Hand made carbon fibre, brass, copper & aluminium 18650 flashlight with triple XP-L HD v6 3D emitters.Cree XP-L HD V6 3D emitters on 20mm noctigon MCPCB
MTN 17mm driver
XP-L HD Modified 10507 Carclo optic
ARC glass
Aluminium & brass heatsink
Brass bezel & switch inserts
Forward clicky tail switch
Tritium vial in switch
Magnetic tail
Carbon fibre & brass construction
Length – 107mm
Width – 22mm
Weight – 120g (with 18650 cell)
Max – 3080 lm
Shortened 18350 Version with aluminium jacket.Cree XP-L HD V6 3D emitters on 20mm noctigon MCPCB
MTN 17mm driver
ARC glass
Magnetic tail
Aluminium Jacket
Length – 78mm
Width – 25mm
Weight – 108g (with 18350 cell)
Max – 2320lmTwo piece aluminium casing is held on by friction. Simply pull it apart to reveal the inner core carbon fibre & brass flashlight.
Dyneema wound mid section
Length – 73mm
Width – 22mm
Weight – 80g (with 18350 cell)
Max – 2320lmSibs.
