Lol, “brave”….??? All I did was nick the corners. Nothing detrimental.
Do I like the qctp? Yes. I did have to turn down and thread the end of the hold down bolt as it was too large for the compound slide. Luckily I have a lathe for that :innocent: The one major gripe would be the kit I bought had a limited number of tool holders and to buy more individually is a lot more pricey.
Tool holders I have - 4x standard 1x boring bar holder 1x knurler (which holds a tool on the backside) 1x parting tool holder plus the original tool holder that came on the lathe. Since I part off with the lathe in reverse I don’t use the quick change parting tool holder, I use the original tool holder for that. Still now and then I’m changing bits in the holders but for changing between commonly used bits it’s great.
I guess a pic could’ve explained that in less words but I’m on the phone.
And just because I’m looking for something doesn’t mean I always find it :laughing: :person_facepalming:
yes might shove a xml and blf driver in it.
more of a test run to see how it would go
see how many cree rings it has.
might try polishing some more with dremmel
If you can get in touch with someone that does electro polishing that would probably work quite well. Lot fees are pricey, we pay $120USD. But you might be able to talk someone into tossing it in with some other stuff since it’s a small part. Also an hour or two in a vibratory tumbler with plastic abrasive before will work wonders. The rings from polishing on the lathe will be gone.
I made up a spindle stop for the lathe. 2 parts - wheel and stop. I printed off a 24 section circle from the net and stuck it to the wheel and scored the wheel for future clarity. I don’t think it’s super strong but should enough for this little lathe and what I do. Also I can’t fit the gear cover while this is attached :cry:
I don’t have a specific build in mind. I have wanted something like this on my lathe but only got around to it the other day. I initially had the idea of using a bicycle chainring but put it in the too hard basket. I like the simplicity of this idea as well as the increments are not fixed.
The RPM DRO is okay but usually don’t use it when working with aluminium. It’s a simple add-on that can be had fairly cheap You just need to supply your own power and magnet for the hall sensor.
Sorry Moose I missed your post. I used a small neodymium magnet (about 10mm x 2mm) on the back end of the spindle. It was strong enough to hold itself on without being flung off.
But that’s all in the past. I sold the little lathe and bought a slightly bigger one. It doesn’t have electronically variable speed (yet) but so far I haven’t missed it much. I don’t know why but I’m having trouble posting pics tonight so a link to the album will have to suffice https://photos.app.goo.gl/1S5J81STWIDgyewD2 My brother helped me set it up on Saturday. I did a test cut on a piece of aluminium and ended up making a spindle handle out of it. My drill press got pushed off the bench so I need to do a little reorganising. All in all happy with the upgrade.
