autoclave
1099
Awdtsi
1221
Awkward Stretch
619
AwkwardPause
464
b1i1l1l1y1
1052
B42
685
686
1019
1020
BackpackNY
571
1084
bakalakos
202
balazs1956
1341
baldo21
260
261
Bam35
1039
bamawthu
599
banker
1013
basslovin808
446
Bastarrdo
117
Batch1
293
344
battletross
809
bawilson2
500
501
Bc412
5
bd52
399
BDM
1018
BDWrabbit
1244
BeardedRaleigh
662
bella-headlight
49
411
877
Bernard
232
Bevo
1086
bhuge00
1049
bigpix
84
bigrick
754
bikedave99
1174
bikenber73
14
Bill 63
752
1296
Bill_tong
896
Billcheese5
949
bionictony
1338
bkling
1067
BlackList
1350
bladesmith3
607
BLFD80
933
BlindingL5s
312
blinker
1306
1353
blinky
1209
blueb8llz
70
553
1120
1121
1122
1123
Bluzie
785
bmaddison
248
Boaz
391
BobbyMK
462
bobdotorg
1271
1272
bobofire
1313
Bogdan
370
371
bogdanr
466
Bohemian
775
bonfire
412
Bong lick
763
1075
Bonham
262
borealis
1098
BorisBar
575
1238
Boro
360
361
bossf350
803
Box
671
Brettg4215
864
Brian Metcalfe
318
319
374
BrianK
447
560
1356
BrianTheJay
950
brightlights
243
brjones
504
brno602
913
brted
249
Bruno28
513
BT100
1087
1138
Bungle88
610
Buzzy243
1179
bwl123
870
cabfrank
443
988
Caleb
203
547
Caleb-v
444
Calmaja
35
Cano
661
1151
Captainvideo
1302
caramba
748
carmantl
345
346
casi29061965
467
490
cavorite
1028
Cawi
1276
cbrake10
749
cclight
897
cdjaney
825
Chadvone
63
693
Charga
124
charles lin
1124
CheapThrills
469
cheesecheeks
816
ChibiM
1310
1321
Chicken Drumstick
131
chinooker
1260
chooma
210
351
chrisc
741
742
churchilllafemme
1230
CircaM
894
Cjlee89
951
cjoe7
146
CJW
367
clagged
991
clange50
479
480
clinicdoc
1226
Cliwilnew
795
cloggy
404
cmflippen
83
cnrffl1
577
1113
cocoschnauzer
363
contigo
1351
Coolerness
664
coolriku
517
Corzy
308
Couchmaster
245
551
552
cpd800t
406
CrashOne
372
377
Crazyeddie
98
137
487
Creepo
909
cristhemuso
388
crx88ia
683
cujo255
1191
cwb
134
cypher1024
973
cypherz
250
Cythras
956
D10ten
608
Dadpool
1161
dafarui
1339
daninho
468
DarkerInSol
615
616
617
618
darkpenguin
718
719
735
736
737
738
739
860
861
862
darol
798
darrenm
1054
1055
darrylo
507
DarthTader
830
datiLED
761
dave101
1041
DavidEF?
7
davidkappelt
1026
davidvns
1128
davos
1062
DB Custom
713
722
997
dbesselt
1156
DBSAR
136
169
1281
DBSS
516
779
deathless
518
Deep skull
977
DeJaVu
669
dekozn
800
Dennis
934
dentillozie
488
Dep668
687
688
derfyled
1237
derpilgerer
630
Desmo
805
devdvr
486
dezoe
1186
dhsvcs
265
1336
1337
dicksog
559
digitaltc
1323
Dimking
425
Dirt
815
Dirty_Pierre
1045
DiscoJoe
1254
djburkes
188
878
Djozz
3
1115
1286
dmbaty
1294
Dobtruckers
1058
DOCFAR
595
Docp723
347
433
434
Doctawho
440
dodo
88
274
dogany
813
Dogsrule
508
donpachi
1252
dotBLF
968
doubleone44
887
downlinx
74
316
doxerino
1304
Dr Forinor
873
Dradge
1248
Dralf
1015
Dregs
172
DrHook59
883
driveX
659
DrJones
75
DT101
152
dudunphy
389
Duke
381
dumptruck
971
Dusty
327
328
Dutcheee
68
322
duvallite
889
dw911
478
Dwantink
135
e10sno
405
1318
1319
Easyrr
6
eb1888
837
838
839
ebosh
777
ediaz
906
eebowler
774
Eggun
1104
1312
egrep
594
Eivwer
171
electricjelly
237
256
ElginAgain
1204
emarkd
109
embee
511
Enelooper
417
engber
947
ERDOS
1150
Erethryn
1259
erikk365
648
Esskay
995
Etex
829
euphxenos
408
everydaysurvivalgear
103
Evilc
65
EyeballFryer
189
Fadetoblack
1295
fantomR
636
Far Thrower
148
197
Farmboy24
1234
Farns
277
Fatlight
663
fatsteve0
1361
FBsLights
790
fcrespi
1262
fed893
307
fedcas
902
feralcomprehension
1194
1311
finges
561
fireblade893
209
firedome
324
711
Firelight2
397
fishlite5
1046
fixed it
78
1097
fixvid
1264
Flash Voyager
652
flashination
87
FlashMax
1225
Flashy Mike
239
410
448
449
Flifish48
806
1096
Flintrock
629
fluffman86
958
FmC
1182
fonfan
234
1023
1024
fonLED
725
Ford Prefect
1068
Foston Pete
453
454
644
foton
1030
Fozzy-SP
317
Frank A.
