In the hopes of not sounding too ignorant, I apologize if I come across that way. Does the S42 with the 18650 tube work correctly and if it does are there certain batteries one should or shouldn’t use?
the S42 has the same ‘improved’ optic mounting as the fixed heads of the S41S: a rim protruding on the inside of the head. That rim was too high up in the S41S and seems even higher in the S42, causing the optics to sit too far from the leds. So what should be a decent hotspot is a wide uneven blur.
A fix could be grinding away some off the top of that rim with a Dremel to sink the optic a bit, I will try that for the S42 one of these days.
I just received the A6_BLF/S41/S42 18650 tube from BG for my S42. Screwed it to the S42 and inserted an unprotected flat Panasonic NCR18650B 3400mAh (Green) in it. It works perfectly (I had previously faced big issues trying to use the original A6_BLF tube with the S42). Did not try any 18350. And that’s only my experience, don’t know about others …
Since the USB cover is redesigning now, they would be in stock and shipped next week, please kindly wait for it.
I hope I don’t have to wait until July 17 just to get it shipped…
Good thing paypal allows disputes for 180 days. I’m seriously considering initiating a dispute over this horrid mess. I haven’t been able to test the item to see if it even works. I’m not keen on damaging a battery just to test it. I’m not doing any mods and I don’t have extra battery tubes. This was presented as a complete, usable, functioning product. Obviously it is not. Lesson learned…
Got my two S42 Nichia today.
First impressions: Bluish tint compare to my 219B, artifacts, usb cover falls out, strange UI. Works with my Vappower IMR 18350, no dent.
No real use for as it is on daily basis. Perfect for the glove box in the car with its micro usb charge and glass breaker.
I also got the 16% code. All in all this light has been such an anti-climax. It could have been superb,instead it’s a mess. As a previous poster said, mine will probably end up as a car torch. I think BG could have given better compensation than a derisory 16% code to be honest. Very underwhelming.
My 40mm 18350 battery tube just arrived, by domestic (US) mail from City of Industry, CA. The threads are longer on both ends, solving both of my original battery problems (front threads too short to reach the driver board, rear threads too short to screws onto battery without damage). I was able to use an AW 16340 as well.
Presumably the USB port cover is coming next month.
So now it works reliably, but the design issues remain:
Horrible UI; including the inability to turn off directly from moonlight mode.
Uneven/non-useful spacing of brightness levels
Skin-singing heat in turbo mode
TIR optic assembly causes artifacts in beam
Still for the low pre-production price paid, I will rationalize a use for it.
