One other problem, I tried to post a screen capture several times using Imgur. It shows in preview, but when I hit save it’s not showing in my edited post. I haven’t changed any setting in my router, firewall, etc. Please help.
It appears to be a problem with this thread. I was able to post an image in another thread without a problem. It was only a test and I deleted my post, but it worked.
I can see the results OK, but it did take 4 tries to post the first time this morning. And when I finally did my vote was deleted, so I revolted.
But best I remember this happens on all polls. It has something to do with Previewing the post before it is posted. If you Preview it something seems to get “thrown off” & things go hatwire. (sorry about the highly nontechnical terms…. but I am not a smart man. )
. EDIT: In fact it is happening now as I try to post this. :person_facepalming: … ??
THAT sounds likevaguely related to a problem we’ve had reported before. Previewing a post in a poll thread caused the user’s vote to disappear I think was that one. I know your issue is different. But, this “poll” thing seems to be causing bugs to occur in preview mode for some reason.
OK……… to post this EDIT 2: I just had to do it in a totally different post. I could not edit Post # 103 above again Once again, this is not particular to this Poll……. I have run into this on Polls before.
——————————————————————————— EDIT 2: So to post this I had to do it after my vote was cancelled and now I will go back and vote again.
This is not particular only to this Poll, I have run into this before on other Polls.
This is a test to see if I can just post with nothing screwy happening………….
EDIT: And it worked just fine as did this edit?
EDIT 2: …. So if this 2nd edit works, beats me??? I have no idea what is happening. Cause like I said…… “I am not a smart man.”
Oh yeah, vote was not cancelled on this post or the first Edit either. If you hear nothing else from me on this it will mean all held true for the 2nd Edit also.
I see your pic very plain Glenn. But now the Smiley button at the top is not working for me anyway.
Below is what I get in a pop up rectangle when I click on the Smiley Button…………
————- budgetlightforum.com says:
TypeError: Cannot set property ‘disabled’ of null
BUT, I was able to do post 106 above and edit it twice with no problems.
EDIT: Nope, just one picture is all I see. :+1:
BUT…… Smiley Button is working again. … :person_facepalming: …
