Looks pretty good to me , thought the beam may hav been a little tighter , anyway i will compare to the Sniper M24 shortly out in the farm hills real use spotlighting
and yes i got some of the 30q`s for it
So Those of you that now hav yours What do you think , And those of you that like to Mod whats your thoughts ? can it be tweeked easily ?
Great looking light, but I’m curious about the regulation, Klarus lights have good thermal management but the temperature ceiling is set too low (not driven hard enough after first thermal drop)
my 30Q`s are the unprotected button tops , and the G35 seems twice as bright as the UT02 so i think the battery`s hav good contact
im ready to compare the G35 with the M24 sniper asap
Sniper is a tough act to follow least of all beat, I’ve got snipers and the 2x’s and the closest light I have with the needed reflector is my modded jaxman X1 with xhp35 but still falls just short of the maxtochs by maybe 200m
My g35 has a beam problem. It must be misadjusted led height or something. I used heat to get the bezel off and once I did that and loosened the bezel the beam tightened up nicely. But now I have a loose bezel. If I tighten it down the beam screws up again. It actually bends the bottom part of the reflector up. If I loosen it goes straight again. Not sure how to fix this. Anyone else have issues with the beam on your g35? I dont have a good enough camera to take any pictures sadly.
you could simply put a thick sheet of paper between the star and the plastic centering ring
simply use a puncher to get the 3 needed holes in it
if its not enough stack them
I think the spacer needs to go around the outer part of the bottom of the reflector. That way it won't bend the reflector upward when I tighten it. I'm not sure though. You can watch the reflector bend when I tighten it.or maybe I should remove a slight amount of material at the top of the reflector.maybe it is too long?