1172
Frankie Baby
342
Franz
788
Freddy61069
282
Fredylee
223
1329
FreeMagenta
1050
freeme
514
Fritz t. Cat
484
Funzel67
990
fuzun
1074
fyesilova
535
g60
290
g_sintornillos
126
gamezawy
38
336
gangstead
53
922
garrybunk
254
gboss
832
gds95
1199
gedasd
1309
geepaw
1038
gehrmo
289
geo1952
455
457
ger-slash
416
Gerrh
531
1163
1164
1285
Gerrit
106
getbully
609
1263
Gilatabar
638
giorgoskok
306
493
1092
GIR
804
818
gisewhcs
384
Gj
580
581
gleamer
432
GlinnDamar
1342
gnatx
588
824
goatfarmer
770
GoldenBatt
383
589
590
gorb507
811
812
goshdogit
11
12
40
120
121
543
556
928
gpapa693
79
gravelmonkey
1027
green_comet
601
GreenShrike
190
gregor
215
GTsuperheros
179
Gtt980
936
guerrilla154
1316
Guggga
538
GulfCoast
880
gungoat
44
Gunnerboy
252
967
Guns712
1300
1301
h2o
181
476
Hairy_Steve
340
hank
258
Hardware
1071
1200
Hauwexis
845
846
847
848
haxquiz
226
927
headburger
592
heatwaves
994
1265
hein11ag
183
Herb Tarlek
931
Hestbech
994
995
hexcode
503
672
Hezekiah
286
759
hideehoo
859
HighCaliber
177
178
hmihaylov
502
Hobo
220
hunter1
116
720
721
hurleyy
993
I_like_lamb
915
Ian2381
150
igeigeige
890
IH8MYX
546
ii_pennies
481
ikaruz_500
989
Illumenated
426
illusioned
954
Ilmatic
1253
1332
ilovejesuschrist
294
295
ImA4Wheelr
19
ISO
705
734
929
930
iwandutchy
1047
J-Dub74
461
J_R_J
675
jack-bkk
356
jacktheclipper
1108
Jailbrake
1034
1090
JakeDjanitor
46
Jalben
187
jama
635
Jambo
912
james y
1043
1044
javipiloto
1154
jaynick
1048
JayT
62
Jayzed
1214
jb1
224
jdunlap27284
164
jealous57
81
Jensa41
731
732
Jerommel
637
jerrod
512
jescereal
228
Jesjes
153
154
jfalk1
918
jhalb
297
jhullin
159
751
jingleberry
1022
Jinx
93
jkbam
550
jmoots
268
jmpaul320
95
299
jmwhite151
482
851
852
853
Joat
184
JockRobbins
717
Joe Darkness
620
joe1512
534
joeangi
756
joechina
633
Joey Adams
1021
1132
John-Galt
463
Johnhywash1
966
johnnydoe
1227
JohnnyMac
496
johnpc
955
johny723
1082
Jonandreadolan
1072
JonnyC
576
JordanZHP
1078
1196
josephqool
1061
jpcuba
684
JPLight
23
646
JPM3
263
264
JS721
216
jsmn4vu
793
Jtm94
1035
Juanesdan
118
juaquin
219
Juggeli
745
jurasik1
1231
justanotherguy
541
712
1080
Jvrthp321
691
jycheang
1009
k-wong
542
1005
Kafar
9
kahvitahra
796
Kalchev
400
kali stupa
1217
Kalihi
836
KawiBoy1428
230
kaybi
1033
Kazik
1315
kbro
168
keengeorge
309
310
KeepingItLight
992
Keepitsharp
175
Keisari
1211
1212
keithd
753
KenE
355
Kenjii
385
Kentuckywindage
797
872
Kepling
333
KFulton
1331
khas
628
Khuan
1148
KIKY
1340
Killforfood
272
379
Kindle
698
KingSmono
578
kiriba-ru
525
Kiukas
640
KiwiKane
174
Kkelleher
99
100
101
102
Kloepper Knife Works
194
195
196
knightstalker
1219
kntx
1073
1116
1189
knudsengj
1106
Koaksijalac
104
Kodachrome40
170
1282
KoekieMonster
161
kommessy
108
korpzgrinda
1029
1133
kotobuki
799
1143
1144
koyotee
276
Kozy
58
129
krutone
1298
Kulumatic
914
Kurt_Norway
593
Kusie
8
17
KutKhemist
123
Kysumi
925
LAB
259
lachesis
673
lalomt
1167
Lamont56
808
lamper
727
1171
lanceb1b
884
laststance
972
lawallac
393
394
Lazy-R-us
25
900
1249
1250
Le_Zouave
71
leaftye
694
1103
1183
1184
LEDtec
823
legan710
1088
Legolas Jr.
