I just tried it and I got no blinks.
But those damn nichia really heat up the whole body but more so the head….Love it.
4 quick clicks gives lockout dont know how to get out of it but i did.
3 quick clicks battery voltage.
I was in a mode that was stuck in low mode would not ramp either way. Dont know how i got there but i got out somehow.
I just did 4 quick clicks waited a few seconds then clicked and held and i had momentary at the highest brightness. Then i did 4 quick and it gave 2 quick blinks and i was back in ramping mode.
Time to recharge….i think the Aspires will be the choice in the 18350 D4.
How hard do I have to study to get my D4 to just turn on high?
4 quick clicks should lock out as well as unlock it. It will give 4 weak blinks whenever you lock or unlock it.
Do you mean high or the highest “turbo”?
Double click from on or off should do that (turbo).
Or if you turn it off at the highest, one click will turn it back on in that same brightness. So its pretty easy.
I tend to go to highest, then ramp it down just a hair and leave it there. This gives you like 90% brightness, but longer run times and less heat.
If it’s memorized to come on a really high setting and you want to turn it on at a low setting, just turn it on by pressing and holding. This will turn it on in moonlight and begin ramping up. It’s good for when you don’t want to mess up your night vision.
:party: Welcome to modern flashlights! :person_facepalming:
Thanks — mine should be here early next week.
First time i tried 4 clicks i got to lockout but i dont know how i got out of it.
Now i cant repeat the lockout as it now gives me momentary at its highest brightness.
And yes, double cluck from on or off gives turbo.
I turned it off at its highest then turned it back on and it goes to lowest.
Maybe im doing something wrong.
Assuming memory is turned on, just ramp it up to where you want and turn it off.
If you are at the lowest, for example, then double click to get turbo, then turn off. It will have the lowest memorized. So try ramping it to where you want.
How do you get into memory mode?
I’m not sure memory is turned on by default. The narsil cheat sheet posted earlier says it’s turned off by default at least for “modes”.
Maybe I turned memory on for my light? I can’t remember.
Memory is a setting you can turn on and off depending on whether you want it to have memory.
On my light I hold the button for 8 seconds and it does the fast double, then 1 blink, pause, etc…
When it gets to double, then 5 blinks I click the button twice. It will blink twice to confirm, (on setting 5, 1 click is disable and 2 clicks is enable and it shows 1 is default) then you can let it finish going through the rest of the menu.
I avoided the complex UI’s for a long time because my memory is so bad. With over 100 lights, it’s difficult to remember which has which UI. But of course now I have Narsil and Bistro and Biscotti and Guppydrv and the Nitecore mismash and and and…. I try to download pdf owners manuals and UI guides so I can refresh my memory if I am using a light that’s tricking me. The cheat sheet is a good idea, if I can remember it’s under the tail cap. lol
I love ramping, so I haven’t changed my Narsil light to date.
Ahhhhh…got to give it a break….the 8 click thing does not work on my lights.
Here is the cheatsheet again for this page.
I think you mean click and hold for 8 seconds to get into the menu.
I hear ya.
I try to take pictures of the pdf and keep it on my phone. That way I always have it.
On my L6 with Narsil I tried out the modes, but ramping is way better. The only thing I remember trying to change in the menu was to turn off all strobes. Unfortunately you can’t when using ramping, it’s a glitch. No big deal though.
I got my driver from Lexel, so he must have set my memory to “enable”. I don’t remember doing it.
I forgot what thread I was on. I didn’t post my video here. Check it out. This shows some narsil basics.
I plan to make a video showing the menu setup, but haven’t had time yet.
