Yes that 3x42 âsunnrangerâ I build obviously had non appropriate coating for light build.
I just build and compare with commercial available stuff on lux meter. And of course âwithout-withâ lux meter lenses method for reflectors. And not that I tried super coated lenses cause beside China available stuff KD and similar I did not have chance to try any better.
So please recommend where we could buy or try VIS cated lenses?
âAn AR coated lens will always outperform a non-AR coated one if it is the correct type of coating.â
That is probably true. But how to know if we have right type of AR coating? And did you try any form of acrylic lenses?
Edit:
I just saw you linked that Edmund lenses. Well at cost of more than 30$ with shipping they are bit expensive? But I guess only for personal and exclusive builds it is worth a try. Can we find something good and cheap? This is BLF and did you try any form of acrylic lenses?
Another one:
âReal night vision gear costs thousands of dollars. â
LOL⌠Wait when our member Seedstar sees thisâŚ
Imho you can make ârealâ night vision that will be same in performance as those expensive one at fraction of price. You only need high quality ccd or cmos sensor + quality camera lenses and bit of creativity. If you donât believe me join to nightvisionforumuk.
I posted two links above, one is for glass and one is for acrylic.
Both are VIS AR coated.
If you get your lenses from flashlightlens.com then they are all made for VIS spectrum.
BTW weâre talking about plano-plano lenses here, also known as optical windows. Thatâs what the maxabeam head has on the front of the reflector.
But the same stuff applies if youâre using plano-aspheric lenses for a lens thrower flashlight.
Never tried them. I would assume they are VIS AR coatings if they are made for flashlights.
Probably much worse quality though than the type of stuff you get from edmund optics or flashlightlens.com.
It is certainly possible that a crappy AR coated glass lens has worse transmission than a high quality non-coated acrylic one, you never know with that stuff from china.
This is why I try to get my stuff from more reliable sources like high end optics manufacturers or mountain electronics and places like that.
Edmundoptics is serious manufacturer while flashlightlens is distributor of quality stuff? Shipping is something that will kill most of users that are not from USA.
So acrylic lenses can have 97% of transmittance and they are probably more durable than glass one.
My acrylic lenses I use as preccolimator in aspherics seems to have 100% of light transmittance without AR coating??? How I stupidly concluded that? Cause without them or with them I have same result on lux meter(with them I have 100% larger beam of course)
And sometimes they are even scratched but it seems that they do not loose on performance because of that.
I want to say acrylic or plexiglass(I did not tried plexiglass yet) is worth a try weather for plano plano or plano convex?
And that middle thing on this The Driver build is something similar that MEM want to try before he disappeared. He told me he can find a way to fit RA on reflector lights and enhance a throw.
Thanks Dale, that clarifies things, feels strange though, so to reduce spill people could stick something on the GT right in front of the led
Well The Driver scratch my input on making a lens yourself then. Besides I can understand that with this build you want the best you can get
Are you talking about some other flashlight? Not the maxabeam you just built, right?
The minimum order quantity for a custom size lens is 100, so even though each lens might be cheap it ends up costing hundreds or thousands of dollars.
A custom 100mm lens at $.15 per mm is $15, but with a MOQ of 100 it becomes $1500âŚ
Cheaper to buy something from edmund optics TBH.
Yes, flashlightlens.com is a distributor of quality stuff. They have been around since 2002 and only sell lenses for flashlights. They, as far as I know, bascially invented the concept of the âUCLâ (ultra clear lens) for flashlights. They also sell borosilicate lenses, which can tolerate high temperatures. Many people on CPF used these for hotwire lights for many years.
Well yes and no. They are a bit more durable because they donât shatter, but my lens cracked in this light. It was my first very big lens. Before I had UCLp lenses up to 75mm.
Your light meter might not detect small differences correctly.
The reason is probably something else though.
The precollimator corrects for the imperfect shape of the main lens. Normally you would loose 7-10% of throw because of the pre-collimator. but you donât loose anything. This means that the pre-collimator is âmaking it easierâ for the lens by making the LED âseem biggerâ. I hope you understand what I am trying to say.
Well glass will always be better if it is high quality. So you just need to test I guess.
A reflecting collar could work, I think. The increase in luminance would not be as dramatic as when itâs used in a lens light though. In a lens light ~70% of the light is available to ârecycleâ, but only ~30% is available in a reflector light.
Iâm actually thinking maybe reflector is the way to go for ultimate throw.
Lenses have a lot of chromatic aberration which almost certainly reduces the lux.
The problem is that to get the best throw, the LED intensity needs to be extremely high, and the wavien collar does massive improvements to that, over 2x.
In order to use the collar with a reflector it would need to be a recoil reflector, not a forward facing one like in normal flashlights.
Then the problem becomes the LED + collar blocking a bunch of light from the center, which is the most intense light, thanks to the collar in the first place.
The solution:
Off axis parabolic mirror!
-no chromatic aberration
-no blockage of light in the middle
-can use a collar to get over 2x LED intensity
Problem is that it would cost several thousand dollars but still, Iâm pretty sure this is the BEST method of getting maximum throw per diameter (with an unlimited budget).
In theory yes, but think about it again. You would be blocking the reflected light of the reflector.
The Maxabeam Reflector used here has a 40mm âdeadâ hole, when used with LEDs. So that is the maximum diameter which the âreflecting collarâ (this name doesnât really make sense here, it doesnât go around the LED) could have. The distance of the reflecting collar will then determine, how much light it collects from the LED. It would need to be just far enough away so that the light of the LED can hit even the outer edges of the reflector.
Of course most of the spill light will pass through the reflected light of the reflector and will thus never hit the âreflecting collarâ. So in reality there is hardly any gain to be had here, maybe 5-10%.
Endermanâs idea to use an off-axis (main) reflector would work much better because more light can be collected without blocking the beam, but it will never be perfect and the light would probably look rather weird.
MEM from this form(inventor of that wavien collar or RA- reflective aperture how he calls it) wanted to try different approach to led reflectors and he called that RRRâŚ
So i will quote him â âThe Recoil Recycled Reflector. Fitting? It is essentially a recoil format, in that the LED directs light directly into a âbarrierâ that ârecoilsâ the energy back through the phosphor, ârecyclingâ output back out to the âreflectorâ â
And you are probably right with this mirror idea cause he wanted to fit as I managed to see flat smaller diameter mirror. So his idea should really work but centering the mirror to the right distance to led will be nightmare.
Edit: He mentioned that XPG3 would be most suitable emitter for that because of all unused phosphor surface!
I think a spherical reflector could be designed to capture all of the spill light for most all reflectors with typical width-to-height ratios.
Below are some rough to-scale sketches of what I am thinking.
The top reflector is a C8 reflector with 38mm active diameter, 32mm height, and ~12mm dead hole diameter. The bottom is a convoy L2 reflector, which is a bit more relatively deep, with 54mm active diameter, 50mm height, and 16mm dead hole diameter.
Letâs constrain the diameter of the spherical reflector section to be the same as the dead hole, so no light from the reflector is blocked. Then the optimal position for the spherical reflector would be as in the sketches, to just allow the LED light to reach the edges of the reflector, but capture all of the would-be spill light. Then the radius of curvature of the spherical reflector is chosen to be the same as the distance separating the LED and spherical reflector, roughly 12 and 18mm in these examples. (Iâm approximating the LED as a point in these sketches for simplicity, but I donât think a finite size LED would completely change the picture.)
I think this makes sense. Have I got something wrong? :sunglasses:
