What did you mod today?
10496 posts / 0 new
zak.wilson
Last seen: 3 days 5 hours ago
ToyKeeper wrote:
It’s too bad Zebralights are so difficult to open or modify. I’d love to take the lens off and find out how it looks on a white cloth.
Left to right: SC62w, Convoy S3 (not AR), flashlightlens.com UCL, Thrunite TN12
Ceilingbounce – flashlight testing and runtime graphs for Android
ZozzV6
ZozzV6's picture
Continue the yesterday work.
The Clear S2+ got biscotti.
A black S2+ got biscotti also and lighted tailcap.
Found some pretty nice green LEDs. Mixed with warm whites.
And a red S2+ got pink lighted tailcap. I managed to fit the 6 LED ring board. The problem was the metal button touched the LEDs top.
Grinded down the edge.
And it fits.
Next to the Clear S2+
All done.
djozz
djozz's picture
Last seen: 1 hour 22 min ago
Nice set, Zozz! I like the pink leds, should get some Smile
ZozzV6
ZozzV6's picture
Thanks. I think it’s nice too. Also the green looks nice. More green in real life. Only the clear is mine. The other two is made by request. I also replaced the led board in the Clear to a PD68 design 6 led version. closer to the top so more light can come out.
ToyKeeper
ToyKeeper's picture
Last seen: 5 min 14 sec ago
Thanks. How did you manage to get the lens out?
zak.wilson
I pried the bezel out. I think the first tool I used was a razor knife, followed by small screwdrivers. The flashlight was already nonfunctional, but the lens and bezel were not damaged in this process and can be reinstalled. It might impact waterproofing some.
MyDangus
Last seen: 7 months 2 days ago
How difficult is it to install a lighted tailcap for a convoy s2 with a qlite driver from mtnelectronics? MY SKILLS are limited to soldering the wires to a mcpcb. Also Where do you get the hardware from? Thanks!
CRX
CRX's picture
Last seen: 5 months 1 day ago
Made a magnetic holder for the DQG UV lighter today to make it detachable like the 47’s atom triple
ZozzV6
ZozzV6's picture
If you using original qlite firmware with 3/5 modes you can buy the astrolux lighted tailcap switch board from banggood and a white silicone tailcap rubber. Then if your flashlight is older you find an aluminum spacer between switch and rubber button. You can drill a lot hole in it to give a path for the light or you can replace some clear acrilyc washer. No need any soldaring work. Just unscrew the switch retaining ring and replace the internals. The retaining ring is left threaded.
ZozzV6
ZozzV6's picture
I really got in lighted tailcaps Big Smile Done my wife’s green S2+ tailcap. It already has biscotti Fw so it needed a bleeder resistor on the driver.
DB Custom
DB Custom's picture
Last seen: 20 hours 45 min ago
I rebuilt my Ti X6 from Rey with XHP-50.2 emitters and a Khatod optic. Even with 22ga leads it pulls 17.22A from the pair of Efest 18350’s for 10,661 lumens! Big Smile
Edit:
This is the light, back when I first built it with the CUTE-3 optics…
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 3 weeks 3 days ago
Edit:
Holy Shit!
How long can you hold it in your hand, before it is too hot?
Battery runtime 3 Minutes?
ToyKeeper
ToyKeeper's picture
*blink*
Things like this are:
  • Why you’re known as Doctor Frankendale.
  • Why I have difficulty refraining from “colorful” language on BLF.
  • Why warning labels were invented.
  • Why I haven’t given up yet on humanity.
DB Custom
DB Custom's picture
I know TK, those numbers seem kinda low, am waiting on my Aspire “yellow jacket” 18350’s to arrive so I can really put the zing in this light. Big Smile
Edit: A breakdown of the levels with tail current readings…
0.05A for 29.12 Lumens
0.19A for 155.6
0.44A for 455.4
1.33A for 1283.4
5.46A for 3774.3
11.35A for 6865.5
17.22A for 10660.5
This, on a pair of dark purple metallic looking Efest 18350’s.
MyDangus
I got mine with guppy, would it still work?
ZozzV6
ZozzV6's picture
I haven’t tried with guppy. I don’t know. Maybe you will need to add a bleeder resistor to driver.
ZozzV6
ZozzV6's picture
I made something half flashlight related and half car related. I had a faulty SK68 with died driver and led. I gutted the internals and added an old XML T6 LED, and made a circuit for using as an ignition setting strobe light for my car. The circuit in the battery tube. And the potmeter is used to set the flash time. Maybe if flashing enough at a very short setting I will replace it with a resistor. The black connector connecting to car battery, and one cable wrap around the cilynder one ignition cable.
Pretty much the ugliest soldering I have ever done Big Smile
ToyKeeper
ToyKeeper's picture
Five words which shouldn’t go together.
ZozzV6
ZozzV6's picture
Why not?
ToyKeeper
ToyKeeper's picture
ZozzV6 wrote:
Why not?
Perhaps I don’t understand what it’s used for. This quote from comedian Steven Wright comes to mind:
“I replaced the headlights in my car with strobe lights, so it looks like I’m the only one moving.”
It doesn’t shine out at other people, does it?
ZozzV6
ZozzV6's picture
Aah! That strobe light is not for driving. It is for repairing and setting engine ignition advance. It has a signal from spark plug number one and the light flashes exactly when that plug fires so when I point it to crankshaft It seems to stand still when engine running. So with a mark on the pulley and some degree marks on engine block I can see the degree of ignition advance need. Wink
So I’m not going to blind anyone.
ToyKeeper
ToyKeeper's picture
That makes a lot more sense.
That really should have come to mind, considering how often I use motion-freezing strobes. I even helped someone time their engine once, using a similar spark strobe method, but the memory was lost in the mist of time.
So, yeah, that’s a great use for an old SK-68. Big Smile
khas
Last seen: 1 week 6 days ago
I always wanted to make a 18650 based XHP35 HI flashligtht so I bought this SecurityIng CREE XM-L2 from Ebay for $7.55 :
The original driver was a 20mm pressfit so I had to widen the pill to make room for the H2-C
XHP35 HI D2 3D CRI80+ on Noctigon
The quality of the SecurityIng is surprisingly good : aluminium reflector, nice anodizing with no flaws and a glass lens (not AR coated though)
giorgoskok
giorgoskok's picture
Last seen: 1 week 1 day ago
Nice mod khas ! Can you share the reflector diameter ?
Thanks
khas
The diameter is 34mm and the height is 24mm so it’s not a thrower, here is some pictures for size comparison :
SecurityIng (left) X7 (middle) C8S (right)
DB Custom
DB Custom's picture
Zozz, perhaps if you called it a timing light instead of a strobe light it would clear up that confusion?
Nice idea by the way…
giorgoskok
Eagle eye X6 reflector’s diameter is 30mm (true diameter , inside) so this must give some good throw too for it’s size too Smile
ZozzV6
ZozzV6's picture
Yes, that is the word I was looking for! This is not my native language so special tech words don’t come in to my mind.
CRX
CRX's picture
I changed the tail on the CRX Knucklehead to have a magnetic momentary switch, it now works as a normal twisty still but has the optional setting of activating when stuck to a ferrous surface, switches off again when placed on wood etc again and can also be locked out to prevent this Smile
Sivy
Last seen: 2 days 20 hours ago
Motion-freezing strobes are mentioned above, are there any flashlights available that could do this?
With a operator variable strobe speed?
I work on high speed machinery and we use slow motion cameras and now Iphones that have this facility to diagnose problems.
A motion freezing strobe maybe useful possibly being able to help see into places that bulky cameras cannot.
