Great work. Now you have a light to be truly happy with, and very proud of.
Iām very proud of seeing someone mod an AA cheapo. Iāve been feeling like doing just that lately.
i love that, but there is still room for bigger driver, i think you should use high power driver, or driver that can support 14500/AA
Ok, 5 more modifications I did to this cheapo flashlight.
1. Updated the tail spring with a solder blob to have a better contact for the battery since it seemed there was a hotspot previously (AA Flashlight Wire Advice). Left is the old spring bypass, right is the new.
2. Put thermal compound between the LED MCPCB and the copper cap.
3. Drilled another hole for the lanyard to help with tail standing.
4. Replaced the plastic smooth reflector with an orange peal aluminum reflector and 5. Replaced the plastic lens with an anti reflective glass lens. Also noteworthy, I used an LED insulation gasket due to the aluminum reflector and put an o-ring between the lens and reflector to help with water resistance.
With the new reflector and lens, the beam greatly improved. Left is the old modified flashlight (notice the rings), right is new.
Hereās a close-up of the beam.
It is still my favorite flashlight around the house, even more so with the improvements. There are no more mods that I want to do with the flashlight. Thanks BLF for all your help!
Nice work. These types of lights with the plastic pills are extra challenging to modā¦.
I agree with ima4whlr ā¦Cheap lights can be much more difficult to mod .
The trick is picking more mod friendly lights
Cute light, nice job. :+1:
In case you were wondering (I know I was), here is a break down of the costs.
- Driver - $1.99
- LED - $4.79
- Copper cap - $0.38
- Switch - $0.79
- Reflector - $1.69
- Lens - $1.57
- Insulation gasket - $0.25
- O-ring - $0.35
Total = $11.81
Luckily the labor was free. :money_mouth_face:
I donāt think this even qualifies as cheap anymore, does it?
Thanks for sharing NeutralFan!
Iām willing to make a mod in a 18650 light that has more or less the same characteristics, and this helped to get some ideas, both for the pill and the switch!
But like you, it wonāt get cheap to make all the changes, so that wonāt be a ācheappoā light anymore!!
Nice work :+1:
Agreed. I started off with trying not to spend too much, but the incremental results were not enough, at least not for me. Iām glad it turned out well in the end since numerous times I thought about cutting my losses and throwing it back with the others.
Glad I could help. Let us know how it turns out.
I will for sure It will be me my first mod! The pieces have been ordered and they are on the way. It will have some flaws, but it will be a start!
I got some questions for you, if you can answer please.
1 - Between the switch and the battery, did you put only the plastic holder you had or did you add another āplastic ringā?
2 - In your case, you had to break the longer metal tab of the swicth and then added and soldered the wire. In my case I guess I wont have to do that as the switch fits well, so the longer tab will be there. If I solder a piece of wire between the tab and the top of the spring, will it be a spring bypass? What dangers can I bring to the light and battery if I do that?
3 - The rings in the beam you showed above (18th June) , they existed before using the insulation gasket, am I correct? If so, using the gasket will help to avoid those rings in cases where the light reflects in the bottom of the reflector? I guess I should have ordered some :person_facepalming: I think my light will have that problemā¦
Thank you once again !! :+1:
Best regards!
Hi MascaratumB, Iām sure youāre getting excited to start your mod.
For the switch, I only used the plastic holder. With the bigger switch in the holder, I had to press very hard press to get it into the tail, but that also helps keep it in place.
Yes, soldering a wire from the tab to the top of the spring will be a spring bypass, but only 1 tab should touch the side of the flashlight else it will always be on essentially bypassing the switch.
I used the insulation gasket when I got the aluminum reflector. The cheapo flashlight came with a smooth plastic reflector so it didnāt need the gasket. The gasket helps prevent a short across the LED. The rings came from the original plastic reflector which was designed to work with the original LED. I tried experimenting with the plastic reflector height here: Mod Advice For a Cheapo Flashlight, but wasnāt too successful.
Chuckle. Now you can replace the battery tube to use a bigger cell ā¦.
āThis is my grandfatherās axe. My father replaced the handle. I replaced the head. But itās still my grandfatherās axe ā¦ā
Good thread well illustrated. This is what itās all about.
Very nice, thanks for sharing !
Which driver did you use ? I suppose you wanted to stay with eneloops, not Li-Ion 14500, correct ? Boost driver are not easy to find these days ā¦
Thanks for your answers NeutralFan!
Yeah, Iām getting excited with my first mod. Actually, I guess Iāll be doing 2 mods in a row! Iāll post them after theyāre done
Hum, I guess Iāll have to add someting on the switch to get it tighter!
I also had to sand it a bit, like you did, and now it is a bit loose. Maybe a plastic ring above it! Would a metal ring (that might get in contact with the battery bottom) be better or worse?
Thanks for the info about the bypass! I guess I wonāt have to make it because everything seems to be in the right place, so far! :+1:
So, about the gasket, itās not only about reflection but also the short that may happen! Nice to know, I want it to be safe to use and not to damage the emitter or LED or whatever may get damage
Iāve looked at my order and I ordered insulation gasktes so I may restā¦ for now!
And yeah, that first āmodā in the reflector wasnāt that good! Thanks for the warning, it might be a thing Iād do just to get things fit!
We learn from each others good and bad experiences, thatās what I like here on BLF!
Once again, thanks for sharing!!! Nice work!! :+1:
Hereās the driver I got from Mountain Electronics: Lumintop Single Board. That is correct, I wanted to keep it an AA flashlight.
As long as the metal ring does not come in contact with the spring or the negative terminal of the battery, you should be fine else again you would be bypassing the switch. Seems it would be safer to use a plastic ring.
Hum, I guess it might be in contact with both (spring and battery)! Iāll add a plastic ring instead, it will be safer.
Thanks for the information once again! :+1:
Best regards!
