Review : Utorch UT01 Flashlight (XP-L V6 / AA & 14500 / e-switch)
Looking forward to your comparison and opinion of the JB E10R
I purchased a CW and a NW last year, just before Christmas. Both had good switches. The NW is an EDC light. The CW has sat unused with the tail cap tightened since then with a purple Efest IMR in it
Today I checked the battery using the built-in tester, and I got 4 blinks. So to answer someone's question about parasitic drain, there appears to be none, or its entirely negligible.
I measured 14uA in standby , when i reviewed this light.
If my calculations are correct , a 650mAh battery will be drained in 5 years .
So, me e10r arrived to me yesterday
After one day playing, there are something i can say
1: the build quality of jetbeam is a little better, the AR lens is better than the one in ut01
2:compatible with all my 14500(shame on you, ut01)
3:the micro usb charge is convenient, but i’m scared that one day i will lost its head when charging(it’s small, and round, which mean i could lost it)
4: i prefer the button of ut01, soft and comfortable
5: the UI is one advantage of ut01. There is delay when changing mode on my e10r, only 3 mode(1 hidden strobe). I wish it was 4 mode, with more reasonable spacing
6: the tint on e10r is(imo) better than the ut01 5000k(too warm, not really 5000k), e10r shows a brighter hotspot, too( thanks too xpl-hi)
In conclusion
Both lights are good to me
But if i need to choose one to buy, i still buy e10r, because better brand(utorch is the clone of…you know)
Hi Mrheosuper
Thanks for doing the comparison with the E10R
Anyone had any problems after using 14500?
I’ve been using Eneloops just to be safe (as if the driver were damaged it would be expensive to get a replacement into my country or I would have to wait to buy it with something else), but the output in turbo with 14500 is quite higher.
Using mine (with 14500) from day 1 , for some minutes every night , no problem at all .
Don’t forget to check the length for the 14500 before you buy. Protected 14500 wont fit unless you do the paper clip trick.
You’re right, 14500 is much brighter than AA but you can’t use it on turbo mode continuously as it gets very warm. Just a heads up
So the light has 4 output modes (lower, low, med, hi), and in addition, each one of these can have one of 3 different outputs, correct?
Which of the 3 outputs is programmed from the factory? The middle one?
Since this ages old thread is still active…
there’s currently a deal on these lights at GearBest, specifics here:
https://slickdeals.net/f/10693384-utorch-ut01-800lm-flashlight-10
$10 with code TTGIFTS
Must be logged in to your account for the code to work.
https://www.gearbest.com/led-flashlights/pp_555778.html
In my experience GearBest is reliable, but their free shipping choice is slooow as molasses. Might end up being a Christmas gift…
I just got two in the mail today from GB - shipped within 24 hours, and arrived much faster than usual.
Oddly enough, these don’t appear to be programmable. They go into the blinky modes just fine, but there’s no apparent ‘low’ in the cycle to begin programming. Am I missing a trick?
The switches seem fine, but I’m also not finding a ‘battery self test’ that someone mentioned earlier in the thread. I’m not complaining; for ten bucks a pop, they’re still a terrific bargain….but if there was a way to lower the ‘moonlight’ mode, I’d do it.
Well, that’s a shame. I ordered one partially because of the programmability factor.
Does this work?
Hmmm… :frowning:
As they say: When it sounds to good to be true, it usually is…
I hope the maximum high output is still the same.
Hallelujah! :+1: That works!
I was doing it wrong….this way is also a bit tricky, and I recommend doing it in a very low-light room, but it definitely works. I managed to reduce the moonlight setting to a fraction of its default. Excellent! :slight_smile: Thank you!
Have had this light for few months. Used about an hour I guess, Went to turn it on today and it's DEAD... }( Hate it when this happens. Can't for the life of me figure what's wrong with it.:|
EDIT: I'm an idiot...battery tube was backwards...dunno how that happened :BLUSH: .......So remember that it won't work unless battery tube is in right configuration.
Drained battery?
My UT01 has been unused for month but still works.
However i just discovered my Klarus Mi7 Ti i haden’t used for a while too, was dead because the cell inside was totally depleted.
Good to know!
Apparently, if the UT01 battery tube is installed backwards, it won't work. Maybe someone else can confirm this with their particular light also? At least, that's what's happening with mine.
Edit Again: I just reversed the tube and it works both ways now. Guess tail cap was not seated completely. Weird, but it works both ways now. :O
Too much Olight?
