Thanks ! Haha i canāt really remember itās name , but i will reply here when i do
Also , updated in the first post the output/time diagram , on the highest brightness of the ramping mode . Over 90% of the total output (about 580 otf lumens) for about 110 minutes ā¦
With the provided 3400mAh battery , it rattles but only a little . Maybe with unprotected and/or slimmer batteries there is a biggest issue .
Does the switch stay lit in all cases?
I prefer the battery indication to signal on activation then turn off, for all battery states; signal intermittently (say every 10 seconds) during use only when the battery is below 25; every 5 seconds when the battery is below 20; then not signal during use but step down the output when the battery is below 15% to prolong remaining runtime.
Great price but I still donāt want to risk getting a green NW.
Mine arrived today. So far Iām really liking it. It runs fairly hot in the turbo mode, but not hot enough to be of any concern. I havenāt measured battery life yet on the Efest 900mAh 18350 Iām using, but it does seem to do pretty good. The tint is supposed to be cool white, to my eyes itās closer to a neutral white
Not having the electronic lockout doesnāt bother me at all since I will not be carrying this in my pocket. Its purpose is a general around the house flashlight. It will get used often
Iāve been using mine for 12 days now and still very pleased with my purchase. Yesterday I received 2 Aspire 1100 mAh 18350ās in the mail. Tested them and they exceed their ratings, 1027 and 1080 mAh on the first discharge cycle. Installed one in the 2C. If I have time tonight Iāll do a rundown test till I get a solid red low battery indicator.
No problem. Iām testing it now. Hopefully, Iāll catch it when the indicator turns solid red.
P.S. There are no 18350 dealers that ship to Greece?
Results: 2C started on turbo. At some point, it stepped down to high. Not sure when it stepped down, but I left it that way. Battery used was a fully charged Aspire 1100 mAh 18350
22 minutes to blinking red
29 minutes to solid red
At that point I shut the 2C off. Itās now recharging via the USB port
Obviously, an 18350 doesnāt come close to a 3400 mAh 18650. For me itās worth having a shorter version of this light even though the runtime is much less.
