I did more various tests with mine but this time on shorter distances 5 meters and I found that results vary a lotā¦
I will take weakest mitkos thrower reflector I made for example with fully charged Samsungs inr 30Q after 30 seconds as you said.
First measuring on 5 meters Showed 247 kcd and after each measuring Uni-t turned off-and on again;
second one 225
Third one 233
Fourth 245
So each time different results on lux reading setting of same light meter.
Than I tried FC function on lux meter and it showed significantly higher results after calculating 1fc= 10.76391 lux
First 267
Second 250
Third 258
Fourth 248
So I guess that readings can vary with this light meter and it seems it reads slightly higher with FC function on (I donāt know if you tried that Djozz)
I would like to mod this light too but iām kinda a newbee to the modding sceneā¦
What kind off stuff do i need to mod this light? I didnt really understand the lowering part of the led that was written in the OP.
XP-G2 de-domed will give you a very narrow beam with this reflector.
Maybe too tight for you to be useful (without binoculars).
I put in a XP-L HI and i quite like it like this.
The best choice for this reflector is a dded XML or XPL: i`ve modded another one today this way, with a good U4 1A and a fet driver plus everythign bypassed it came out exacly 245k cds at 5.2 amps: running with a VTC 6 battery
XPL Hi would never ever give you 250k mcds ā¦and we are BLF-ers, lets leave Hi for CPFers pls
They are using a relatively good black emitter bracked now so you can use it by default
Unfortunately the default emitter is a total garbage, not like the first ones i got
yet, the host is great, the results are exacly the same that i got with a good modded B 158
P.S
A dded XPL would give you a little bit more actualy yet it starts at 6+ amps usualy,
As i mentiuoned this many times here, HI emitter has a sillicone burn issue on a long term base when driven at high currents, especialy < 5000k bins
Plus its a low performer .
Plus we are BLFers, its a shame not to dedome a XML or XPL in that host, or XPGā¦
Actualy CPF way is to get a M2X and pay aditionaly 100$ for a high class modding
Not yet djozz , waiting for them to arrive( ordered them from Arrow)ā¦ i suspect that Luminus are using Cree coresā¦ as you know Cree are selling massively cores onlyā¦
Yet, a well driven U4 1A beam profile looks even better than the default Olight M3X one with the same intensity
I had a talk with the seller( a nice chinese woman as it seems) , however she speaks only business english, she understands only about quantity and price per pc and cares not for hosts
Its 40 kms away from me so i visited them many times , they do some OEMS for Bosch, Phillips, even Cree! I wonder how they stand the CN yet they do, at least for now
The only one they have 2 weeks ago is P2-AA-VL, i guess its more or less 8000k or something and thats kinda higher K that i needed actualy but i got only 2 for the test
They claim 1800+ lument at 5 amps, thats more or less like a V6 emitter
I understand your opinion, but iām driving the XP-L HI (V3 1A) on 4 Amperes, which makes it a fine light that will have maximum output for a good part of the charge of the battery.
It doesnāt get hot either.
Can you say the same?
Probably not, but thatās not important to you, you want the highest Candela readings from a single 18650 light.
So, to each their own, right?
No need to be snobbish on BLF, thatās what people dislike about CPF, donāt you agree?
Ofc i can! Any U3 or U4 at 4 amps will have at least 20% better candelas, better beam profile and i am 100% sure that it will run cooled than your HI or any other HI emitter in existance.
About dding it, well, i am pretty confident that everybody can do it, if someone cant: msg me , or those lovely blf ppl arround that topic would gladly help at no cost.
PPl dislike CPF cause it was all about Surefire( the one and only), flashlights under 100$ are crap, no reason bannings and other stuff of that ilk
Once again, thats the reality, the BLF way, the cheaper and more reliable / productive wayā¦and its fun.
Exacly as modding that host, yes its ugly and cheap yet the results are great
Actualy yes, on second thoughts there are ppl that demand only 6500k+ ā¦then using HI is reasonableā¦.i did that on my first host actualy, quite forgot about that
Well, i have no SureFires or Sparks or other overpriced lights.
But if i want to run a XM or XP LED on 6 Amperes i want to run it on 2x 18650 (or 26650) with a buck driver like FX-30.
For a single cell the VF is too high at those currents, so the party is over after a short while.
But okay, maybe the XP-L Hi V3 1A was not the most exiting choice for this ānew BLF classicā, but i had one lying around so i put it in there.
Bedankt voor je reply;) i want the led to be close to the reflector but what i understand is you need to fill in the space with copper or other conducter. Can i just take a 16mm copper plate and drill two holes in it for the cables and put a 26mm mcpcb on that plate(with thermal paste)?
Ok. You know that 16mm mcpcb build guys with drilled reflector from this thread? I checked again with new lux meter (with fc fuction, 5 meters, 5 measurings) and average was 282kcd.
Now I will add 11,4% difference Djozz got in measuring same dd emitter and same budget lux meter as mine + compared to professional light meter and final result is 321kcd (if I calculated right :question: ) for old xpg2s42b in Supwildfire reflector.
That is not bad at allā¦ I finally have piece of mind :innocent:
So yesā¦ 240kcd of new production xpg2s42b that some of you guys got with fet driver now seems realistic to my previous results from aspheric lights(25-30% difference among new vs old one) and if I will do another batch of this Supwildfire(Mitkoās thrower) reflectors I will do them with new s42b. Why? Larger beam and only 3,6A current draw with fet drivers so you can enjoy turbo mode for a longer timeā¦