130
leroycp
236
266
450
451
Lexel
696
1287
Lfatman
707
Liber8
537
lichtpfadfinder
1292
Light of Earendil
700
lightbulb
281
lightknot
471
492
598
lightlight22
772
920
1040
1328
lightmog
72
lightx
757
Lilien
978
Lion42
246
lionheart_2281
33
litcrit
871
Litefighter
1320
1334
1335
LloydV
767
Loneman
510
903
longmire
1256
Lopan
1069
lovetheguitar
981
Lowtech
1042
1193
ludolf
348
luisgcan
1162
Lumenmaster17
1145
1146
1147
Lumens Industry
634
lumiere
231
Lund1660
64
439
luxlad
831
lyse99
1012
Lyubo Yanev
427
428
429
536
M4D M4X
350
M78
157
337
1007
MACS0647
313
MAD TM26
656
657
Magbrite
584
magnet
302
MagPap
794
Maiden666
92
maildroid
331
Majoroverkill
919
malamask
113
mandala
952
953
manithree
1255
Manulous
1270
ManWithoutShadow
1100
1299
Mapache
4
markalike
602
Marothar
1236
marsalla
475
Martini
82
726
martook
48
martytown
976
Masejoer
842
Matchoo
905
matkovicha
1185
Matomoto
1324
mattlward
16
34
214
MauiSon
42
979
maukka
225
627
Maxxsounds
681
MBuitendorp
1210
mcfarlie6996
964
965
MCT
162
Mecallie
1051
MechEngVictor
275
Medvegy
660
Melven
167
meti
470
metz3006
843
Meyer
138
MG
353
mhanlen
77
mi bill
127
Micael
858
Miguel_79
1114
1129
Miguelintegral
1175
mikeyx
622
Mindaugass
769
1081
Minimoke
30
975
miswas
760
Mitko
26
27
mitrhandir
1303
mizjif
714
Mkduffer
600
mlodyulek
1283
moemin
375
MontyPyfon
66
moridin
907
Morpheus
613
MorpheusT1
762
MortyDuck
764
MountainKing
438
445
MountainMan
786
787
mozart.f
314
Mr.Poppy
192
267
1247
1308
Mr.Scott
251
1077
mrheosuper
1110
mrkelvin
606
MRsDNF
325
326
mrstealyourgains
1014
msg1285
173
Mstevens113
114
Mt.B
392
MtnDon
158
498
mud_muncher
624
mudguts
680
716
Muto
20
242
689
mutts13
1343
1348
muzzleblast?
89
mxlu
396
MyDangus
1181
myowin
213
1235
myst999
198
728
1266
1267
nanojack
1036
narin000
524
Nathan42
946
987
1365
Navin_R_Johnson
817
neckbear
935
needmorlts
911
Neilyboy
1307
netprince
176
378
nexrace1
579
nfetterly
362
366
Nguyen
1277
1293
nickdude
591
Nickke
604
Nicolaas
857
Nicolicous
270
Night Light
1093
NightLight
369
Nightshade
574
niktak11
782
Nil
959
960
Nite Shadow
1001
Nitetime
163
nitrader0
1203
nnmnu1
1349
No Agenda
431
nofear87
382
Noki
573
noob
828
833
1025
Nord
1170
Nortson
810
novice1
338
nqcken
119
241
nskn71
1136
NuggetMcNugget
166
332
ObiWan-Kenobi
422
423
octav
666
OdorlessCurves
529
530
ohnonothimagain
1357
olivedrab
658
OrangePeel
1275
1288
orinjuse
835
Orionz23
1168
osb40000
193
OscarM
1290
Oswald3211
724
oto
888
Ozythemandias
625
Pablogy
441
PabloVerde
1037
pacbough
149
papaslightsaber
583
1125
1126
patchythepirate
704
1364
patmet
1347
patmurris
55
patmurris
1355
Paul321
139
pawwright
151
PBWilson
557
558
peabody
207
Peetz
311
Pegaso
122
Peho
112
pepe2017
1305
pepinfaxera
1158
perche
1155
peterlcole
924
peteybaby
549
petr9999
1137
Petroleum Lantern Guy
891
Phoenix_FIN
395
Pidro
465
pieman7
670
pirate joe 22
678
679
783
784
piyoman
840
plntigrado
1153
pommie
54
pook
330
pooptoast
519
powerfultorches
569
praveendk
437
presterjohn
586
715
Presumptuous
653
654
655
Primal
364
prisma
401
Prometheus
1149
ProtaBLF
419
pscal
376
puccio1969
76
Pukachi
205
pukoid
868
Pulsar13
288
qandeel
631
632
R.D.
