Another tip… Don’t go to close with compressor air gun when blowing out remaining silicone. Strong compressor could be to much for that tiny wires. Use it at least 20-30 cm above led and if you can aim minus toward plus size of emitter (so all junk will fell over + wires in single blow).
There is a bit of green on the very low modes but overall considering it started out as a unspecified XM-L2 CW with a blue tint, I would call the DD tint white.
After reading about the nitro thinner, since I had some laying around, I decided to try dedoming an xhp50.2 that I plan to put in a convoy L2. The results were better than I expected: in ~10 minutes the dome came off without leaving much residue (but it took a bit of phosphor with it) and while I haven’t tried it in a flashlight yet, the tint seems to have changed very little (this was a 3A) and the infamous yellow tint shift seems to be less evident than before. Though I’m not sure why that happened, I think it may be because of the thickness of the phosphor layer on the sides being reduced by the phosphor lost during the process.
When you de doming of hard core emitters you can leave them even more than 15 minutes in boiling thinner. When dome fells(and that happens very soon) it does not necessarily means that other silicone bits on emitter will fall they need to be cooked bit longer.
So don’t watch guys. Stick to my instructions and click stopwatch. But even 1 or more hour of cooking can’t destroy phosphor.
Nitro thinner sounds mean but it is not. If it is skin friendly so it should be phosphor friendly.
And one thing I can’t believe. That there are no paint thinners on some markets? Guys what do you use for thinning a paint before coloring something? With which solvent do you clean your painting tools, and even your skin after painting with color for metal surfaces?
Anyone dedome any XPL V6 1As recently? For me most of these emitters do not dedome easily using hot gas method. There remains a layer/chunk of silicone that is well attached to the phosphor. I end up having to carefully scrape this away and it’s not clean.
Hi, I made a dedom with thiner for polyurethane paints, with temperature in hot water, no flame, 30 minutes, but there were traces that I had to clean carefully, the result of the dye is just as thin in xpg2 s42b, greetings !!
Hi, if you use nitro thinner, or similar, it is thinner polyurethane based paints, difficult to determine, compared to convoy L6 N2-3A, it is greener and is a warm green, so I would say that between 3B-3S-3T, for My vision and use outdoors, it is quite pleasant, good depth, greetings!
I folded a small container from tinfoil filled it with some thinner, placed it on my hotplate, and put some leds in mounted on a ledboard. I soon found out that you want to be outside when doing that (headache now :person_facepalming: ). I checked a XM-L2, a 3rd gen Oslon Square, and a Nichia 219B.
Once the thinner was hot, the XM-L2 dome floated off in 3 minutes. Not all the silicone was removed after 25 minutes but the die was nice and clean.
When after 20 minutes (yes, I was impatient and curious) the other 2 domes did not spontaneously fell off (they did look far gone though) I gave them a gentle push and there they went.
The Oslon dome came off together with a clump of phosfor while in other places still silicon was on the die (probable cause: phosfor mixed in the silicone), dedoming without removing phosfor will not work like this (and likely never). The picture looks better than in reality: the remaining phosfor layer was of uneven thickness, the silicone broke off in a random way inside the phosfor area.
The Nichia dome came off with a clear layer of silicon left on the die.
When trying to pry off remaining silicon it became clear to me something that I did not realise before: also the Nichia phosfor is mixed with silicone but during production the phosfor-silicone mix is applied in a die-cavity first, filling it up, then the clear silicone dome is added.
So with these Nichia’s you end up with damaged phosfor or with a film of silicone on the phosfor. This is not different from a shaved dome.
In my case: damaged phosfor:
Conclusion:this is a very potent method (thanks l.i.), XM-L’s dedoming is peanuts, and with Nichia’s it worked way better than ever before with petrol. But it will not magically dedome leds that have the phosfor mixed in the silicone.
