Wow, I bought the last remaining 219C in black I think…thank goodness for impulse buys xD
I actually am not sure. I haven't used the light a lot. Tom E. should be able to fill in all of the details on the firmware...I wasn't provided with a full list of the functions.
looking forward to some reviews of this light……
Wahoo! Got a shipping notice for the D4’s pre-ordered and a shipping refund …. two orders were combined into the same shipment.
I was unusually indecisive selecting an LED for the green version. The 219C sold out so fasssst in green that I was unprepared!
Thanks very much for the pre-order setup and such speedy turnaround upon your receiving them, RMM! That is stellar performance!
Richard, do you have any Meteors on the way?
Colors?
Thank you
Yes, I have some on order in white in every tint that should be arriving here any day now. I also am going to get more black, but they were not available yet when I placed my last order.
Will these fit the Convoy L6?
Probably not if they are big.
Unless l6 has changed
Probably not if they are big. Unless l6 has changed
...and they don't work well in series.
Making them work in series is easy enough, but if the cells are too wide for the L6 tube that is harder to fix. There is apparently some variation in the L6 tube ID. See here for some discussion: Convoy L6... XHP70 Beast! - #3980 by vestureofblood
The liitokala 5000mAh cells are also wider than a typical 26650.
From the discussion in the above link, some new keeppower cells were very wide at 26.9x mm, and these did not fit in some of the L6 tubes. I think people have used the liitokala cells in the L6 with no problem so I would think the shockli cells should work as well.
I do know that some of my customers have had the protected 5200mAh cells fit in their L6s, but I know that the initial copies that I tried them in definitely did not fit. There is indeed some variation in almost all Convoy tubes.
I use KP protected.
The gap i 0.00000mm airtight fit.
Richard,
What is the lumen output of the D4 and when do you expect the Aspire 18350’s to be available? I want to order a couple Shockli’s and a D4 and it would be great it I could order some of the Aspires at the same time. Thanks
Are the D4’s expected to be restocked at some point in the future?
Did you read the product page?
"We will have more stock in just a few days. Hang tight! "
Richard, What is the lumen output of the D4 and when do you expect the Aspire 18350’s to be available? I want to order a couple Shockli’s and a D4 and it would be great it I could order some of the Aspires at the same time. Thanks
I do not know the lumen outputs. I haven't tested them. They should be the same as any other direct drive quad flashlight --- 3,000+ (for a few seconds, anyways).
Aspire batteries should be here soon. They have shipped, but as many of you may already know they have rebadged the "1300 mAh" cells to a more realistic "1100 mAh" battery. It was very kind of them to tell me that after the order had been placed for almost a month and had already shipped.
That sounds good. I will place an order as soon as they get in. Are the Shockli 5500mAh batteries a lot thicker than the Liitokala 5000? I know that they are a tight fit in my SD26vn, but I would most likely use them in my U21vn and EC50vn anyway.
Ah, I only knew of the length issue with some batteries. I didn’t realize there is also an issue with some oversized cells. thanks guys.
Is it possible to stock the XHP35 HI E4-3C again?
Just got the D4’s. My first ramping lights, I like them.
The Nichias get extremely hot within seconds the same with the xpl hi the s4 2b is a little better. With the 18350 they are measure 2.5 inches very short, me likes.
