Today I learned of DQG Tiny 18650’s existence and I’m puzzled. Comparing both converted to 3*XP-L2, DQG has:
Is it possible to mod DQG Tiny to get even smaller size?
==not really
Are there compatible battery tubes that would make it even smaller?
==no, it doesn;t screw together like that… you would have to make it on a lathe or something, then add the polarity-protection if you wanted that
—i personally hate 18350 batteries
Are there other lights that might serve me better?
==manker U11 is decent and cheap, not quite as small as the dqg but has charging built in, possibly better heat dissipation
==the dqg tiny 18650, i have had 2 of them fail, one because of the switch, the 2nd some mystery fading out, then finally just stopped
==the heat dissipation is not very good in it
lowest light levels not really very low, like 65 lumens or 85
==you are not going to get 2000 lumen in something this small, even 1000 is pushing the heat dissipation limits
and battery life, and single-LED capacity, and battery max current draw
What do you mean, there are no really good 18500’s? There’s Panasonic NCR18500A 2040mAH if you want capacity with decent output, or Efest Purple 1000mAH if you want a higher output current. If you’re looking for both in one cell, then I think you’re right. There are none that I know of.
Thanks for the answer. Yesterday night, while searching for DQG Tiny I saw some thread mentioning that it is compatible with S2+ tubes. Thinking about it today, I thought it seemed weird and wanted to ask, but can’t find it. I guess that being tired, I confused something. That was probably another light.
As to the lowest mode - a triple mod will enable picking about any small enough driver, so this is not a problem.
2000 lm:
There are many DD S2+ triples out there and some of them 18350. I guess they easily exceed this output level, though obviously for a short time.
I find it weird, I’ve seen a few high-power mods and the lowest usable DD runtime for a small light (like 18350 S2+ ;)) is 30 seconds. A non-extreme DD triple in DQG Tiny 18650 - I read that in 10 seconds it’s too hot to touch. I wonder why is it so…
Together with a large battery (which sinks some heat too), can it really have 3x lower thermal capacity? Or maybe thermal transfer from the head to the rest of the light is so wrong? Is thermal transfer so good that it’s actually reasonably warm inside, but too hot outside? Or maybe there’s another reason?
Yes, that’s actually what I meant. Panasonic NCR18500A….well, I was too harsh really. If one’s current draw is low enough for this cell to handle - it is a good one.
Efest Purple - I can’t call it good. Aspire 18350 offers both higher current and higher capacity while being much smaller.
I have some of those new Aspire 18350’s on the way, so I will soon know how they compare. To date though, the 18500 Efest is top dog in a light in my own testing.
18350 light + 2 spares is about equal weight and energy to 18650 light w/out spares. Somewhat higher bulk. If you need less energy, 18350 wins. If more - 18650. For me less is going to happen far more often then more and furthermore I tend to always have a spare (In case I forgot to recharge. Happened once.) so 18350 just seems better.
The new Aspire 18350 cell should change a lot of things in small flashlights. With 1200mAh capacity as compared to 650mAh, and with high discharge capability as well, our small lights should see nice gains. I have some on the way to try out. My small Sinner 18350 triples will be quite happy!
The specific challenge to shorten the tube of a DQG Tiny will be tube thickness. It would be best to cut the tube then cut new threads. The human lathe method, where the two cut off components of the tube are re-joined with a slip joint, might not work here due to the thin walls of the tube.
Each of them adds information not available in others.
The last one contains the following image of the battery tube:
// Doesn’t show as image on the forum, you have to click, sorry…
Doesn’t look like ome could cut a new thread in the middle of a tube; the thread diameter seems just as large as the outer that of the knurling, if not larger.
Any suggestions?
BTW:
it seems that one could shorten the bezel by 1-2 mm…
DQG Tiny modded to triple is the most compact you can get in 18650 format. If you run it with a FET driver at max power peak output should be north of 2000 lumens.
However, the downside of this is the DQG has no heatsinking and its head is very small. I have very similar modded DQG Tiny III 18650 triple XPL and it gets HOT. So hot that I had to limit output to 3 amps and even then it can’t run at that power for long.
Some other ideas: 1. I modded a Sunwayman C10R with triple XPL and FET driver. As a host this was a nice choice since it has a decent head with some heatsink fins. The stock light runs on one CR123/16340, but I managed to fit an 18500 in mine. At peak output on a quality IMR 18500 it’s as bright as a FET driven 18650 triple, but is substantially smaller and lighter than even a DQG Tiny 18650 and takes longer to heat up to the point where it’s too hot to touch. This is quite an ambitious mod though… definitely not for first time modders.
2. How about a Jaxman E2L host with triple XPL HI or XPL2 a FET driver and 18500 battery tube. The downside of this setup is it is larger than a DQG Tiny 18650 and runs on a smaller battery. The upside is you can get much higher output because heatsinking is much better than the DQG. Also with the switch in the tail instead of the hot head, you can let the head get hotter while still being able to operate the light. This is also a relatively easy to assemble mod even for first-time modders.
It looks like Emisar D4 wouldn’s be far off these two when it comes to cooling while beating them nicely in size. Looks like a great light, can’t wait for it.
Personally I’m looking into entering a smaller class. DQG Tiny shortened to 18350, with a bezel shortened by 1 mm is 25% smaller. This triple would have lower volume than many 14500 lights despite 30% larger battery capacity and 3 LEDs.
Yep I surely expect it to be a Pareto-frontier in each configuration.
Still, in thermally-stable modes a DQG Tiny (shortened or not) is going to have only marginally worse runtime and not-so-marginally smaller size.
Once you exceed DQG’s thermal capabilities, but stay within D4’s, the latter will provide longer runtime at the same output.
At the end of the range, cooling doesn’t matter; thermal capacity does. Still, D4 is going to be better….though probably with a smaller difference….while still having not-so-marginally larger size.
So I consider DQG Tiny to use the bulk more efficiently than D4 in the boring, but so useful modes. At the high end - I wouldn’t call any of them better, just different.
As you mentioned before, quality is another matter.
This kind of thread has me interested. It makes me wonder what the capabilities of future lights will be. My first “nice” lights (a couple Fenix and 4Sevens) have been left in the dust, lumen-wise and that’s only with a handful of years going by.
When will keychain-sized lights (AA-sized) be able to hit 1000 lumens with respectable runtimes? Batteries continue to inch forward with more capacity and more efficient leds might arise.
Exciting times for sure. Let’s hope Elon Musk and his factory makes some more breakthroughs that will eventually trickle down into other products.
