Eagle Eye X7, no mods, EVVA 26650 5200mAh button top.
Both springs overheated, lost temper and lost spring.
I tried to bluetooth a pic from my phone to the computer for attachment but couldn’t get it to transfer.
Doug
Edit: unsoldered the wires, looked for possible contacts between + and host, resoldered the wires. At first turn on there was no light but the springs were on the way to a second melt down. I suspect the driver is internally shorted.
I did a reboot of the computer and that fixed the bluetooth issue. Now when I try to attach an image I don’t a popup that allows me to go to my drive and select the image.
Yes you need to host the image somewhere, like tinypic or something
Then you have a link to it and it can be posted (please set width 100% while doing the posting )
If the springs fried before power on, short within the driver does seem most likely cause. Please let us know what problem you find on the top of the driver (or post a couple good close up pics).
EDIT: Nix the above. The switch would have to be On (or shorted) for a short in the driver or LED leads to matter.
You can always try running it without a reflector to determine if that is the cause of a short circuit. If that was the original cause, something else might have been fried but you may be lucky too
Welcome to BLF jr2017, right on!
It reminds me of the Coneta, 26650 with a wide +top could short because the driver retainer ring could touch the cell creating a dead short.
