Ok, sorry to be a bother. I haven’t followed every post here. I was trying to figure out if it’s possible I could get a driver for the Courui D01. I looked at the OP, but I’m not sure I’m understanding all the options and how they add up together. I guess it would be the 38.5mm driver, so that costs a bit extra for being a larger size. I want NarsilM if you’ve got it worked out, or whatever is the latest working version. I will do temp calibration myself. I want the standard amount of 7135’s on board. And it will be used with the normal 1S3P set-up of the Courui, with a ~3V LED, so I don’t need LDO and the LVP should be set for 1S operation with the standard values. I also don’t need a spring provided because I have springs of my own.
So, first, can I order one, or is it too late? Secondly, if it’s okay to order, what is the total price with shipping to the US? I tried to calculate it myself, but I’m not sure if I got it right. Please check and let me know.
Oh, just looked again at post #2 and it appears that three 38.5mm drivers have already been ordered. I don’t need 3x of those myself. If any more get made, I’d like to get one.
My drivers were delivered today. Odd how it took twice as long to travel from New York to Ohio as it took to travel from Germany and clear customs.
Tomorrow should be fun. Reflow the xhp70 to the 32mm star, reflow the star to the heat spreader/shim, reflow the brass ring to the driver, and assemble the Chimera. Forward clicky already installed as is the modified button cover. New photos in the Chimera thread tomorrow.
I’m really looking forward to seeing the results of the xhp50.2 and 22mm TA driver in the Convoy L5. I’m reasonably certain I’ll be pleased with the 3a tint and slightly larger hotspot (compared to the xml2 u2 3c it replaces). I prefer a 3d tint over 3c so the 3a should be just a bit cooler than a 3d.
Thanks again, Lexel!
edit: the Convoy L5 was my first ‘good’ flashlight (torch) and though it is no longer produced I know it has unrealized potential. With the TA driver it can be used with 2s 26350 in one battery tube or 2s 26650 with both tubes. The reflector finish produces a really nice beam without rings (xml2) and I feel it is a forgotten gem worth updating. I’ll admit I’m not overly fond of the large stainless bezel but with a few layers of foil to improve heat transfer from the pill it is very effective in shedding heat. If you have a Convoy L5 post your opinions or mods in the upcoming thread.
Dang, really sad I missed out on this. New here and just learning about the TA + Narsil. Looks like exactly what I need for an upcoming mod. I look forward to batch number 4, if you choose to do another!
