Weāre just scratching the surface of short arc with our LED lights
The only way to get better is to keep building!
The BLF GT will hopefully be on this list soon
Well itās also #1 for LED flashlights that are available on the market
Guinness apparently didnāt take Raās Maxablaster submission because it wasnāt a retail flashlight.
If I ever build a light that makes the top 3, I will call it _blaster
Will update asap.
Unfortunately the Hyperblitz and the Zielscheinwerfer wonāt make it on my list since they are both tethered, not āportableā.
If people want to see those lights they can go to your document instead
Youāre right, I was looking at the wrong images that werenāt the hyperblitz.
Iām not sure if the Zielscheinwerfer counts as āportableā based on the guidelines I mentioned at the start, do you think it can be carried in one hand for many minutes with the ballast and batteries and everything?
Looks a bit too heavy to me, but idk.
I assumed that the moon blaster was battery powered and portable if it is only 120W, but without images it is hard to be sure.
I will have to look into it.
