It was an xm-l2 u2 1a emitter. So that shouldnāt be the problem. Maybe it was the thinner I used?
Tried it against my ZL sc600 mk iii hi first. Shouldnāt have done that :person_facepalming:
Guys. Any nitro thinner from your local shops should work. It does not have to be one I linked. Use from your own local market. For best results follow my mentioned method. My all come ultra clear so should yoursā¦
Edit:
āIf you want ultra clear dd die than do 15minutes of boiling(you must see bubbles if it is boiling hot) and after that put it in isoproply alcohol bath and blow with compressed air. Result like MEM or Mitko from this thread each timeā¦ā
And perfect method is revealed. :partying_face: For harder silicone base emitters that are hard nut to crack do the same but you can slightly and carefully cut them from side to side with scalpel which will allow better solvent penetration.
You will all thank me after this I did lot of experiments with my market available solvents to find that the best stuff is in front of my nose in basement and it is even not that harmful since a lot of guys cleans paint on their hands and even face after messing themselves with color they just use mentioned nitro paint thinner on the skin
P.S.
Did I mentioned that you can de dome them 5-15-50-100 or even 1000 if needed at once with this method? (just choose proper size pot)
Will the nitro solution dedome a XHP70.2 emitter?
I guess you should try I am very convinced it will. Especially if you closely follow what I wrote. Good night peopleā¦ 2amā¦
Thanks for sharing luminarium iaculator. :+1:
Just tried luminarium iaculatorās metode with nitro paint thinner with two XM-L2 CW is works great :
Thank you so much for sharing this :+1:
This is proper result of my method :+1:
Thanksā¦
Edit:
Another tipā¦ Donāt go to close with compressor air gun when blowing out remaining silicone. Strong compressor could be to much for that tiny wires. Use it at least 20-30 cm above led and if you can aim minus toward plus size of emitter (so all junk will fell over + wires in single blow).
What about the tint?
X6 XM-L2 CW DD
There is a bit of green on the very low modes but overall considering it started out as a unspecified XM-L2 CW with a blue tint, I would call the DD tint white.
Nice job khas!
Do you have a link to the thinner you used? Hopefully I can get it shipped to Sweden!
Never mind. I saw that you bought it in Italyā¦
I have been trying to find nitro thinner in sweden but cant seem to find anyā¦
Sledgestone if you are more successful please share your findings
Iāll try to find some. There might be some at a local paint shop.
That dedome and beam tint look really good khas! Congrats
Has anyone found that nitro solution in the USA? Care to share the link?
After reading about the nitro thinner, since I had some laying around, I decided to try dedoming an xhp50.2 that I plan to put in a convoy L2. The results were better than I expected: in ~10 minutes the dome came off without leaving much residue (but it took a bit of phosphor with it) and while I havenāt tried it in a flashlight yet, the tint seems to have changed very little (this was a 3A) and the infamous yellow tint shift seems to be less evident than before. Though Iām not sure why that happened, I think it may be because of the thickness of the phosphor layer on the sides being reduced by the phosphor lost during the process.
I made some progress. Found this in Sweden.
http://www.lackbutiken.com/sv/hem/ppg-billack/tvatt/max-meyer-nitro-fortunning-1-literāpid50.html
Didnāt find a data sheet though, but Iām pretty sure that itās the same. Only thing missing is the Antinebbia part. Anyone know what it means?
My best guess is that Antinebbia means āNo fogā
I found this in the USA but not sure how much it costs or if it would work like luminarium iaculator has posted
The only places in the US that might carry it are
And a hobby nitro thinner that might also work is this one
Hm, no fog? Not exactly sure what fog means in this situationā¦
Guys,
When you de doming of hard core emitters you can leave them even more than 15 minutes in boiling thinner. When dome fells(and that happens very soon) it does not necessarily means that other silicone bits on emitter will fall they need to be cooked bit longer.
So donāt watch guys. Stick to my instructions and click stopwatch. But even 1 or more hour of cooking canāt destroy phosphor.
Nitro thinner sounds mean but it is not. If it is skin friendly so it should be phosphor friendly.
And one thing I canāt believe. That there are no paint thinners on some markets? Guys what do you use for thinning a paint before coloring something? With which solvent do you clean your painting tools, and even your skin after painting with color for metal surfaces?
Anyone dedome any XPL V6 1As recently? For me most of these emitters do not dedome easily using hot gas method. There remains a layer/chunk of silicone that is well attached to the phosphor. I end up having to carefully scrape this away and itās not clean.
