It seems “ramping” is not clear enough to describe the concept. It is unrelated to heat or power regulation. It is an interface style.
The Meteor has 9 brightness levels (plus short transitions between each):
4mA (UI1 1A, UI2 1A, UI3)
60 (UI1 1B, UI2 1B, UI3)
500 (UI2 2A, UI3)
750 (UI1 2A, UI3)
1000 (UI2 2B, UI3)
2000 (UI2 3A, UI3)
3000 (UI1 2B, UI3)
4000 (UI2 3B, UI3)
8000 (Turbo, UI3?)
It doesn’t offer 20mA or 200mA, for example. Those are between the stair steps.
Narsil (as used in the BLF Q8) has 150 brightness levels, a smooth visually-linear progression from about 2mA all the way up to ~20,000mA. If I understand correctly, the D4 uses the same smooth ramp as Narsil. It is similar to how the SWM V11R works, or the Jetbeam RRT01, except it uses an e-switch instead of a magnetic ring.
This makes modes and mode groups irrelevant. There are no stair steps to arrange into groups. Instead, simply hold the button until it is bright enough. It can be set to the exact level desired.
Mode groups can be implemented for those who prefer it, and Narsil includes a UI which uses mode groups. But the smooth ramping UI is simpler and people seem to prefer it so far.
This is how the Meteor’s levels compare to the Q8 and D4, in graph form:
No. You or anyone else still not able to answer my question.
Your graphs are shown as lines. For q8 and d4 they should be extended and drawn as big area (and you are not able to say in which point will it work actualy). Thats why q8 will be hard to sell over $40 price - if seller will claim some output and runtime numbers, lots buyers wont see same numbers in own tests and some of them will open cases and ask refunds. Like led lamps from ali - you never now how much power they will consump.
The graph above could be viewed as a slice of a larger 3-dimensional surface. If a time dimension was added depth-wise through the screen, it could be used to show runtime graphs.
For example, take one X value on the levels graph above. Let’s call it 60% max brightness. If it extended back through the screen, it might look something like this graph selfbuilt made: (green=Meteor, red=Q8, purple=D4)
This isn’t the best representation since it’s for a completely different set of lights, but I hope the idea is still clear: The Meteor has better output regulation on medium and high modes, so it looks almost flat. The Q8 and D4 have only partial regulation, so the output follows a gradual curve over time.
This depends on the output level though:
On low modes, there isn’t much difference because both methods are regulated on low.
On turbo, there isn’t much difference since they’re all pretty much direct-drive.
On medium and high modes, the Meteor’s flat regulation is significantly different than the FET+1 driver’s partial regulation. However, on a small light like the D4 these modes are generally limited by temperature, so the output depends on thermal regulation rather than power regulation.
This regulation difference is something people can’t easily see during use. If output slowly drops 20% over a period of 2 hours, it’s virtually impossible for a human to notice without a lux meter. However, the interface is something people notice right away, so it might be a good idea to prioritize interface over regulation if a tradeoff is required. The SWM V11R was a hugely popular light because it had such a nice smooth ramping interface, even though it was notoriously bad at regulation.
Anyway, nobody knows the details yet, so instead of saying rude things about it based on speculation, let’s wait until reviewers have a chance to try it.
I don’t know all the details and it’s not my story to tell but, from what I’ve heard, this quote might be more true and more unfortunate than Serp intended. A big part of why I make everything open-source is to make sure nothing has to depend on one developer.
One thing is certain though — Intl-Outdoor is not Astrolux. Hank doesn’t sell badly-designed junk like the S42.
2 hours? 20% drop? Are you sure?
Several messaged ago you was not happy with steps in m43 ui. Now you understand that smaller steps are not reasonable by eye.
And no, you cant show all factors in 3-dimensional graph because cell internal R and discharge curve are not same. Ramping fet is smth very strange. You are trying to manage some parameter that you havent calculated and dont know exactly its value right now.
P.S. Im not against cheap custom drivers, Im not going to share links to foreign forums and make adv. for developers that wants $30 for one driver. I just dont like when programmers making hardware developments (and vice versa).
P.P.S. Cell voltage and R can be tested each time you turn switch on and some standart discharge curved can be used to make lower modes (50% and less) more stable (compensate cell discharge).
While I definitely prefer boost drivers with stable output to FET drivers, I have never seen the combination of:
Good efficiency
High maximum current
Ability to fit in a pocketable light (let’s call that about 20mm driver diameter)
Low price
It’s usually 2/4. Zebralights, for example are small and efficient, but they’re not hot-rods by BLF standards and they’re pretty expensive. The Haikelite MT01 using the off the shelf LD-35 boost driver is cheap and efficient but doesn’t come anywhere near fitting in my pocket, nor is it capable of a lot of output for a 3x18650 light. The Meteor might arguably hit three points: it’s a good value for what you get, but it’s not cheap in absolute terms.
A compact triple with a high-current boost driver would be awesome. Wait… that exists, but you’ll pay through the nose for anything from Lux-RC. The D4 costs $35 and I’m fine with a FET driver at that price point. If anybody would like to bring the Indigo driver to market outside Russia and can hit a competitive price point, I’m sure BLFers would be interested. I, for one need more Nichia 144As in my life.
I personally don´t care about the driver type in the new D4 - I want the most lumen out of it in turbo mode (hopefully nearly 4400 lumen in the XP-L HI version :smiling_imp: ); batteries can be recharged!
I didn’t try to put all factors into one graph.
A 3-dimensional graph can show 3 factors. In this case:
X = brightness level in UI (1-9 of 9, or 1-150 of 150)
Y = lumens
Z = time
I’m not trying to regulate flat lumen output in firmware at all, and I don’t think the D4 firmware does either. I don’t care much if output sags over time. I do try to regulate heat though, because I don’t like to damage the hardware or burn the user.
The firmware could attempt to do flat current regulation on a FET, by increasing PWM level or decreasing PFM ceiling as voltage drops. I’ve done it before. It’s complicated and fragile and not very effective. I don’t find it worthwhile. Current regulation is better handled at a hardware level.
As far as I can tell, the D4 should have high maximum current, ability to fit in a pocketable light, and low price. The efficiency isn’t going to be as good as a Zebralight, but it should be significantly better than a FET-only driver. So… 3/4 maybe?
Does anybody of you use lights except for wow - effect?
As already said this host can carry 5-7W for long time. With 10-15W consumption it would be hot like zebra on turbo. With 20W+ it would be an useless toy. I have 30W pocket light of similar size and overheating(65C) occurs after 17 seconds.
A price of Skilhunt h03 with buck driver is obout 30$. So D4 with dd , pwm and unknown output (becouse of rumping) is only quite expensive host for mod.
After M43, D4 is huge step back for Hank. I understand that d4 is already in production but I hope to see good drivers in the next Hank s light.
The Meteor is called Noctigon MEteor, and is sold as a semi-high end flashlight with a rather high price-point…
The D4 is sold under Emisar brand, at 35$ for a quad… you can’t expect the same level of technology/efficiency/Russian eforums exigence…
Please, Russian fellows, give us the secret to make 35$ flashlights with magical boost driver fully relgulated at all levels
The good thing is that no one forces you to buy it ….I do not understand your disgust, if something I do not like I do not buy it and I do not walk all day complaining ….
I like this price at what it offers, so I will buy one. The good thing is that no one forces anyone to buy anything.
(of course, I will buy it only if Hank decide sell in his store….)
M43 also had a price of a mid-range flashlight when it was relised. I dont want another zebralight.
I was waiting for good 4led light with good modern driver for adequate price.
