I checked SF11 for all day: set OFF with a pack of fully charged battery, faced up; its still OFF for all the time. Looked like it was my real mistake before!
I have gotten mine to work a few times, without it acting up. I would still be cautious about leaving batteries in, if you’ve experienced the same issues, some of the rest of us have.
According to the manual, a half twist of the tailcap will perform a lockout. Do those of you with a working SF11 get that? Mine has power pretty much as soon as the locating pins of the tailcap are inserted.
Mine has also worked normally a few times, then it goes back to being unresponsive and having a mind of its own. Thankfully Sofirn are working with me to resolve the issue, will update when the replacement comes.
I wanted to post here, and thank Tracy for getting involved in the issue I had with my SF11. I received a new one today, and have been putting it through the ringer for the last couple of hours. It is working great. This one came from a different Amazon distribution center, so hopefully for Sofirn, it was just a small batch that were having problems.
I also want to thank Tracy for the help on the SF11 Issues. She actually PMed me before I had a chance to send them a message or go through Amazon. My replacement light arrived last week and is working as it should. Very happy with the light now, should make a great emergency AA light.
Is there any way to identify which batch — flaky, or reliable — that a light came from?
I mean, besides sitting and watching to see if it turns itself on …
Looks like I dodged a bullet on the SF11. The aliexpress store listing has 14500 in the title, in the url , and in the description.
I thought “COOL! A light that will use 4 NiMh AAs or 4 Lithium 14500’s!” and placed an order. Then I looked more closely at this thread and the description page, and the seller verified that it won’t use 3.7v 14500 batteries.
So, I’ll be getting a refund for now. I realize 14500 is, technically, the size of a AA, but that seems pretty shady and misleading to so prominently display that in the description since the commonly accepted meaning of 14500 is the lithium rechargeables. But maybe I’m wrong.
Is that a way to tell the old flaky batch from the revised batch?
I applaud Sofirn making improvements — but I want something clearly visible showing which batch a flashlight comes from, even if it’s only a painted “v1.1” version number, or a paint dot, or something distinctive.
Sofirn, consider getting some glow-in-the-dark paint to put dots on revised lights. That would be a find-in-the-dark feature worth having, too.
No lockout. That’s about my only real gripe with this light. I have one of the bad ones, purchased in May. Tracy had a replacement sent within a couple of days. I’ve had both apart, and there is no difference in the driver. Same model/ revision number. I think they pulled them from Amazon, when they started having issues. It isn’t an issue that will just appear one day, either. It will show up as soon as the light gets heated up. (Or at least thats what everyone, including myself, experienced) Never did figure out exactly what was causing it.
One thought for Tracy/Sofirn — check your driver circuit for susceptibility to “electronic smog” like a cell phone operating nearby.
I have seen other electronics from China that would turn on or off if a cell phone or walkie-talkie radio operated nearby, for example.
I also noticed I could trigger a neighbor’s car alarm by changing modes on a flashlight as I was walking near it (a few years ago, I no longer have that light— not one of yours)
Thank you very much for you guys kindly feedback of Sofirn light.
SF11 was something wrong in June but we have completely destroyed that products on Amazon and made improvement.
If you met any problem or question, please feel free to contact the sales servers and they will do their best to assist you to solve your problem as soon. We 100% stand with our customers.
Would a new version of the SF11 be coming out soon?
I’m getting to like that form-factor, and it’s just a nice simple but elegant design. Very clean.
Improving on the TK4A would make the SF11(A?) a winner. Keep the same UI as the TK4A, but make doubleclick turbo/100% instead of strobe, so this way you’d have instant access to both its lowest and highest settings.
The reflector of the TK4A seems to have some very fine leftover machining marks, making the beam slightly ringy. Smooth it out, and you’d have a perfect beam!
And it definitely needs 2 screws to hold down the emitter.
