During traveling i donāt think you will have 4 powerbanks and 4 usb-cables with you for charging the lantern.
Also using chargers with different current would result in different voltage cells, which for sure isnāt good.
My idea was just about 1 powerbank as I wrote, as almost every 10Ah + nowadays can deliver more than 3A. You have more than one usb port in the single powerbank and also you can use Y cable to use just powerbank to its maximum rated power delivery. And the cells would all be charged as it would one input so always parallel charging. With lab PSUs it is not uncommon to parallel them to double to Current or put them In series (not this case obviously) to Double the voltage
With my phone I cannot post images but this was the idea
Ahh, I see. Ok, thanks David.
Not that I intended to use primaries, but the thought occurred for a second, (based on someoneās earlier post) that adapting a holder for primaries might be useful in a pinch or for the non-lithium-ion initiated. The idea of a carrier was short sighted however; using primaries would also introduce problems related to someone mistakenly trying to recharge them using the 4056 since it would see the voltage range for Li-Ion cells and, it seems, provide a charge current, yuck :confounded: :person_facepalming:
You have to consider not every traveller has a 10Ah+ (letās stick to capacitiy, so 40Wh+) powerbank. Means it has to be large enough to fit 4x 18650 cells and weight around 300g if itās made of plastic.
Most can deliver 1A, some have only one port wich can deliver up to 2A.
Even power plugs only deliver at best 2,5A.
Itās better to stay realistic.
following.
Been following this since a long long time
Any new updates on this?
Iām interested. Thanks!
Would it be possible to use a light pipe so that the LEDs would still be mounted in the base but the light would be emitted downwards like a traditional lantern?
Interested
Interested
@DBSAR
Unfortunately photobucket did change the policy. So from 1st of july 2017, no embedding of images on third-party websites, such as personal blogs and forums, is possible for free anymore.
They sell this function now for $399/year.
So is it possible to reupload the pictures to a fair image hoster?
Now the thread has raised to 12 pages, what speaks for your project. Iām very curious about the result too
Any news for the crowd?
Interested
Interested
Hope this project get going now that the Q8 are final. Love the charging discussion and to use it with a solarcharger.
Interested.
I am letting TheMiller have a break from it and when heās ready we can take on the BLF Lantern project.
Good to know thereās at least some kind of āplanā for this which is being executed, sorta. :+1:
Great, so the project is still alive
Interested
Iām interested.
I think the current lantern offerings out there are sorely lacking. With the thought and planning that has been demonstrated by this group for the Q8 and the BLF GT alone, i think a fantastic lantern could be made.
