Cheap bare 385nm UV LED
Its one step closer.
Now it should not take to long anymore!
Ok, I got the leds in.
And there’s complications. This is how the leds look, it is not the same led that the OP is about.
  1. it is a LG led alright
  2. it has the narrow 55 degrees emission dome
  3. it is from a newer generation than the led that I tested, with, if specs are compared, almost double the output at 500mA ( LEUVA35T01TL00, 385nm Narrow, 1100mW typ. at 500mA)
The newer generation with better output (I would still have to test what the real world performance is) is pretty cool of course. But that it is the narrow emmission version may be not cool for some.
So perhaps the folks who have signed in and even payed for these leds should post how they like them, especially of course TheOnlyDoc and alpg88, who will get the bulk of the leds.
(ok, I’ll start: I had no ongoing project for these so I just love what’s going on :party: and would not mind getting 8 of these instead of the 3 that I signed in for)
I like it! The 55° emission dome is even better for me. So i am happy. And i will not complain about getting a newer generation with more output.
I send a PM to all on the list.
And i contacted the seller and asked for the flux and voltage bin. But ~1400mW at ~700mA is dam hot! My DD tripple could get really hot :smiling_imp: . I am eager to see what this led can do on a copper MCPCB at 1 amp+. If i had to guess i would say that the tripple could get easy 4-5W real 385nm output.
Maybe i should get one of this stickers for the light :smiley:
does it mean they wont work as good with tir? i’m planing to use PMMA triple from ledil, i used it before with 365nm leds. but those had 120*
It will be an surprise how they behave in a TIR. I do have a Ledil Cute and a 32mm Noctigon board I could check, but it will take another week before I actually have time to do the experiment.
I thought that plastic lenses/TIR are not the best way to go if you use UV leds. Also AR coating on glass lenses. Thats the reason why i ordered new lenses for my Wall-E light (against the description the light arrived with cheap plastic lenses) one with AR coating for the MC-E led and one without for the UV tripple.
I might have to grab some of these LEDs and throw together a P60 quad drop in, no optics, just bare emitters, would be handy for checking for leaks with fluorescent dyes and other close up stuff, which is really all I do with UV anyhow.
Is the new version available on Ali yet?
they are not, vast majority of them, but those made with PMMA are ok. unlike polycarb pmma can work with band as low as 365nm.
Dam i could have fit a quad copper mcpcb in the Wall-E light. Mhh but now i have a tripple board with small tripple reflector here. No no no it is tempting but no i will not do it. :person_facepalming:
@Jensen567
The shop on Aliexpress is selling these leds on Alustar 10pcs/lot at $12.75 (https://de.aliexpress.com/item/10pcs-3W-3535-High-Power-LED-UV-Light-Chip-365nm-385nm-395nm-405nm-420nm-Ultra-Violet/32805138361.html).
Normal price at this shop is 15$/lot.
I’m not sure that there is a PMMA Ledl optic for the quad boards used here on BLF, these quad boards are made for Carclo 10622 optics which are made of polycarbonate that has a cut-off at 400nm.
But aparently you do not know what you will get, I’m pretty sure that if you buy these leds on the 20mm star it is still the older generation led (which perfroms fine btw) with the 120 degrees dome because they still have already produced stock, and not the newer gen. with 55 degrees dome like we received as bare leds now.
What are the plastic lenses made of in the cheap Chinese zoomies? I’m thinking with the tighter 55° emission dome, an aspheric is better than a reflector. But, I can’t afford nice lights with glass lenses! :stuck_out_tongue:
Polycarbonate, and having measured a few for 365nm transparancy I can confirm that they block it. The small On The Road zoomie (i3) has a glass lens though, that could be a nice host for this led.
figures… :weary:
Are there any left? How much is UK shipping?
TheOnlyDoc will know soon how many are left. The shipping is 1.70 euro.
You know what I just thought of? If these are not the exact same emitters, then how do we know if they are even the same wavelength as the ones we asked for? Is the original LG packaging present and labeled appropriately?
No, it is a matter of trust. I did check their earlier LG leds and they were dead-on 385nm. I could check these too but will not bother actually, it is not that the 385nm ones are more special or expensive than the 395 or 405 ones, I think that they know their leds but just don’t understand their customers.
That’s good enough for me. As many LEDs as you’ve tested over the years, if you can trust them, so can I. I don’t have any particular attachment to any particular wavelength anyway. I’m just buying these to play with. :smiley:
on the pic the dome looks taller than normal? is it the case, or just optical illusion?
