Quote: “Highest capabilities-to-bulk small light
Hey, as some of you know, I’m into small lights that give a lot of light. … … …”
This is in may area of interest. We all know that we can not have lots of the following three things: runtime and power and compact size, at the same time. One must be sacrificed.
I am interested in most power per size, at the highest setting. I can always select a lower setting to get more runtime and less heat from the light.
My current somewhat smaller size/power choices are:
P60vn Quad XP-L HD 2 cell host Cryos Cu head, 4,300 lumens.
Manker MK34Vn XP-L, 7,650 lumens.
Nitecore TM06Svn 4 x XHP50.2, 9,500 lumens.
I am always looking to see what else there is that fits this bill that is a must-have.
The DQG Tiny 26650 3rd is in that spirit… Of course it’s bigger then a 18350 light but still very pocketable. No idea regarding the “thermally stable” thing though. Runtime is amazing - something like 8 hours at 300lm (medium) and 2:30h on high at 900lm.
Superb upgrade
It’s a shame there are no really good 18500 batteries. Though as HKJ predicts, they may show up soon.
Nevertheless that head is quite large and I have a feeling that a 24 mm triple would be only slightly less powerful with significantly smaller size. DQG Tiny is ~8% larger, yet it takes 18650.
How are PT16 thermals?
Interesting, thank you. I’ll surely wait for it, though I suspect that improved performance over DQG triple won’t beat the size difference for me. I’d love to be wrong though.
Just wait for it, the DQG lights are awesome but always have quality thingies going on, I’m expecting a bit better from intl-outdoor flashlights. The user interface and performance of the D4 is unknown for now, but if it turns out to be good too it will win me over, despite the 5mm length difference.
Today I learned of DQG Tiny 18650’s existence and I’m puzzled. Comparing both converted to 3*XP-L2, DQG has:
Is it possible to mod DQG Tiny to get even smaller size?
==not really
Are there compatible battery tubes that would make it even smaller?
==no, it doesn;t screw together like that… you would have to make it on a lathe or something, then add the polarity-protection if you wanted that
—i personally hate 18350 batteries
Are there other lights that might serve me better?
==manker U11 is decent and cheap, not quite as small as the dqg but has charging built in, possibly better heat dissipation
==the dqg tiny 18650, i have had 2 of them fail, one because of the switch, the 2nd some mystery fading out, then finally just stopped
==the heat dissipation is not very good in it
lowest light levels not really very low, like 65 lumens or 85
==you are not going to get 2000 lumen in something this small, even 1000 is pushing the heat dissipation limits
and battery life, and single-LED capacity, and battery max current draw
What do you mean, there are no really good 18500’s? There’s Panasonic NCR18500A 2040mAH if you want capacity with decent output, or Efest Purple 1000mAH if you want a higher output current. If you’re looking for both in one cell, then I think you’re right. There are none that I know of.
Thanks for the answer. Yesterday night, while searching for DQG Tiny I saw some thread mentioning that it is compatible with S2+ tubes. Thinking about it today, I thought it seemed weird and wanted to ask, but can’t find it. I guess that being tired, I confused something. That was probably another light.
As to the lowest mode - a triple mod will enable picking about any small enough driver, so this is not a problem.
2000 lm:
There are many DD S2+ triples out there and some of them 18350. I guess they easily exceed this output level, though obviously for a short time.
I find it weird, I’ve seen a few high-power mods and the lowest usable DD runtime for a small light (like 18350 S2+ ;)) is 30 seconds. A non-extreme DD triple in DQG Tiny 18650 - I read that in 10 seconds it’s too hot to touch. I wonder why is it so…
Together with a large battery (which sinks some heat too), can it really have 3x lower thermal capacity? Or maybe thermal transfer from the head to the rest of the light is so wrong? Is thermal transfer so good that it’s actually reasonably warm inside, but too hot outside? Or maybe there’s another reason?
Yes, that’s actually what I meant. Panasonic NCR18500A….well, I was too harsh really. If one’s current draw is low enough for this cell to handle - it is a good one.
Efest Purple - I can’t call it good. Aspire 18350 offers both higher current and higher capacity while being much smaller.
I have some of those new Aspire 18350’s on the way, so I will soon know how they compare. To date though, the 18500 Efest is top dog in a light in my own testing.
18350 light + 2 spares is about equal weight and energy to 18650 light w/out spares. Somewhat higher bulk. If you need less energy, 18350 wins. If more - 18650. For me less is going to happen far more often then more and furthermore I tend to always have a spare (In case I forgot to recharge. Happened once.) so 18350 just seems better.
