Ha Djozz is not joking when he does his test :+1:
Yeah I did press the second LED down better, that could be it.
Either way it does seem like all the LEDs are the same bin like it says in the datasheet.
They will not be good for direct drive, unless you are ok with less current.
At 4.2v the LED only took 2.5A, and to get it to 5A it required 5v.
Direct drive with a single cell would make it run at ~2-2.5A which isnât very high.
I recommend a CC buck driver for people who want to drive this LED hard.
(at least this is what the power supply showed me, I didnt have time to check it with a voltmeter)
On second though, the 3ft of wire might have made a difference, I bet the voltage drop at the LED is actually less than what the power supply showed.
Maybe like 1v less? that would be more similar to DJozzâs resultsâŚ
Nice, I think my setup did provide better cooling than that since it didnât have a huge copper column that heat had to travel through.
What thermal paste do you usually use?
2.5A at 4.2V sounds far outside normal voltage variation for the Black Flat.
Yeah it was probably just the power supply.
Now that I know it wonât burn up I will do a test using my MTN max 6A driver and measure the voltage at the LED.
And build one small light with FET driver please
DTP friendly P channel MOSFET driver
17mm and bigger
did 17mm Oshpark
and 17-24mm Seeed design
Still no replyâs for this revolutionary driver?
Lexel when we can expect it and how much it will cost?
I see MCU there but is it possible that you individually re flash it for costumer demands (I need only Turbo, mid, low without memory effect so it always starts on high.
The parts price will be around 1.3$ less than the other Narsil/Bistro drivers, as the FET is cheaper and no AMCs
The MCU can be Attiny 13a, 25 and 85 or other
Pin 3,5 and 6 are bridged to the single FET, so it is possible to run different 1 channel output firmwares
@Djozz: thank you for testing the Black Flat two years ago! Because of you my big thrower now does 1.7Mcd. We all might have never noticed this LED if you hadnât tried it.
Youâre welcome. But my own first test in a Brinyte B158 made me believe that in practice this led was not so great as the test suggested. Must have been an imperfect reflow. Good that you guys went on with this led.
I got the first batch 17 and 20mm boards produced
Was it the same LED which you used for the test?
In what distance did you measure the light? You need to be further away compared to the same light with XP-G2 because the LED is smaller.
There might also be another reason. Itâs possible that the lens of the Brinyte is not precise enough for such a small LED. You could check this by putting the light into full focus and looking straight at it from a few meters away. The entire lens needs to be yellow (or lit up).
If itâs not, then a fix would be to add a pre-collimator. It makes the LED seem twice as big which âmakes it easierâ for the lens.
I measured at 7 meter, but an aspheric flashlight measures well at shorter distance just as well.
The Brinyte plastic lens is one of the best I have seen, and much better than any glass lens that I have encountered in various flashlights. The die image is very crisp, if the lens was imperfect you would see the imperfect focus coming from the lens part that gives different focus or chromatic abberations superimposed over the sharp die image. But you donât see any of that.
Some recent testing with L4Pâs Oslon board mafe me realise how sensitive specifically the overdriven Black Flat is for imperfect heatsinking, I really think that it is likely that something like that happened at the time.
I agree, but you never know until you try ;).
Which is the right one to order? Whatâs 5-pin vs. 2-pin?
https://www.arrow.com/en/products/luwhwqp-8m7n-ebvf46fcbb46-1/osram-opto-semiconductors
https://www.arrow.com/en/products/luwhwqp-8m7n-ebvf46fcbb46-8e8h/osram-opto-semiconductors
All the ones available on mouser and digikey are the 8E8H ones so go with that.
It also says new on arrow, so makes sense to buy the more recent one.
Of course I ordered the wrong ones in a hurry. :person_facepalming:
So, having seen some interesting results from new builds with the Black Flat I just ordered my first ones. Iâm thinking about putting 4 in the Sofirn Q8, any reason that wonât work? I donât need this light to be a lumens boss, but a throwy performance might be very interestingâŚ
They have a very small tab on the outside of each pad, positive and negative, these make up for the 2 additional âpinsâ so they call it a 5 pin. It mounts the same as all the XP/Nichia/Samsung 3 slot footprints. (got this on the data sheet)
