Got mine today. As expected the 18650 tube, supposedly designed for the S42, did not work.
It doesnt sound like CS is even aware of the problems with the light much less the 18650 tube fit.
Im concerned about compressing and damaging both 18350 & 18650 batts
Im not looking forward to trying to straightening this out……
Edit: Flatop Panasonic worked………. I apologize if my original post mislead anyone
Just received my copy an hour ago. I found a potential fix for the cell length problem. I believe the tail spring could have been engineered better. I removed the tail spring and, using two pairs of needle nose pliers, cut the leg off of the small diameter and simply wound the spring tighter. Now, instead of the coils “stacking” on top of each other, they collapse inside each other. The whole height of the spring now almost completely collapses into the recess in the tailcap. My estimate is a gain of @1.5mm. My Efest purples fit a lot better now. Can’t take photos as I’m at work. Hope this helps!
Oh, that’s unfortunate…
I ordered the 2 18650 tubes Banggood sells for the S42 after first reading about the problem, the aluminum and steel versions, in order to have a workaround.
If they don’t work, I threw good money after bad .
Arent the S41 & S42 tubes supposed to be the same?
Seems like the trouble with the earlier tubes not working was different threads not the length correct?
This is the heading for the S42 18650 tube that I ordered……
“Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube”
Edit:
The original 18650 battery I tried was a Samsung ICR button top.
After reading your post I found a Panasonic NCR18650B Flatop ……It fit and the light worked with that tube/battery combination…
Looking at the 2 batteries side/side there is a considerable difference in length
Sorry, I did not realize there could be that much difference in 18650 lengths.
Ergonomics is bad.
The charging function is the worst possible.
The USB port cover is disgusting.
User interface is illogical delirium.
The light beam profile is ugly. Too many artifacts.
It’s a piece of shit and even $25 it does not have to cost. It’s too expensive.
But tell us how you really feel . Language please!
I disagree - I would not call it ugly .
I think it's worth modding - will replace the driver, dump the USB charging, and then should have space to add at least some copper under the shelf.
I would prefer the copper head and aluminum tube though (bezel doesn't matter to me) - think they said it was going to be offered. Problem is with the huge driver/USB circuit, the head can't be made as thick as the S41's. Might just buy the S42S and replace the battery tube and tail with the S42's.
You are missing one big huge difference - an e-switch, it's just about a min requirement for me. I have an S41 actually in 219B. Finally yesterday I was able to get the bezel off the S41 combining the pine board hole w/compression cut/clamps method and a good strap wrench.
The E14II light is look'n pretty good but $65 with no discounts is not a BLF deal. In my opinion, they have some nerve to even post here on BLF. Whenever asked about a discount, they simply refuse to answer - like every time.
