FS: CHEAP LEDs, drivers PCBs and more.
Hi all, It’s that time of year again.
USA Shipping is $2.85
World wide is more than the stuff would be worth.
Paypal is asflashlights@gmail.com
Brand New XP-L HI V2s on 20mm Noctigons $4.88 each (19 available)
Brand New XP-L HI V2s on 16mm Noctigons $4.88 each (17 available)
32mm pcbs for 3 XML/XHP50 in parallel $0.50 each (11>8 available)
45mm pcbs for 3 XML/XHP50 foot print in parallel. $0.50 each (18>17 available)
17mm pcbs for Alex Wells Mosfet driver $2.50 for all 8pc
New XPG3s 90CRI $1.50 each (8>4> ALL SOLD)
32mm 3x board shown is used but working $3.50
New FET+1 drivers from banggood $3.88 each (11>8>6>5 available)
Some other buck drivers?? Probly 3 mode, Probly 8.4V $1.50 each (4>2 available)
Used maglite stuff. The LEDs on the 2 outer ones work, the one in the center I don’t know. $5 for all three ALL SOLD
Pile of used LEDs free with any purchase :slight_smile: ALL GONE
To bad shipping kills it for me.
Do you know of a source for XPG3 90CRI that has acceptable shipping costs to Europe?
Good luck with the sale. Some interesting things here.
He dekozn,
The only place I know to get them is Cutter Electronics. Their shipping is pretty high, unless you order big $.
Do you know the output rating of the buck drivers? Probably not?
Will take 4 XP-G3 5000k, 2 A6 drivers and pile’o’leds!
Thanks Matt
If I remember correctly they were sold to me as being 3 amp, but actually only output like 1-2 ish. There is a sense resistor you can stack chips on, but they really only perform at a decent current if your near to top end of the voltage range. Basically 2 li-ion with a 3v led.
Ok thanks:)
What is the tint on the XPL-Hi?
They are 1A tint.
I’ll take
32mm pcbs for 3 XML/XHP50 in parallel $0.50 each - 3 pcs
45mm pcbs for 3 XML/XHP50 foot print in parallel. $0.50 each - 1pcs
New XPG3s 90CRI $1.50 each - 4pcs
New FET+1 drivers from banggood $3.88 each - 1pcs
Probly 3 mode, Probly 8.4V $1.50 each - 1pcs
PM please
fonfan I put 2 of the buck drivers in your package. One is new and the other is one I used for testing, it has some extra sense resistors already added to it.
bump.
