Test/review of Ijoy INR26650 4200mAh (Black-Yellow)
18 posts / 0 new
HKJ
HKJ's picture
Last seen: 12 hours 58 min ago
DSC_8852
Official specifications:
  • Battery Capacity (Mfg Rated): 4200 mAh
  • Battery Chemistry: Li-Ion
  • Battery Feature: Rechargeable
  • Battery Form Factor: INR 26650
  • Battery Rated Voltage: 3.7 V
  • Product Weight: 91 g
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-info
A high current 26650 cell.
DSC_8850 DSC_8851
DSC_8853 DSC_8854
DSC_8855
DSC_8856
DSC_8857
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-Capacity
The cell has fairly constant capacity up to 15A and can handle 30A, the tracking between the cells is not perfect, but acceptable.
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-Temp-15.0
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-Temp-20.0
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-Temp-30.0
The cell can handle a 30A discharge without getting to hot.
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-CapacityTimeHours
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-Energy
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-PowerLoadTime
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-TripCurrent
Ijoy%20INR26650%204200mAh%20(Black-Yellow)-Charge
Conclusion
This cell live up to the rated capacity and has good high current performance.
Notes and links
Compare to 18650 and other batteries
wolfdog1226
wolfdog1226's picture
Last seen: 2 years 7 months ago
Thanks for the review.
It seems that this battery has less voltage sag than my Vappower starting at 15a.At 10a they are about even.
Until then my Vappower is actually better and has a bit more capacity.
The reviewer “Mooch” from the vape industry claims this is the best high drain out there. I guess for those who vape it probably is.
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
RobertB
RobertB's picture
Last seen: 2 days 21 hours ago
Yup, great cell with Plenty of head room for anything we do with flashlights. iJoy is a vape company which who these cells are targeted
Barkuti
Barkuti's picture
Last seen: 1 day 23 hours ago
Graph from Mooch's review of this IJOY cell.
Seems his review samples performed a bit better and more consistently, bearing also in mind he doesn't uses a 4 terminal battery holder/cradle.
Cheers
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
wolfdog1226
When Jon got these 3 months or so ago he stated that he was the only one in USA to have them at that time and they are LESS than half the price of what ijoy is selling them on their website!
https://liionwholesale.com/collections/batteries/products/ijoy-26650-bat...
        WOLFDOG
shadockan
shadockan's picture
Last seen: 3 weeks 1 day ago
Look at the Aspire 4300
It is better than Ijoy
Batteries manufacturer is YDL
The same as 18350-1300 , 18650-1800/2500
wolfdog1226
OK Thanks,,,,,,,,,,has someone tested the Aspire 26650 4300mAh?
I hope HKJ does so I can use the “Comparator
        WOLFDOG
Tom E
Tom E's picture
Last seen: 2 days 2 hours ago
wolfdog1226 wrote:
shadockan wrote:
Look at the Aspire 4300 It is better than Ijoy Batteries manufacturer is YDL The same as 18350-1300 , 18650-1800/2500
OK Thanks,,,,,,,,,,has someone tested the Aspire 26650 4300mAh? I hope HKJ does so I can use the "Comparator
I found this: http://www.aspirecig.com/products/battery-cells/2016/1102/383.html, but comparing 20A discharge curves, the Aspire is clearly worse if I'm reading this right.
What makes you say it's better?
wolfdog1226
Tom E wrote:
wolfdog1226 wrote:
OK Thanks,,,,,,,,,,has someone tested the Aspire 26650 4300mAh? I hope HKJ does so I can use the “Comparator
I found this: http://www.aspirecig.com/products/battery-cells/2016/1102/383.html, but comparing 20A discharge curves, the Aspire is clearly worse if I’m reading this right.
What makes you say it’s better?
Thanks for the link. The Aspire also looks worse to me. Especially in the beginning.
        WOLFDOG
shadockan
shadockan's picture
I found a battery test here and is one of the people I trust along with Henrik:
(He is in our company, too. Hello Torchy …)
Http://www.torchythebatteryboy.com/p/blog-page_27.html
Aspire looks better … I think …
Below the chart table, we see the duration of the discharges in seconds.
Tom E
Tom E's picture
Not sure how to read those charts - they are pulse tests, not continuous? Length of time is not so concerning - we care more about voltage at high drain, say 5A to 20A.
shadockan
shadockan's picture
Yes.
You’re right .
I mentioned only as a result of … a little superiority and more of a word that I am a vaper and more I am interested in the pulse discharge (regardless of the Amperes I use).
I should have made it clear from the beginning ….
Sorry.
RobertB
RobertB's picture
Tom E wrote:
Not sure how to read those charts – they are pulse tests, not continuous? Length of time is not so concerning – we care more about voltage at high drain, say 5A to 20A.
Here’s Mooch’s continuous tests at 10 through 40A range. When he rates a cell, he errs on the side of safety.
https://www.e-cigarette-forum.com/forum/threads/ijoy-40a-4200mah-26650-b...
Tom E
Tom E's picture
Yep, we are talking about the Aspire 26650 4300 mAh cell, well, compared against the iJoy. Would be nice to see Mooch's comparison tests but from what I could find, Mooch's 26650 summary post is out dated, here: https://www.e-cigarette-forum.com/forum/blog-entry/26650-safety-grades-and-pulse-performance-data.7554/
RobertB
RobertB's picture
Tom E wrote:
Yep, we are talking about the Aspire 26650 4300 mAh cell, well, compared against the iJoy. Would be nice to see Mooch’s comparison tests but from what I could find, Mooch’s 26650 summary post is out dated, here: https://www.e-cigarette-forum.com/forum/blog-entry/26650-safety-grades-and-pulse-performance-data.7554/
Oops, sorry, was following the OP. Why do you say his summery post is outdated?
Here’s all 31 26650’s he’s tested
Tom E
Tom E's picture
It looked all dated Jan 20, 2016 if I understand it right, but the list you linked is different, not what I could find. So apparently he did a 26650 summary thing back in Jan 2016, but has tested other cells since.
Even that post you linked to I can't find a "last modified" date for. The June 22, 2015 date on the bottom can't be right.
RobertB
RobertB's picture
Even that post you linked to I can’t find a “last modified” date for. The June 22, 2015 date on the bottom can’t be right.
Well, there’s not a lot new coming out, other than maybe re-wraps. The iJoy looks like it’s been out on the market for at least 9 months
Tom E
Tom E's picture
Ahh, might be interesting to some. Even though those Aspire 26650 4300's looked poorer performing than the iJoy, I had already ordered 2 of them, arrived yesterday. So, charged them up and tested them against other top performing cells, including the EFEST dark purple 4200's, iJoy, LK 5000's, etc. Well, the Aspire beat them all.
However very limited test: DD FET light w/dedomed XM-L4, checked initial amps using the clamp meter. Amps on both Aspire's were higher than all others, but not by much - slightly higher. All cells were 4.19V or 4.20V pretty fresh off the charger.
2 EFEST 4200's and 3 LK's were included in the tests, just to eliminate any single cell issues. I only have one iJoy though.