974
radb
856
rag
283
298
Ragsy
499
1117
raiko
570
rajun50
651
Randolph
212
RapidLux
1346
1360
Rat_Racer
999
RaVeN
160
raynman
706
rdoc613
879
red72vw
521
redrider706
1359
regaia
1008
reliant_turbo
710
850
ReManG
320
reno
1118
retiro675
352
826
rexdog
442
515
rfd673
747
ricardon
300
Ricflair
323
Rick
199
rjorge
708
rmkline
436
Rob_K
244
robbobus
233
Roberrt777
185
RobertB
140
RocketTomato
766
RockHugger
1173
Romey310
969
970
RonMuller
111
Roter
649
RotorHead64
1284
Rpdos
1180
Rska
650
Rsqweezy
814
rufrydr
765
Rufusbduck
60
Rxich
866
ryukin2000
1220
sac02
645
908
1215
1216
saf99
755
Saigon
247
SamHaLeKe
485
samis
509
samnavy
73
san san
926
1130
1131
sandanbob
532
Sarge930
86
Savydude
1222
SawMaster
45
saypat
141
sb56637
191
scarnific
566
scdaf
271
296
Schkü
614
schlockproof
612
Sciencetists
257
SciFiFreak
31
Scooby
582
Scooter000
315
scootypuffjr
844
Scorpia
596
scotlarock
329
1085
Scottland
334
Scotty
746
scs
80
sebastiang
611
SebaZ74
1239
1240
SeenTheLight
301
819
SFB
1109
Sgtpev
206
Shadowcactus
916
Shadowfax
341
Sharpie
354
shimano3000
409
shimey
211
shirnask
61
733
Shoe
957
shogan
227
Shur
284
SIGShooter
368
Silent_Star
1190
Silentcropduster
667
Simplelight
961
962
slackwolf
885
886
slackwolf 3rd
1000
Sledge
980
985
986
1326
Sledgestone
677
841
slickpenguin
643
854
slimkango
52
1207
slow2go
221
222
692
1139
1140
1141
1278
1279
1280
smed1275
494
Smittymojo
768
1142
SmokinH
855
Snoballz
1031
SoCalTiger
1344
sochi111
1032
Sofa
834
sol
291
292
SolarLumen
776
solRNY
1291
somnambulism
562
Sonpham
621
southland
142
143
144
145
sp5it
94
1201
spade413
1178
sparkyDK
1188
specialk
865
Speed4goal
413
Speedsix
1083
spkzzz
474
526
Sprinkles
279
778
901
srs2000
1187
stanley-beamish
107
starcrazed
1330
stareye
540
staticx57
238
steel_1024
709
Steenbhg
701
1205
1206
1268
steepdrop
435
497
Stephen Elliott
1322
stephenk
269
steve42
1016
Stevejj
1218
SteveMidwest
1289
stevez32
822
Stittville Ed
85
998
Stoneface
758
1127
strango
96
strayz
505
Streamer
1246
strmix
676
Subterrestrial
1003
Sukoi
642
1010
Sullysat
418
Suncoaster
682
Swennie
895
Syncmasterklop
867
syracuse
349
T-boon
304
T18
390
1257
t3rminal
1213
tapir
489
tarver
132
229
Tarvos
15
tas69
380
tatasal
506
teacher
321
1134
tebeve
893
techieman33
456
Tecmo
57
tekwyzrd
37
tenohfive
802
Tete
217
Texas_Ace
472
473
The Burgh
235
The Grand Pooh-Bah
1056
1057
The Imp
1242
The Jinx
522
699
The Last Katun
90
The Miller
1
2
The_Driver
1352
thebaum
585
807
thecrc
1177
TheDude
415
TheHebrewHammer
820
821
TheJo
1053
TheMadcap
97
themaindude
343
1094
1095
Theodore41
520
theoldbill
59
TheOnlyDocc
1135
thijsco19
24
tigris99
603
timcodes
1004
1017
tindrum42
1059
1060
tinowrx
572
Tixx
371
Tjhosan
273
Tjohn
940
941
942
943
944
Tmik
287
tmxod
771
Toccata
1241
tocirahl
1362
Tom E
28
29
874
875
1223
1224
Tom_182
695
780
tomtaylor
201
tonylim
43
torchjunkie
483
597
toxiccoccyx
1107
ToyKeeper
339
tracerfire
1317
Trashman531
285
Trasnodel
729
trevglas
200
trevize
1165
treysoucie
789
tristanxoxo
240
1070
troisanh
91
tronx
674
TRoPHeuS
1152
tru3s1lv3r
39
Tunerman
1002
tungkon
1011
TurboLion
917
turbopscl
892
turpulator
1066
1363
tzmxxhh
21
Ulric
1198
unit311
849
unknown00101
548
uqs1000
357
Vagany
647
VaKo
208
Valdorg
1202
Van
491
Vanq86
1176
vas
133
vasa_visost
668
Vattern
18
velocraig
781
vex_zg
730
Viamede
948
vinte77
414
Volks1973
743
vulpes
539
vwpieces
881
Wackyvegan
156
walty
280
WarHawk-AVG
420
421
warzi1975
528
wattstar
791
websterjody
996
1105
weklund
460
Werner
10
WestBam
1333
westcoastwonders
639
whitecitadel
1354
Wieselflinkpro
125
750
1079
Wildcat
827
945
