As a recent receipient of a huge number of Rude votes, I definately would like to see the anonymous system done away with.
If something is truly Rudeā¦ the Giver of the vote should have no problem with the Giveee knowing they gave the vote.
Just because someone chooses to mark a post rude does not automatically make it Rude.
Nor does dressing up an obviously Rude post with smiley faces make it not Rude.
āTo meā, that is somewhat equal to Chocolate coating something the doggie dropped & serving it up as something wonderful. Yeahā¦ it might look good at first glanceā¦ā¦ till you get to the core of it that is. . And there are some on here that are masters of that technique.
IF there cannot be an anonymous system, I feel there should at very least there should be something simple that people could show agreement with a post.
And I see the word āvendettaā used in this thread. In fact it was used in obviously Rude ways aimed at the one who started this thread. Pretty amazingā¦not in a good way either.
To me, vendetta is when some anonymous person starts handing out Rude votes simply because someone does not agree with their opinion & it upsets their fragile little ego.
Thatā¦ā¦ā¦. is the real meaning of vendatta as far as I am concerned.
And at that point, might as well post about it as a ājokeā; because that is exactly what it has become.
And posting about the injustice is no more Off Topic than the truck loads of other Off Topic chatter.
Hi there teacher. Not to come down on you publicly, but again, by participating in an off-the-rails thread that is spawning an argument and getting tempers riled, rules were broken, and rude points happened.
Very true, well said.
When a lot of rude points start to rack up, there is often the false assumption that they are fraudulent hits. Seen from my end, itās usually another storyā in the case of a user that starts to go off the scale with rude hits, there are usually multiple users, many of whom have no dog in the fight, that mark the post(s) as rude.
I definitely will not be implementing a way for users to see who marked the post as rude. It doesnāt matter who marked it as rude, as long as it was a genuine response to something perceived as rudeness (as defined here), thereās basically no disputing it. Somebody was offended or concerned that rules were being broken, and it doesnāt matter who it was. What matters is what was said that offended the user. And thatās what you can see here:
As I said before, in the rare case that somebody tries to game the system to clobber a personal enemy with rude points, I can easily detect that and will take necessary corrective measures, including suspending the account.
Hey SB, can you give a list of most rude points given? Also without names.
That 48 current is a bit of a shock but made me think if there are, say 5 members giving 80% of all rudes or if it is a much smaller difference between the ātopā 5 or 10 then 48-6-and lower.
Hmmm, I could probably figure out a way to generate that data, but itās a bit harder to compile that. But Iām constantly checking my list of users that currently have non-expired rudeness points, and at any given moment itās usually quite a short list (if any), and usually populated by a few repeat offenders.
By knowing who marked you rude will only take the disagreement even further, and will also make people create new anonymous accounts just to mark rude. Not that it isnāt already happening now, but could get worse.
This is logical IMHO, this is on topic talking aboit getting rides in almost any other thread is of topic, generally not positive so bound to get a rude click.
Btw I like the idea of giving a reason when marking something as rude. It makes it a bit harder to do, and gives a good opportunity to Learn if one gets one.
Not a bad idea. It hadnāt occurred to me, so I havenāt given much thought yet to the implications of it. But I do know that on a technical level it would be much harder for me to implement with the available tools and frameworks I have for this forum.
Hi Sb. No problem, I donāt feel as though you have come down on me at all.
It is no secret I am the person with 48 Rude votes, down from 53 I might add.
When I PMād you about this you kindly responded with some directives. I replied that I would make a very conscious effort to comply with those directives. And I have.
Yes, I as well as others do not necessarily like the anonymous system, for reasons statedā¦ā¦ BUT, this is āyour houseā & you set the tone as well as rules.
That is good enough for me. :+1:
