So you are now holding new world candela record when it comes to led flashlights.
So it throws around 2,2mcd without wavien collar?
Edit:
I can’t help myself thinking what numbers you would got with good XP-G2 here?
But since you only reflowed 2xOsram Black Flat maybe that means they are now more consistently build so maybe we don’t actually need to pick best of 5 or 10?
Excluding the big fresnel builds, yes.
You could argue that a big box with a giant fresnel lens in it isn’t really a flashlight, but a more clear definition is that this is the most powerful LED flashlight with a “less than 12” size optic”
Also the lux for those freslen builds was measured relatively close, like 5-15m iirc, so unless longer measurents are taken I’m not sure how reliable those are due to massive spherical and chromatic aberration.
It might be that they can produce that high lux at close range because of the diameter, but when measured farther away it decreases at a faster rate than 1/r^2.
Not sure though, because I don’t have a fresnel lens to test.
What I do know though is that when I get back from vacation I will try to save up money for better measurement equipment so I can confirm my lux numbers at even bigger distances (you saw in the other thread how measuring at 5m gave a completely incorrect value)
Currently on my shopping list is:
-second luxmeter from a different brand to double check values with
–150m laser meter (3x longer than I have right now)
–1300m laser rangefinder (less accurate than a laser meter but can do way longer distances)
I would guess between 2-2.2Mcd without the collar, yes.
What I would really like to see in this monster aspheric light builds is zooming function. For example 300-500 kcd of very wide flood mode(pure large hotspot that no reflector in a world can compete to) but because of wavien collar flood mode would be very limited right?
The way the single long focal length lens system is set up, it would need to move a very long distance and only widen the beam to like 10-20 degrees instead of 0.
A multi-lens system would need to be used, especially if there is a wavien collar which prevents the lens from getting more than 35mm close to the LED.
In order to get the best throw, I stick to single-optic systems for the least possible loss, and large spill doesn’t really interest me.
Also, with less than 500 lumens coming out of the front, there’s no way to get 500kcd and a wide spot at the same time
True, I just said ‘less than’, cause I have no idea
I just checked and it looks very similar in brightness to my 240lm P5r.2.
Makes sense, it’s probably close to 1000lm at the current I’m driving it, wavien collar leaves about half of that coming out at 60 degrees, and then about half of that actually hits the lens.
As you can see, lumen efficiency is not key here xD
I measured my fresnel box at 13 meter, with the spot focused at that distance. When used at 500 meter I had to re-focus quite a bit. But the shape of the hotspot and tint-gradient was the same for 13 meter and 500 meter, I do not expect a different kcd number for measuring at the two distances.
Enderman,
You forgot Lumensteins Lux Monster
In the beginning: 2Mcd with 3 XP-G2 at 5A (this value was always too low…)
Then modded again, 1.9Mcd with three XHP-35 HI
Also another light from Xandre: the SR-90-in-kurz-und-heftig (SR-90 in short and extreme). It’s a Vinz mod from 2013 and was the main inspiration for my Project Excalibur. It did 970kcd with a de-domed XP-G2 R5 (measured at 70m!). Pics can be found here.
Kenji modded some lights too
Nitecore TM-36 with XP-G2 S2: 842kcd
Eagletac MX25C2 Turbo wirh XP-G2 S2: 790kcd
Also the Lemax LX70
Normal Version: 1.3Mcd
LX-70 Superpower - 4.5Mcd (is has a much larger reflector)
Yeah, I just added the ones I remembered, a separate “record throwers” topic sounds awesome
I’ll do that in a few hours and update the graph with all of those.
Let me know of any others I should add!
I suggest to make the graph more interesting by putting on the x-axis the surface area of the largest optical element (lens or reflector) and the throw (kcd) on the y-axis.
That’s a great idea, I will make a second graph for that for sure
Thank you!
Kinda sucks that the one thing I made difficult to remove was the temp probe, and that’s the only thing having issues… lol
At least it sorta works, every time I want to see the temp I need to set the flashlight to low mode
I contacted them a while ago asking what kinds of conditions they would require for a “flashlight” but they never got back
The definition isn’t really clear, it just says a “small” portable battery powered light source, and there is no exact definition of small.
Guiness called this ginormous thing a “flashlight” so I guess for them there is no size restriction as long as it doesn’t need to be plugged into a wall and is “portable”.
So basically just buy a giant fresnel lens, stick some wheels on it, and you basically quality as a “flashlight” and win because you have the biggest diameter.
Someone else want the record? just increase the diameter.
That’s no fun IMO. I’m trying to get the best lux per diameter while staying portable, which for me personally is something I can fit in my backpack an carry around.
6” diameter and 500mm long is about max what I can fit while still closing it, or 12” diameter and 6” thick cylinder.
I have thought about it some more. Enderman’s graph is acutally kind of nice because it shows the performance (ie throw) differences between the lights without evaluating how optimezed they are. It shows that there is indeed still a very large difference between the Maxabeam and most LED lights. I know from personal experience that this is definitely the case.
These were taken with my not-so-great point and shoot camera with 100 iso and 4-5 second exposure. Look very similar to what could be seen irl, although with some highlights a bit overexposed like streetlamps and lamps and stuff.
Uploaded in high res in case you want to zoom in.
Some simple beamshots pointing into the sky.
Pointed at some dark trees about 500 or 1000m away, can clearly see the branches if you zoom in.
A close boat a few hundred meters awaay.
A far boat, about 500+ meters away.
These ones I think are the most impressive, the beam is actually visible from the side, and cuts through the sky even when there is a lot of ambient light around!
More than 50 people stopped to look at it while passing by, I just pretended to be another random person as I walked down the street taking my pictures like everyone else.
Very little side spill, anyone can easily look at the flashlight continuously without it hurting at all.
Temperature at the probe was below 40C after about half an hour of runtime, so the LED is likely at very safe temps far below 85C.
It is important that the fan is running because one other time the fan cable got caught in the blades and I realized after a while that the light was at 70+ degrees inside the PVC tube!
Thanks for reading.