wildmermaid
1091
Wildthing
533
willmo
605
882
WillyD
303
wilwok
1076
1258
Wineslurper
554
555
wisefire
869
wishiwereaskibum
587
wkhchin81
477
Wojto
1325
WolfA
69
Wrathbringer27
41
wunderhe
115
Wyre
1269
Xandre
527
xCentrino
1314
1358
xed888
305
xelario
773
xjsnake
36
xray291
1192
xtrosity
723
XXX-Man
1197
xzel87
665
yasenf
1006
1232
1233
1273
1274
yclongthrow
898
899
YoFlash
744
Yokiamy
1245
Yourrid
1101
1102
zachary6227
1297
zak.wilson
182
Zanders
792
zara
180
zelee
22
Zeratull
703
zeroair
452
zifzif
1243
zipelgas
386
zoysiamo
1251
ZozzV6
626
×73rmin8r
1063
1008 names
1360 lights
2 DOGS, 264, 2Ace, 5ar, 7pot, a12luke, a_idiot, Aardvark Spleen, Abe87, Abqjohnny
abril, adirondackdestroyer, adrianlights, AEDe, Ag76, aggillator, aginthelaw, Agiri, aim120, AirBreaker
akhyar, akoposilester, akovia, albertopnp, Alcius, alejandrov, alex64, AlexGT, Alkpwn77, allthumbs
alphazeta, alternety, Alux, amplificus, Andmiller, andrewmac, Andybibbville, Andyman?, Angel Martínez, ant0
Antenne, Anthon, antiparanoico, AppA, aprendiz, apt323, archi, archimedes, aremihc, ARMS.AARON
ARsee, Arufonsi, aslpg, asnidi2, asot, Astromanic, AsylumSweep, atbglenn, Atom00, Autoclave
Awdtsi, Awkward Stretch, AwkwardPause, b1i1l1l1y1, B42, BackpackNY, bakalakos, balazs1956, baldo21, Bam35
bamawthu, banker, basslovin808, Bastarrdo, Batch1, battletross, bawilson2, Bc412, bd52, BDM
BDWrabbit, BeardedRaleigh, bella-headlight, Bernard, Bevo, bhuge00, bigpix, bigrick, bikedave99, bikenber73
Bill 63, Bill_tong, Billcheese5, bionictony, bkling, BlackList, bladesmith3, BLFD80, BlindingL5s, blinker
blinky, blueb8llz, Bluzie, bmaddison, Boaz, BobbyMK, bobdotorg, bobofire, Bogdan, bogdanr
Bohemian, bonfire, Bong lick, Bonham, borealis, BorisBar, Boro, bossf350, Box, Brettg4215
Brian Metcalfe, BrianK, BrianTheJay, brightlights, brjones, brno602, brted, Bruno28, BT100, Bungle88
Buzzy243, bwl123, cabfrank, Caleb, Caleb-v, Calmaja, Cano, Captainvideo, caramba, carmantl
casi29061965, cavorite, Cawi, cbrake10, cclight, cdjaney, Chadvone, Charga, charles lin, CheapThrills
cheesecheeks, ChibiM, Chicken Drumstick, chinooker, chooma, chrisc, churchilllafemme, CircaM, Cjlee89, cjoe7
CJW, clagged, clange50, clinicdoc, Cliwilnew, cloggy, cmflippen, cnrffl1, cocoschnauzer, contigo
Coolerness, coolriku, Corzy, Couchmaster, cpd800t, CrashOne, Crazyeddie, Creepo, cristhemuso, crx88ia
cujo255, cwb, cypher1024, cypherz, Cythras, D10ten, Dadpool, dafarui, daninho, DarkerInSol
darkpenguin, darol, darrenm, darrylo, DarthTader, datiLED, dave101, DavidEF?, davidkappelt, davidvns
davos, DB Custom, dbesselt, DBSAR, DBSS, deathless, Deep skull, DeJaVu, dekozn, Dennis
dentillozie, Dep668, derfyled, derpilgerer, Desmo, devdvr, dezoe, dhsvcs, dicksog, digitaltc
Dimking, Dirt, Dirty_Pierre, DiscoJoe, djburkes, Djozz, dmbaty, Dobtruckers, DOCFAR, Docp723
Doctawho, dodo, dogany, Dogsrule, donpachi, dotBLF, doubleone44, downlinx, doxerino, Dr Forinor
Dradge, Dralf, Dregs, DrHook59, driveX, DrJones, DT101, dudunphy, Duke, dumptruck
Dusty, Dutcheee, duvallite, dw911, Dwantink, e10sno, Easyrr, eb1888, ebosh, ediaz
eebowler, Eggun, egrep, Eivwer, electricjelly, ElginAgain, emarkd, embee, Enelooper, engber
ERDOS, Erethryn, erikk365, Esskay, Etex, euphxenos, everydaysurvivalgear, Evilc, EyeballFryer, Fadetoblack
fantomR, Far Thrower, Farmboy24, Farns, Fatlight, fatsteve0, FBsLights, fcrespi, fed893, fedcas
feralcomprehension, finges, fireblade893, firedome, Firelight2, fishlite5, fixed it, fixvid, Flash Voyager, flashination
FlashMax, Flashy Mike, Flifish48, Flintrock, fluffman86, FmC, fonfan, fonLED, Ford Prefect, Foston Pete
foton, Fozzy-SP, Frank A., Frankie Baby, Franz, Freddy61069, Fredylee, FreeMagenta, freeme, Fritz t. Cat
Funzel67, fuzun, fyesilova, g60, g_sintornillos, gamezawy, gangstead, garrybunk, gboss, gds95
gedasd, geepaw, gehrmo, geo1952, ger-slash, Gerrh, Gerrit, getbully, Gilatabar, giorgoskok
GIR, gisewhcs, Gj, gleamer, GlinnDamar, gnatx, goatfarmer, GoldenBatt, gorb507, goshdogit
gpapa693, gravelmonkey, green_comet, GreenShrike, gregor, GTsuperheros, Gtt980, guerrilla154, Guggga, GulfCoast
gungoat, Gunnerboy, Guns712, h2o, Hairy_Steve, hank, Hardware, Hauwexis, haxquiz, headburger
heatwaves, hein11ag, Herb Tarlek, Hestbech, hexcode, Hezekiah, hideehoo, HighCaliber, hmihaylov, Hobo
hunter1, hurleyy, I_like_lamb, Ian2381, igeigeige, IH8MYX, ii_pennies, ikaruz_500, Illumenated, illusioned
Ilmatic, ilovejesuschrist, ImA4Wheelr, ISO, iwandutchy, J-Dub74, J_R_J, jack-bkk, jacktheclipper, Jailbrake
JakeDjanitor, Jalben, jama, Jambo, james y, javipiloto, jaynick, JayT, Jayzed, jb1
jdunlap27284, jealous57, Jensa41, Jerommel, jerrod, jescereal, Jesjes, jfalk1, jhalb, jhullin
jingleberry, Jinx, jkbam, jmoots, jmpaul320, jmwhite151, Joat, JockRobbins, Joe Darkness, joe1512
joeangi, joechina, Joey Adams, John-Galt, Johnhywash1, johnnydoe, JohnnyMac, johnpc, johny723, Jonandreadolan
JonnyC, JordanZHP, josephqool, jpcuba, JPLight, JPM3, JS721, jsmn4vu, Jtm94, Juanesdan
juaquin, Juggeli, jurasik1, justanotherguy, Jvrthp321, jycheang, k-wong, Kafar, kahvitahra, Kalchev
kali stupa, Kalihi, KawiBoy1428, kaybi, Kazik, kbro, keengeorge, KeepingItLight, Keepitsharp, Keisari
keithd, KenE, Kenjii, Kentuckywindage, Kepling, KFulton, khas, Khuan, KIKY, Killforfood
Kindle, KingSmono, kiriba-ru, Kiukas, KiwiKane, Kkelleher, Kloepper Knife Works, knightstalker, kntx, knudsengj
Koaksijalac, Kodachrome40, KoekieMonster, kommessy, korpzgrinda, kotobuki, koyotee, Kozy, krutone, Kulumatic
Kurt_Norway, Kusie, KutKhemist, Kysumi, LAB, lachesis, lalomt, Lamont56, lamper, lanceb1b
laststance, lawallac, Lazy-R-us, Le_Zouave, leaftye, LEDtec, legan710, Legolas Jr., leroycp, Lexel
Lfatman, Liber8, lichtpfadfinder, Light of Earendil, lightbulb, lightknot, lightlight22, lightmog, lightx, Lilien
Lion42, lionheart_2281, litcrit, Litefighter, LloydV, Loneman, longmire, Lopan, lovetheguitar, Lowtech
ludolf, luisgcan, Lumenmaster17, Lumens Industry, lumiere, Lund1660, luxlad, lyse99, Lyubo Yanev, M4D M4X
M78, MACS0647, MAD TM26, Magbrite, magnet, MagPap, Maiden666, maildroid, Majoroverkill, malamask
mandala, manithree, Manulous, ManWithoutShadow, Mapache, markalike, Marothar, marsalla, Martini, martook
martytown, Masejoer, Matchoo, matkovicha, Matomoto, mattlward, MauiSon, maukka, Maxxsounds, MBuitendorp
mcfarlie6996, MCT, Mecallie, MechEngVictor, Medvegy, Melven, meti, metz3006, Meyer, MG
mhanlen, mi bill, Micael, Miguel_79, Miguelintegral, mikeyx, Mindaugass, Minimoke, miswas, Mitko
mitrhandir, mizjif, Mkduffer, mlodyulek, moemin, MontyPyfon, moridin, Morpheus, MorpheusT1, MortyDuck
MountainKing, MountainMan, mozart.f, Mr.Poppy, Mr.Scott, mrheosuper, mrkelvin, MRsDNF, mrstealyourgains, msg1285
Mstevens113, Mt.B, MtnDon, mud_muncher, mudguts, Muto, mutts13, muzzleblast?, mxlu, MyDangus
myowin, myst999, nanojack, narin000, Nathan42, Navin_R_Johnson, neckbear, needmorlts, Neilyboy, netprince
nexrace1, nfetterly, Nguyen, nickdude, Nickke, Nicolaas, Nicolicous, Night Light, NightLight, Nightshade
niktak11, Nil, Nite Shadow, Nitetime, nitrader0, nnmnu1, No Agenda, nofear87, Noki, noob
