It will most likely be junk like most *fire chargers. It’s not worth the time, really.
I have ordered one. It will go in the low priority queue, i.e. it can be a long time before I publish a review.
There is a big risk it is a bad charger, UltraFire often is.
https://www.aliexpress.com/item/TP5100-double-single-lithium-battery-charge-management-compatible-2A-rechargeable-lithium-plate/32615889901.html
I found this while searching for a small but >1A charging circuit
This thing is interesting, because you can choose 4.2 or 8.2V - I think the charging current drops to 1A at 8.4V
also, the input-voltage can be pretty high.
If you are bored (lol)…
I have ordered one, but it will probably be a very long time before I get time to look at it.
Hi HKJ, there’s the new 4-slot charger Liitokala Lii-402:
http://www.liitokala.com.cn/productView.asp?id=47
It would be cool if you can lay your hands on one of these when they are available
I expect to test it, but I do not have any in queue and will very soon have a lot of other chargers in queue (DHL was supposed to deliver them today, but it looks like they where a bit too optimistic).
Sofirn, again - very cheap 8-slot charger.
But does it trickle charge and hurt LSD cells? Can’t tell.
Got a guess on this one?
I recall some chargers were wired so badly that they could put line voltage on the outside metal frame of cell phones.
Bad thing to take into a bathtub.
And there they are: cell phone charger hot voltage outside hand risk problem electrocution - Google Search
That is a major risk with any charger that get two skulls in my list: Index of tested and reviewed USB power supplies/chargers
Shouldn’t they installed RCD/RCCB on the breaker especially for bathroom in the US?
Probably only when they change an installation or make a new installation.
have you test this charger seems like an okay price for a 2A charging. Really lacking information, if its charging 2A at all slots that would be good.
AWT C4 charger
No, but it looks interesting. With the amount of chargers I have in queue just now, I will not order new chargers for test.
At a later day I expect to check this thread for interesting chargers.
I remember for that later day also a Nitecore SC4 .
I have made a memo in the second post of the thread.
10 amps....... O_O
It’s 8 Amps max (4x2A), if I’m reading it correctly.
The outer bays can push 3 Amps only when the two inner bays aren’t being used.
The main negative I see is that there is no discharge function and no ability to measure actual battery capacity in mAh.
Oh yes... I read it again... In my mind I have read ch2 and ch3 can only deliver 2A when 4 slot are used. My bad, seems time to sleep has arrived. Thank you for the clarification.
