Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
wooo just got done doing some plastic surgery on my VTC6’s as well , now they all have some nice size solder boobs. :partying_face:
Implants, if you prefer…
To be clear
That lamination, what is that?
The top cover with insulation properties or are the copper traces part of it?
Interested
Well , i thought something similar , but i’ll have to get max 2 or 3 for start :stuck_out_tongue:
In my case the copper traces are part of the delamination, which implies that the traces are less well cooled, which really could be an issue at 20A.
Hi, I’m interested in 1 BLF Q8, is it still possible to be added to the list?
Thanks in advance.
Yes welcome to BLF!
It must be onplants, as the addition go on the top of things and not inside.
Thanks :slight_smile:
So we’re going to need new mpcb’s? Now that we got a need for 1000+ pieces we might get a better price from other companies. If they offered $8 for 50 pieces how much would it be for 1000+?
We asked Thorfire to check with the maker of the MCPCBs and showed the pics.
When we hear back we post here ASAP
On mine the loose layer at the edge seems to be only the solder mask (but there is no electrical copper in that area). The interior ‘bubble’ closer to the black wire may include copper, but I am not sure.
AFAIK these boards are fabricated by laminating the various layers together. Between each set of layers there is a layer of adhesive and it seems this adhesive failed.
Random google:
THANK YOU DEL, I was wondering about that.
I generally lock out lights to get rid of the blue switch glow when I’m not carrying them around.
I assume that’s impossible to do with this light?
I don’t know if this is what you mean, but in the Narsil reference manual, in the advanced configuration section at the end of the manual, one has the option of disabling the button LED.
The manual, written by Tom I believe, is found here.
I was just typing this , it’s the “Locator Led” option
Hank, I don’t have a huge amount of experience with lights, but the Narsil programming is pretty fantastic. It gives the user the most control of any light that I’ve ever seen. Most programs for lights give far less control or no control at all.
I think you’ll be happy with what you can do with the UI.
Couple ways (green glow for the Q8 ) -
  • can do a lockout, and when it's locked out, the Ind. is OFF - I thought that made the most sense for most common usage (4X clicks in ramping to lockout, other way in mode sets)
  • can also use a quick shortcut to disable the Ind. LED when the light is OFF, in both ramping and mode set operation (ramping: press&hold til the light goes on in moon, quickly release)
  • can also disable it completely in the configuration settings
I knew this would be a wanted feature so put in a lot of support for it.
Tom E posted the below back in #7351. His numbers are a bit different from what DEL found, but there is certainly little danger of parasitic drain rendering the light useless in time of need…. even if the user is just halfway paying attention to their light every few years. :smiley::wink:
Only 10-60 years? :smiling_imp: :smiley: Maybe change a resister to get that number up a bit? (sorry, I couldn’t resist[er])
