I’ve noticed this with Banggood before. I tried to leave a well-deserved negative review for the Astrolux E02, which came with an MCPCB that has a bad thermal path and it was never published.
GearBest does this too. I love Ganzo knives, have about 30 of them, and rave about them in reviews. But when one arrived with an uncharacteristic design flaw, I wrote a 3/5 star review (instead of the 5/5s I normally write) and outlined the problem.
And that was the one review that never got published…
There shouldn’t have been a spring on the driver.
Removing it solves most of the problem.
And then shorten / replace the tail spring with a shorter one to solve that problem and then a 18350 will fit just fine, maybe even protected ones (which you probably shouldn’t use in this high current light anyway).
Can go either way. From other projects that I did some #'s on, the springs on each end is really the best way to go to accomodate the widest range of cell lengths. Think bout it - for an 18650 you need to support a 5-6 mm spread (65 to 71), and in order to do that, you need at least some decent compression on the shortest cells at 65 mm, maybe 3 mm of compression, depending on stiffness. On the largest 71's that means 9 mm of compression. So how do you get 9 mm of compression without over pressuring the cell? Well, a spring on each end makes it a whole lot easier since each would compress only 4.5 mm. One big semi stiff or soft spring? Maybe...
For these high performance compact lights, I don't think it's a bad thing to make it a requirement to use only flat top unprotected cells, but that's a call to be made by the seller/manufacturer.
With all due respect, this is simply not your problem.
However, it may be that you can exert more influence than others to Banggood, with a view to them adopting a swift and painless solution to this problem. As you say, a longer tube should resolve most of what is wrong. Some forum members are grudgingly happy to tinker. I am not. I just want a torch that works. Any talk of which battery should or shouldn’t be used is superfluous. I don’t want to buy a torch where my existing batteries are rendered useless through bad design and a complete lack of quality checking.
Do you think therefore that you could perhaps intercede with Banggood?
My S42 219C measurements on a VTC6 18650 (none of my unprotected flat or button top 18350s fit of course)
Very nice and neutral ~5000 K color temp with great tint. Turbo is useless since it gets unbearable to hold after 30 sec. UI is slow and cumbersome. PWM used but not visible on any mode.
Output
Turbo
0 sec: 1500 lm
30 sec: 1030 lm (head too hot to touch at this point)
What LED's? Assume 219C's, if so, good to see you got bout the same results I got in lumens, and super hot in 30 secs, andd good you confirmed the fit of the 18350's, same as I'm seeing.
Notice the S42 has been removed from the BangGood site? A search doesn't show it, but a link from my order list gets to the page, but listed as all sold out. Glad they did this.
Even for a small light like this, a 30% output drop in 30 seconds makes me suspect that people should check the heat path, perhaps the ledboard is not fixed flat onto the shelf?
Mine looked pretty well done actually, gray thermal paste, 2 screws holding it down, not super tight but secure, didn't notice any bumps or anything, grease seemed well spread out. But a 1.5 mm thick MCPCB and a 1.0 mm thick shelf, thin alum at the head, plus 219C's using a FET (not sure if any limits on it) -- all add up to some intense heat real quick. That press&hold for OFF is a finger burner.
Here’s High 2 on a VTC6 (10.8 Wh) with 48 lm/W on average over the run. For comparison, a Thrunite TC12 V2 with a single 219C CRI90 at similar output gets 78 lm/W.
Just received my S42 today!
After reading for the last couple of weeks all comments of two threads here, I wasn’t sure if this was good news or not so … let’s give it a try anyway …
As I was aiming to use it solely with an 18650 cell (I don’t have any shorter ones), and the s41/s42/BLF_A6 18650 tube I ordered to BG didn’t arrive yet, I immediately dismantled my BLF A6 tube to use it with the S42 alongside an unprotected flat NCR18650B. Screwed all together, pressed the S42 on/off button and … nothing happened.
Tried several times, with a protected button top NCR18650 and the A6_BLG back (buttom), no more chance. I was still left in the dark :person_facepalming:
So guys, before I declare it DOA to BG, any thing you suggest I may try?
I’m not confortable with the idea to dismantle the head, there seems to be some glue there.
