I ordered 4 for $19.57 plus $5.79… can someone check if they are legit? Here is a link. Thanks
Those are the “new” ones. Hopefully they will be… They should be.
If you have a charger that will check discharge capacity, check them when you get them. That will tell the story… most of it anyway.
Thanks… hopefully they works great in two 26650 series. Else I may have to buy connector or solder blop…
They sell battery series connector for 26650 or 18650… about $1.07 each…
https://m.aliexpress.com/s/item/32667378904.html?spm=a2g0n.search-cache.0.0.70bc08b9AIi3tj#autostay
Your welcome. Maybe they will, on all the others I have some will & some won’t. No rhyme or reason to it either… just luck of the draw.
That connector is what I use on the one’s that need it. Only bad thing about buying those 1 or 2 at a time is shipping kills you …… :person_facepalming:
So I bought a handful of them last time I bought and the shipping was not much more than buying one.
If you want one PM me your address and I’ll send you one. :+1:
Thank you. I will pm you when I need it… by the way, they shipped out the 4x 26650 within 24 hours from AliExpress. I will update the delivery time and battery status.
Your welcome… my pleasure.
Wait till you need it if you wish, or go ahead & let me get it in the mail for you to have when you need it.
Really looking forward to the info on the “new” LiitoKala batteries when you get them too. :+1:
In case any of you still wanna bet on the blue winning horse, take a look here: C-26650 @ Colaier Direct Sales Store
Received a couple 30Qs from them two days ago, tad slow shipping yet all good in every other respect.
Some 5500mAh 26650 did come up a few month ago (can’t remember when or where, but same baby blue wrapping) and i would have expected LiitoKala to follow up…
Testing now a pair of blues from GB i received a couple month ago. No “F1” on the first line of label.
PS: Both cells came out over 5150mAh on my Opus BT C3100 at 1A - which is known to be a tad optimistic. Those are from the last batch GB was selling a couple month ago - they are out of stock now. On their pictures the cells had only one line of text above the bar code whereas the ones i received and tested have two.
+ 3.6V 18.0Wh F1 -
INR26650-50A VB15I19D 03327
I haven’t tried them in serie.
So far they look like the real thing - whatever it is.
Just ordered a pair of these Lii-50A 26650
Got the code here: Gearbest Official Deal thread (July 8th part 2 - code still works today)
When they arrive I’ll test capacity on my Lii-500 charger/analyzer and post the results here.
Thanks for the heads-up beam0, just ordered a set of 4 and will see how they compare to the pale blue ones I already have. Good deal with the coupon, nice catch!
Yep, appreciate the tip beam0… :+1:
I got four on the way. I’ll be interested to compare them with my originals also.
It probably won’t be anytime soon though… I chose Free Shipping.
No problem, yeah great price, hope they’re good. I finally went to order those blue ones and found out about the change over to these.
I did the standard shipping but I added the shipping insurance ($1.20) …probably should have got the 4-pack.
/\ …. :+1:
Just receive mine new ones, I can tell you that they can’t be connected in series and that they came with 3.8V in them. Put one of them for NOR test and I will post result here after finish.
Well… not quiet as good as the light blue ones it seems. But, still right at the rated capacity. :+1:
Thanks for sharing.
I don’t see any problem since capacity is as it says on the battery.
The only complaint for now is that they can’t been connected in series.
I can’t get my light blue ones in series either, it is close but the top is just a bit too shallow. A very low solder blob solved it.
The same is true of the regular ones, so no change there. I just add a solder blob.
I use magnets when I need to connect in series and batteries are flat top, this is just a notice that they could make it to be connected in series like some other factories that make same things like Keeppower or Sanyo.
