I like the overlapping faces better
Most people do care quite a bit in my experience, thank you for being so chill about it.
I’m basically done and am putting on the finishing touches now. If I want to flesh out some details (like MSRP, official pages, and paired bays) it could take the rest of the weekend.
I’ve found a few minor typos: the Fenix ARE-X1+ has backwards battery diameters. The JetBeam i4 Pro and TrustFire TR-001 have backwards lengths. The Ikea Veinninge has “0.02 amps” for the “max all slots” current.
edit: The HG-1206W has 0.3/0.6/0.6 for the currents which is weird but I think I understand what is going on there. The BT-C100 has 1.6 for “max all” and 2 amps for “max single” which seems weird for a single-bay charger. What is up with that?
It is the internet, I have no way of controlling my data. In my opinion the best way is to let people use it and ask them to credit me (with a link).
And some hours every week from no on (Prices changes).
Thanks, I have fixed it.
Errors was unavoidable when typing in data for nearly 200 chargers.
The 1206 has 0.6A, it can be delivered to a single cell or shared between two cells with 0.3A for each.
The BT-C100 is a bit problematic, probably 2A in both field are more correct, but it is only valid for NiMH.
Found one more typo, the SC-C5 has the wrong chemistries listed.
So I feel the prototype is ready for you guys to take a look at: http://chargers.parametrek.com
I’ve added three requested features already. Whether or not a charger is enclosed, common cells that should fit, and how many channels a charger has. Though I was only able to find 4 that didn’t have the expected number of channels.
Next I’ll be adding MSRP information. Or maybe buying a new charger
HKJ, I hope you like how it is looking.
That was bad, my generator swapped two chemistries, it is fixed now.
What do you mean by channels?
Same thing that you mean by channels in your reviews. If a charger can only do pairs of batteries, then it has half as many channels. Hank had asked for this information to be included so I put it in.
Number of channels and doing batteries in series is not the same thing.
The Ikea 12 slot charger has two charge channels, but do not do batteries in series or change the charge current depending on number of batteries.
All chargers where the current is red do AA/AAA batteries in series.
Henrik, it’s incredibly helpful having all your reviews in one place like this. Your reviews are always the first place I look when considering chargers or cells. :+1: Thank you!
About the only thing I can think of that would be nice to have (perhaps this has already been mentioned?) would be the ability to sort by column. I’d sort by rating and once below a certain score I know I’m not interested. I must admit I was confused a bit at first by your rating system at first, particularly the overlapping faces. I would have suggested the one and a half face thing too but I hadn’t scrolled down enough yet to see your scoring system was explained at the bottom. Maybe that could be at the top instead of the bottom? Anyway, once I understood the scoring system I too now like your half hidden peek-a-boo face for the “fairly good” ranking.
If you don’t change a thing I’m certainly satisfied with this and I’ll be referring to it often.
Oh and Parametrek, I like your take on arranging all this too. Adds a nice bit or sortability. :+1:
Excellent resource and very informative. I was considering a Folomov A4 after seeing them in the Illumn email today but don't see it listed in the chart, unless I missed it in the 3 times I went through it.
No, I have never seen that charger.
Browsers usual has a page search function (Often Ctrl-F) that makes it easy to check a list.
Awesome HKJ!
I want to thank you for all your efforts in testing. I base most of my buying decisions (cells and chargers) on your thorough work!
You also do a very good job in educating people about the workings and save handling of batteries. I personally learned a lot from your website and your test comments.
Thank you!
+1
Typo? Shouldn’t the Xtar SV2’s max single slot current be 2A, not 1A?
Thanks for a fantastic resource.
Yes, is should. It is fixed now and thanks for the help.
There seems to be a couple of inconsistencies with charger test reviews. I would like to see more consistency in the reviews so a better and more logical comparison between chargers can be made.
The first inconsistency is that the 2500V and 5000V isolation/insulation test is either not done for some chargers, or if it was done, the results of the tests were not mentioned in the reviews. These test results should be mandatory for all chargers with results of those tests posted, please.
Second inconsistency is that really "old" batteries are not always tested, or if they are, the results of those tests were not mentioned in the reviews. It is important to see how chargers handle older batteries/cells as well as new batteries/cells. Again this test should be mandatory with accompanying test results in the reviews, please.
Also, some chargers have updated firmware which may address any issues shown in test of chargers with earlier versions of firmware. So chargers that have updated their firmware should be retested with the latest firmware, please.
Ideally, all charger reviews should be revised/updated where necessary to add the 2500V/5000V tests, plus the testing of really old batteries/cells, and chargers with latest firmware should be retested also.
Thank you.
These test are not relevant for usb powered charger and I did not do them before I got equipment to do it.
I may forget it a few times, if I get reminded about it I will do it, if I still have the charger.
I can only do test with old batteries when I have old batteries. Sometimes batteries gets to old and are removed from the test set.
Usual I do not know when chargers get updated, there is also an issue about time used to test a charger. For some of the more advanced chargers it can take 3 weeks, I do not not wish to retest that very often.
I do not keep all the old chargers, this makes it impossible for me to do more tests on them. Often I have new chargers to test and I prefer to use my time on them.
Thanks for the prompt reply.
It is appreciated that some time is required to (re)test chargers, but to make a meaningful comparison between chargers the same full range of tests should be applied to all tested chargers as far as possible.
One of the important aspects of chargers is their ability to recharge older batteries/cells. So the use of older cells in these tests should be standard as part of the tests. Certainly some old cells get "retired" eventually, but surely other similar older cells could be made available for testing instead!?
There are still a lot of older chargers available for sale which have since had their hardware and/or firmware upgraded which would most likely produce different test results compared to the earlier test results.
If a previously reviewed charger is no longer in your possession, then surely you could request another updated version of the charger be submitted for review!?
The ISDT C4 charger, for example, has had several revisions of its firmware (now at 1.1.0.6 I believe) since the initial test review. It would be very useful to see improvements (if any) have been made to this charger!
Most of the time I have old cell, but how old varies a bit. With LiIon the 18350-IMR has been used for many years on all chargers. With NiMH it is usual a 2500mAh cell that gets old.
Yes, I know that, but I do generally not now which chargers gets updated.
I do usual not ask manufacturers or dealers for chargers, the contact me with the charger they want tested.
That is the first time I hear about more updates (I do not check around for new versions), but I do not have time to check it now. I have a couple of chargers and some manufactures has told be I can expect more very soon.
Thank you so much for indicating which chargers can also be used as power banks in this tabulated data! This is a feature I am currently researching and you are making my job much easier.
One small thing that I could suggest is that the provided links to each charger open in a new window versus inside the table space. This provides much more viewing room for the charger data and allows multiple chargers to be compared, each in their own window.
All of this work you are doing for us is incredible! Thank you!
If you have a wheel try clicking on it.
You can also right-click and select open in a new window.
