Hey lads what KCD numbers are people getting from there L2? I measured mine at 270KCD but i am not expert at measuring distance. I shined it across a bay i was fishing at and i could see the light on a white house which is 1km away. It light up the reflectors easily but i was surprised to see it shine on a house.
Its hard for me to gauge distance i live on the coast and we stick out further then most of sydney so we cop all the wind this leaves a lot of water particles in the air. I have noticed if i do beam shots at my girlfriends parents although its a lake its like 30min inland and there isn’t much wind and waves so all lights shine better there.
Follow up to my previous post of L6 with TA driver w/ narsil v1.4. By Lexel. Previously the led had a very low glow with side switch in the off position & tail on. See post #227. Lexel thought it was a leaky 7135 chip.
Now I’m seeing this, batteries are at 3.9 volt ea. Wondering if there is a way to measure 7135 chips to pinpoint the culprit.
Regarding the glowing emitters while off, I think I know the cause in my case. Your cause might still be the 7135. I’m not sure of an easy way to check for sure other than removing the 7135 chip and seeing if the glowing stops.
I used all 7 emitters/MCPCBs from my 7xXPL L2 build to make my 7xC8 build, using a (different) FET-only driver with e-switch. Now only the first parallel string of emitters glows while off. So I think there must be a high-resistance connection from one of the LED negatives to ground. In my L2 build I must have had this one LED in the second parallel string, which made all of the emitters glow. In my current build that one LED must be in the first string (from positive), making just the first string glow.
Wow, thats odd. Maybe Lexel should replace it? I know it’s only $25, but I’d be pretty upset. If he sent you a new one and you sent the old one back to him, he might be able to remove all components and reflow them back on (using new 7135 chips) then he could simply resale it to another person so he doesn’t lose much money.
Modded the H2-C driver with a R030 sense resistor to output 2.37A to the XHP35 HI E2 3A emitter. (see this post and thread for info on modding this driver) I filed down the edges to make it fit in the L2 driver space. I could not get the output to be stable at this level with 1s input, so I’m using 2x26350 cells. These cells are a bit too long for the L2 single tube so for now the battery tube is not completely threaded into the head, to make room for the cells.
I measured 250Kcd at 6m. I was comparing the L2 w/XHP35 to my fandyfire SP02 with dedomed XPL V6 1A, which does 243Kcd with a fully charged 30Q at about 20s. The SP02 has the same reflector as the HD2010 and Mitko’s BLF style thrower. Based on a ceiling bounce test the L2 has about 30% more output. The two beams look very similar. The L2 hotspot is very slightly larger with a larger corona.
So, a pretty good result, but not a huge performance increase over the dedomed XPL V6. The boost driver/XHP35 setup also uses quite a bit more power, about 60% more from the cell(s).
I took the H2-C driver and XHP35 out of the L2 and replaced it with a sliced XHP50 J4 running off 2x26350. It pulls around 6.5-7A from the 26350 cells and does about 2900 lumens at 15s and 157Kcd at 30s. There is a donut hole.
Edit: I’m pretty pleased with the short L2 and XHP50 combo. The beam is about the same size as an EE X6 with XPL HI now.
Modded my Convoy L6 with TA 30mm driver by Lexel.
This is my very first mod and I reused the spring and lead wires.
Thought I burnt a chip but luckily the flashlight is working.
Steep learning curve for me as its a first for me especially the soldering part.
Is the LD-29 the stock driver for the L2?
I know a little L2 driver history. When it first came out the L2 could only support a single cell driving a 3 volt emitter. Later on it was able to support one or two cells but the output is always 3v.
If you want to run a 6 volt emitter I’m pretty sure you’re going to have to swap drivers.
Modded an L2 with triple XPL. I’ve tried a few different emitter combinations in my shorty L2 host recently. I had a modded H2-C driver with XHP35 HI powered by 2x26350 that did around 2200 lumens and 250Kcd. This was a nice combination but I have a fandyfire SP02 with dedomed XPL V6 that had similar performance in a more compact package. Next I had a sliced XHP50 with FET driver and 2x26350 that did ~2900 lumens and 157Kcd. I feel like this combination suited the L2 well; the host has some nice mass and fins so I think a more powerful setup is needed with the L2.
Finally I modded it with this triple dedomed XPL V6 1A setup. The reflectors are from EE X6’s. Quite a bit of shaping (with a file) was needed to get them to fit.
It does ~3600 lumens at 15s and 152Kcd with a 30Q. The beam is pretty much like a EE X6, but appears a bit wider. I think this a result of the modifications to the reflectors. The outer part of the reflector contributes light to the center part of the beam, so removing some of this part takes some of the light from the center of the beam and moves it to the spill, resulting in a wider spill with some “flower petal” pattern.
Was hoping for a bit more beam lux, but it’s a nicer beam than the XHP50 and produces more light more efficiently. It pulls around 12A.
Nice one! I have a LOT of X6 reflectors sitting around doing nothing.
Got my first XHP-70.2 in today from Richard so of course, cervical collar or no, I swapped it into my ramping L6. It’s now pulling 16.48A (up from 11.91A) and making 7417.5 lumens at start on fresh charged LiitoKala light blue 5000mAh cells.
I don’t have a smooth reflector for it, cut the aperture of mine to fit the MT-G2 in my other L6, guess I’ll have to see about procuring another reflector or sanding down one of the OP ones I have extra.
Edit: Does 9073.5 lumens sound better? I forgot I had a small Omten switch in this one and I did not have it bypassed, so I put a Lg Omten switch with a 20ga bypass in it. Recharging cells again to see what a max possible lumens is.
Another item I discovered, my original black L6 tail cap spring, started to malfunction. Jumper wire came loose, but I also noticed the height of the spring was shorter than on my clear L6’s, plus the coiled spring wire diameter was smaller, as well. Cause light to not make contact with shorter IMR batteries. Replaced it.
Removing resistors from one circuit to use on another can be tricky, there is a metal “C” shaped attachment on each end of a ceramic resistor and this is what allows us to solder them on in the first place. Many times, one end of the metal will slip off the ceramic, leaving nothing to solder to. I like to slip a razor blade under one end while softening the solder and let the razor blade divide the resistor from the board, but only lifting by that minimal thickness. Then I go to the other side and, without lifting the loose side, soften the solder on this last side and lift with tweezers. Usually, but not always, works.
You should be able to test it with a DMM, make sure both ends are capable of taking a circuit. Looks like the bottom as shown may be missing that metal end cap, can’t be for sure though.