Nord, Nortson, novice1, nqcken, nskn71, NuggetMcNugget, ObiWan-Kenobi, octav, OdorlessCurves, ohnonothimagain
olivedrab, OrangePeel, orinjuse, Orionz23, osb40000, OscarM, Oswald3211, oto, Ozythemandias, Pablogy
PabloVerde, pacbough, papaslightsaber, patchythepirate, patmet, patmurris, patmurris , Paul321, pawwright, PBWilson
peabody, Peetz, Pegaso, Peho, pepe2017, pepinfaxera, perche, peterlcole, peteybaby, petr9999
Petroleum Lantern Guy, Phoenix_FIN, Pidro, pieman7, pirate joe 22, piyoman, plntigrado, pommie, pook, pooptoast
powerfultorches, praveendk, presterjohn, Presumptuous, Primal, prisma, Prometheus, ProtaBLF, pscal, puccio1969
Pukachi, pukoid, Pulsar13, qandeel, R.D., radb, rag, Ragsy, raiko, rajun50
Randolph, RapidLux, Rat_Racer, RaVeN, raynman, rdoc613, red72vw, redrider706, regaia, reliant_turbo
ReManG, reno, retiro675, rexdog, rfd673, ricardon, Ricflair, Rick, rjorge, rmkline
Rob_K, robbobus, Roberrt777, RobertB, RocketTomato, RockHugger, Romey310, RonMuller, Roter, RotorHead64
Rpdos, Rska, Rsqweezy, rufrydr, Rufusbduck, Rxich, ryukin2000, sac02, saf99, Saigon
SamHaLeKe, samis, samnavy, san san, sandanbob, Sarge930, Savydude, SawMaster, saypat, sb56637
scarnific, scdaf, Schkü, schlockproof, Sciencetists, SciFiFreak, Scooby, Scooter000, scootypuffjr, Scorpia
scotlarock, Scottland, Scotty, scs, sebastiang, SebaZ74, SeenTheLight, SFB, Sgtpev, Shadowcactus
Shadowfax, Sharpie, shimano3000, shimey, shirnask, Shoe, shogan, Shur, SIGShooter, Silent_Star
Silentcropduster, Simplelight, slackwolf, slackwolf 3rd, Sledge, Sledgestone, slickpenguin, slimkango, slow2go, smed1275
Smittymojo, SmokinH, Snoballz, SoCalTiger, sochi111, Sofa, sol, SolarLumen, solRNY, somnambulism
Sonpham, southland, sp5it, spade413, sparkyDK, specialk, Speed4goal, Speedsix, spkzzz, Sprinkles
srs2000, stanley-beamish, starcrazed, stareye, staticx57, steel_1024, Steenbhg, steepdrop, Stephen Elliott, stephenk
steve42, Stevejj, SteveMidwest, stevez32, Stittville Ed, Stoneface, strango, strayz, Streamer, strmix
Subterrestrial, Sukoi, Sullysat, Suncoaster, Swennie, Syncmasterklop, syracuse, T-boon, T18, t3rminal
tapir, tarver, Tarvos, tas69, tatasal, teacher, tebeve, techieman33, Tecmo, tekwyzrd
tenohfive, Tete, Texas_Ace, The Burgh, The Grand Pooh-Bah, The Imp, The Jinx, The Last Katun, The Miller, The_Driver
thebaum, thecrc, TheDude, TheHebrewHammer, TheJo, TheMadcap, themaindude, Theodore41, theoldbill, TheOnlyDocc
thijsco19, tigris99, timcodes, tindrum42, tinowrx, Tixx, Tjhosan, Tjohn, Tmik, tmxod
Toccata, tocirahl, Tom E, Tom_182, tomtaylor, tonylim, torchjunkie, toxiccoccyx, ToyKeeper, tracerfire
Trashman531, Trasnodel, trevglas, trevize, treysoucie, tristanxoxo, troisanh, tronx, TRoPHeuS, tru3s1lv3r
Tunerman, tungkon, TurboLion, turbopscl, turpulator, tzmxxhh, Ulric, unit311, unknown00101, uqs1000
Vagany, VaKo, Valdorg, Van, Vanq86, vas, vasa_visost, Vattern, velocraig, vex_zg
Viamede, vinte77, Volks1973, vulpes, vwpieces, Wackyvegan, walty, WarHawk-AVG, warzi1975, wattstar
websterjody, weklund, Werner, WestBam, westcoastwonders, whitecitadel, Wieselflinkpro, Wildcat, wildmermaid, Wildthing
willmo, WillyD, wilwok, Wineslurper, wisefire, wishiwereaskibum, wkhchin81, Wojto, WolfA, Wrathbringer27
wunderhe, Wyre, Xandre, xCentrino, xed888, xelario, xjsnake, xray291, xtrosity, XXX-Man
xzel87, yasenf, yclongthrow, YoFlash, Yokiamy, Yourrid, zachary6227, zak.wilson, Zanders, zara
zelee, Zeratull, zeroair, zifzif, zipelgas, zoysiamo, ZozzV6, ×73rmin8r,
teacher
(teacher)
June 6, 2017, 2:49am
8353
