Review:Angryfox E6 multifunctional mini flashlight
The fox E6 sports set is a special high-brightness EDC flashlight designed for professional outdoor workers, outdoorsportsmen, and special industryworkers. Special design,reliable quality and rich accessories can beperfectly adapted to all kinds of bad places and extremeenvironment. This new professional high-end flashlight is the onlychoice for special places, light weight is only 37gram weight(without battery) but with Max 630LM output and 528H runtime.
Patented Family-owned “Rattlesnake” clip design
The flashlight can stay at 45 degrees lighting angle all the time when it is being hanging somewhere, it is very interesting.
Multi-purpose belt buckle, it can connect the E6 to headband and wrist strip to get the headlight and wrist light.
The original integrated 8-colorssoft light dimmer to make this light for multi-use.
With a new metal silicon bicycle fixing seat
For this light set, it comes with new variable every-direction headband; wide-compatibility two-ways wrist strap; a new metal silicon bicycle fixing seat.
That looks like a fun flashlight!
How about some specifications: what batteries does it use, what type of led is in there, where can I buy it and what are the costs?
Welcome to BLF!
+1 on what Djozz said :wink:
What he said… :smiley:
It takes one CR123/16340 battery and uses XML2 U4 LED.
You can buy Angryfox at Amazon.
:smiley: :smiley: :smiley:
Forgive my bit of skepticism, but
Your only posts here are reviews from this manufacturer.
Are you a flashlight enthusiast, or a Commercial Seller?
My guess is a seller/manufacturer, but not very commercial, there’s even no link in the OP. :slight_smile:
My only druther would be that the battery-tube be just a tad wider to be able to take an 18350, and not be limited to 16340s.
A nice stiff spring would keep it from rattling around too much.
Your guess is correct :+1:
The light looks very interesting. Do you have a release date?
Ok, You pawned this as a review in the title, did not post it under the commercial seller spot, you say it's a U4 while Amazon says it's a U2, and you want $45 for it shipped. Hhhmmmm...
This make me angry as a fox
Thank you for your suggestion, we will consider that in the updated version later.
The Angryfox E6 light set is available already. :slight_smile:
:stuck_out_tongue: You are funny…Calm down, the U4 is our updated LED version. :slight_smile:
I guess CR123 strobe lm are an error?
The Strobe lumen is same as the high mode :slight_smile:
