Yes the whole emitter soldered to the mcpcb is is submersed in the solvent. I fine reflowing undomed emitters a hassle so I make sure it is soldered to the destination mcpcb. Also. The emitters would just bounce around if not attached to anything. Possibly causing bondwire damage. It usually needs to be cleaned up with a tooth pick afterward so that requires the emitter to be attached as well.
Yes, the whole emitter mpcb and all go in the solvent. Generally I use a quarter inch of solvent and gently agitate after 15 minutes to remove the bits left behind that are still touching the emitter.
I’ve been using Mek to dedomed xml2 emitters. The results ate not perfect but satisfactory with no silicone left on the done. Is there another solvent or solvents that I can add to the mek to get better results? Ild just try stuff but the idea of randomly mixing chemicals is short lived in my mind
Yes it is. The funny thing is I can still get 1000+ meters in an L2 host with a single 26650 by choosing emitters with the lowest Vf. In an ass backwards kinda way I measure the current at 4 volts on my power supply and sort them by how much each draws.
Also, with a clear solvent the tint shift is not discernible unless you compare side by side with a rosy xpl hi. In my opinion the S4 2B still makes a great thrower.
The new ones show an ugly green tint shift when dedomed with gasoline apparently. Never tried personally, but others including L.I. have reported this to be so. I can say with confidence that this is not the case with a clear solvent like Aerosolve.
The new ones generally have a higher forward voltage as well which limits the amount of current available to the emitter using a single cell. From what I’ve tested the average current is about 3.7 amps at 4 volts but there are some outliers that run 4 to 4.5 amps. These produce similar throw numbers to the old school S4 2B’s.
You just have to buy a bunch of them and test them individually to find the best ones.
Yes I also found that they mostly draw 3,6 - 3,8A in fet driver configuration. That is not bad for certain configurations cause battery will last longer and performance will be similar to dedomed xm-l2 or XP-L but they will of course draw more current.
And yes it really is greener and uglier than old one. But you will not notice that in reflector lights. You will only notice that in aspheric lights.
So Swib did you tried them in aspheric? If not than you will not notice ugliness of this new s41b emitter and it has nothing with de doming.
I know how to hot de dome(reported from plenty guys that it has least tint shift) and have tried all sorts of solvent methods until I find solvent that works best for me. Boiling hot solvent is best imho and I also can say with confidence that there is no difference in final result with properly(good luck with that ) hot de dome or hot solvent de dome of same S42B emitter except that solvent hot de dome is far superior and easier so I can for example de dome around 50 emitters at once in not more than 15-20 minutes.
So I would really like to see someone who does hot de doming to do the same.
I said several times that I use hot nitro paint thinner (I don’t know if you guys in USA have this).
So I use boiling hot Nitro paint thinner. It is that simple…
Ya I know. But that product is not available in the states nor are the chemicals it is made up of. Those of us in the states are apparently not able to self regulate this kind of product. We need some one like a government to be responsible and block its availability.
I think you just must try stuff in USA that is made for thinning a paint or cleaning brushes from paint.
And remember boiling hot stuff(it would better be to cook that outside because of smelly and potentially harmful fumes).
I had similar problem when I was trying to get how do you USA guys say… “mineral spirits”.
There is no such thing on our market…
I needed that for diluting true oil (an excellent gunstock finish). And at the end I find something that works great (zippo lighter fluid ).