Sheriously, typical flat tops won’t work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA’s are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
:+1: …. My apologies sparky. I was thinking only of the GA’s and totally left out the test of the important facts about most all other flat tops. :person_facepalming:
Again… my apologies. I shall now put on the Dunce Hat & sit myself in the corner the remainder of the night for the incorrect info I gave… that in all likelyhood could create confusion…… :person_facepalming: … :cry:
Thank goodness Tom caught it quickly & posted the correct info.
I’ll edit my post also…
sparkyDK
(sparkyDK)
June 6, 2017, 3:30am
8354
Thats okay and not the cells i got for the Q8, i have a set of Sony’s VTC6 and a Set of the brown LG’s ( HG2 ), both flat top style i will have to do something about.
I am not quite sure if the GAs will be good without something done to them, as they have no button the spring should squease them less tight, so maybe a thud on the end cap would make connection go.
Then again as i understand the Q8 that shouldent matter if one or two cells momentarily get disconnected.
Man i cant wait to get my hands on this thing, just ordered a new sleeping bag tonight, so aside for a pice of tarp i am ready to go play survivalist in the forests of Denmark.
Forrest’s that will not be so dark when i am around, with or without the Q8
blinker
(blinker)
June 6, 2017, 5:28am
8355
Yay! An updated list. Thanks.
B42
(B42)
June 6, 2017, 6:07am
8356
Doh, just read about the switch to 3 LEDs, thats not happening is it? I certainly would vote against it but looks like I didn’t check back and see it in time to vote…
teacher
(teacher)
June 6, 2017, 6:43am
8358
What are you referring to might I ask?
teacher
(teacher)
June 6, 2017, 6:44am
8359
MRsDNF:
Thanks Mr.Scott. :+1:
+1 to that. Your a life saver Mr. Scott……
Yeah thanks again so much Mr.Scott!!
Wit? No switch to 3 LEDs
Modders have made smart modifications to the tail PCB so the tail can be used to load cells
The Boss1 had nubs and a good alignment where other companies go for a rotating tail PCB
I’m number 340 on the list.
Someone from work wants a stupidly bright light and I think will qualify.
Can I be added again so I get another one?
Thanks
I am happy that the light is “finished”!
But now that the luminus sst-40 is out (with real low Vf) i find it really a pity that we did not go for the dualfoodprint leadboard. Is there a plan for a GB in place for a dual leadboard?
djozz
(djozz)
June 6, 2017, 1:10pm
8363
You can make a plan, I once had a quote from Kerui Electronics for about 8 euro per board, 50 minimum. The contact is Sundy and she is on BLF under the name “leo ou”. The boards that they make seem high quality (my N119 boards come from there).
I do not have the funds to backup a project like that but i started a interest list to check if we could get enought people togeter to make it happen.
This is a first check if enough people are interested in a Q8 Dual footprint, quad LED copper DTP LEDboard.
The Board would be produced by Kerui Electronics for about 8 euro per board (50 pcs minimum order). It is only a interest list to check if we could get filled the minimum order. No commitments for now.
The Board is available at LED4Powers Online Store!
Board without LEDs = 3,97€ (https://led4power.com/product/l4p-blf-q8-40405050-38mm-dtp-direct-thermal-path-copper-mcpcb/ )
Board with 4 …
Hi, FNG here. Can you summarize the perceived advantages of what you're suggesting and outline any other changes that would be required?
Thanks!
