I know it’ll be some time before it gets into our hands. I should start looking for batteries so I’m set on those. Is there a preferred battery people are thinking of using? Should I wait for protos to go out and see what the proto testers think?
I doubt that it’ll draw huge amounts of current from each cell, so I’m fairly certain it won’t need to be anything special in the way of cells. You’ll want them to match of course. If I’m wrong someone please correct me.
You know to stay away from the Chinese cells that claim 15000mAH and sell for $2, right? They’re too good to be true for a reason.
edit: I doubt protected cells would hurt and probably be a very good idea, but do we know if there are length restrictions? I don’t.
I wouldn’t be at all surprised if there is a group buy on cells as there is/was for the Q8.
May I ask if anyone can confirm that this GT light require battery total of 8 cell or we can run only 4 cell but will not get the full 100% performance & Runtime.
Thank you.
I read on the front pake that it takes 8x18650s or rather 2x 4x18650s right? that is a tons of capacity for a modestly driven small XHP35? I think i’ll use BLF GT’s massive battery as a battery carrier for my other light
Yes four cells ought to work
In fact this proto is a shorty with only one carrier , we wonder if it ia because of easier prototype making and saving weight or why they did this.
Hmm TK, your 10m throw vs GT 2000+m. For portable light I stick with the GT. However do fly by for a nice BBQ
it’s a beautiful light and those beamshots are crazy. Never gunna deny that.
However, seeing that this is a deticated thrower, I can’t help but ask this question:
Considering the emitter is square and the reflector is round, is there some kind of engineeering magic that can be applied to the reflector to optimize the beam pattern for more throw?
I would imagine the light coming out of the corners of the LED are being reflected a few microdegrees away from the hotspot. Or is this an ignorable issue with such a drastic size difference between the size of LED vs size of reflector?
