Got my light in from Amazon today fast shipping, but big disappointment!!!
Fresh set of eneloops and it worked okay but a little funny. Switch operated slow… real slow. (some reviews mentioned it) Then it just started acting crazy! Changing modes by itself, indicator light kept changing from red to green to yellow and back again. Pulled the batts out and popped in another fresh set of Eneloops. Same deal! Light was tripping out, changing modes and the switch would barely work. That was enough for me!
Definitely not a reliable light. Back in the box and returning to Amazon.
Yep, I received mine yesterday. It’s having the same issue. Made it through a couple of mode sequences, and then started spazzing out. Actually had to pull the batteries to ensure it wouldn’t turn itself on. I like the light, very bright. Too, bad.
I got my SF11 yesterday and tested it this morning, also had some switch troubles, at first it would turn on to a random mode, then not switch modes or turn off no matter what I did with the switch, had to remove the batteries. The second time it went into strobe and did the same thing until I just started pressing the button like crazy, then it started functioning like normal. Not sure what was up with that, but it seems to work fine now. I am using lithium primary cells (energizer ultimate lithium AA cells).
One thing I do really like, the head on mine was not glued shut, so I can actually get in there for modding. Think I will put in an XP-L HI in warm white.
SP32 arrived today and it works great. I like the smooth ramping between modes. For $18 including battery and charger, this was a great deal. Any chance of allowing people to use the coupon code more than once? I’d like to buy a few more as gifts.
Got the SP32 today from Amazon.
The light work for a minute, the it go haywire, on by itself, cannot switch mode, cannot turn off, I take the battery out and put it back in, it Strobe.
Fix?
I really it this light if it work.
This batch of lights are definitely defective and unpredictable! The light will come on by itself if batteries are left in it!!!
I was testing the light again and found the same erratic results. I left the light in the off mode to take care of something else and came back to find the light on in a low mode. Came on by itself! Thankfully it did not come back on in turbo, and burn something up! Luckily it runs on AA’s and not our favorite 18650’s or similar.
Take the batteries out and return this light!
Sofirn, see all the above posts… this is a bad batch of lights. You should really recall all these lights before it does some real damage!
Thank you. Good idea… I’m curious what they have to say.
I like the light, it’s nice has a good feel to it and the indicator switch is cool. I was going to use it as a nightstand/back-up light. But it is unpredictable and dangerous as far as I’m concerned. Luckily the issues came out right away and not after a month of use….
I have one SF11 already and love it! I just ordered another one with discount. Great light for the money. Hope you get the quirks fixed those that have them.
I’m so sorry for the problems you are experiencing
Thank you for your feedback. We have feedback to the our factory who have find the issues occurred and get solutions to avoid the issues in next batch.
Sorry again for the inconvenience caused to you
If there have other problem, please feel free to contact with me, we will make explanation or assist you solve that.
Thank you very much
Have a nice day
Sofirn
