The first 3 is bout right, the last 3 I'm not personally sure of - still not sure if the efficiency is that that bad or not - UI has probs, but dunno bout the worse ever - it's usable, and can't vouch for the artifacts. My S41 was an early one, and the MCPCB is definitely different than later S41's and even the S42.
Of course bout the head design handling the heat, there's basically no tube light that has a head design that can handle high amp heat - it's all a matter of what you want and what risks you are willing to take. Perfect temp regulation is maybe what you want because it will give you turbo output, though briefly.
Based on Maukka’s test, we can be sure it’s a 219C, 5000K, R9050 (90+ CRI, 50+ R9). That doesn’t tell us what the exact tint bin is; it’s probably sm507, as tighter binning costs more and this light is very inexpensive with four of them, nor the flux bin, but it’s probably not the highest available (that being D240, last I checked).
In the hopes of not sounding too ignorant, I apologize if I come across that way. Does the S42 with the 18650 tube work correctly and if it does are there certain batteries one should or shouldn’t use?
the S42 has the same ‘improved’ optic mounting as the fixed heads of the S41S: a rim protruding on the inside of the head. That rim was too high up in the S41S and seems even higher in the S42, causing the optics to sit too far from the leds. So what should be a decent hotspot is a wide uneven blur.
A fix could be grinding away some off the top of that rim with a Dremel to sink the optic a bit, I will try that for the S42 one of these days.
I just received the A6_BLF/S41/S42 18650 tube from BG for my S42. Screwed it to the S42 and inserted an unprotected flat Panasonic NCR18650B 3400mAh (Green) in it. It works perfectly (I had previously faced big issues trying to use the original A6_BLF tube with the S42). Did not try any 18350. And that’s only my experience, don’t know about others …
Since the USB cover is redesigning now, they would be in stock and shipped next week, please kindly wait for it.
I hope I don’t have to wait until July 17 just to get it shipped…
Good thing paypal allows disputes for 180 days. I’m seriously considering initiating a dispute over this horrid mess. I haven’t been able to test the item to see if it even works. I’m not keen on damaging a battery just to test it. I’m not doing any mods and I don’t have extra battery tubes. This was presented as a complete, usable, functioning product. Obviously it is not. Lesson learned…
Got my two S42 Nichia today.
First impressions: Bluish tint compare to my 219B, artifacts, usb cover falls out, strange UI. Works with my Vappower IMR 18350, no dent.
No real use for as it is on daily basis. Perfect for the glove box in the car with its micro usb charge and glass breaker.
