8 AA slots, looks like this:
Illumn.com - Flashlights, Batteries, Carry Gear, Intelligent LED Lighting,...
Your trusted source for authentic batteries, flashlights, and more!
This Folomov one can do 8A max, same as MC3000.
I'm not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and compensate for that so, should be legit. I repeat, mereley looking at the spec...i could be worng, since i read the review long time ago
Pete7874:This Folomov one can do 8A max, same as MC3000.
I’m not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and compensate for that so, should be legit. I repeat, mereley looking at the spec…i could be worng, since i read the review long time ago
Yes, I’ve seen mfg specs that state it can do 3A per slot, but HKJ review only indicates 2A per slot. Not sure why the discrepancy.
I do have a 3A discharge curve:
!http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png!
There was a bug in my table with all chargers, it is fixed (There is probably more bugs in the table and I will fix them as fast as I know about them).
I am not going to fix the broken link.
Thanks, HKJ. There is this table in your review that only shows current values up to 2A, and not even for 18650 batteries, so I wasn’t sure…
That is the recommended charger current for different cell sizes.
Got it. Thanks for clarification. Looks like MC3000 is still the king.
It really is, the more time I spend with it the more I like it. The UI feels so easy to use now… (after a year)
to go beyond 3A i think you’ll need hobby charger + 18650 holder and MC3000 is already expensive, but i dont charge my 18650s beyond 3A anyway, tried on 4A but got rather hot (samsung 30Q got 41C)
Pete7874:Yes, I’ve seen mfg specs that state it can do 3A per slot, but HKJ review only indicates 2A per slot. Not sure why the discrepancy.
I do have a 3A discharge curve: !http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png!
Fixed link. ;-)
You may want to switch to the advanced post editor, HKJ. Getting used to it may take some time, but the rewards are substantial.
The email ad I got from illumn says:
A4 is a 4 slot smart charger with the capability of charging all 4 slots at 2A per slot. The outer two slots (slot 1 and slot 4) are capable of charging up to 3A when charging fewer than 4 batteries for your larger 26650 capacity batteries. Packed full of features such as LiFePO4 support, NiMh/NiCd charging capabilities, and 0V activation
Adding an official request to test the new Miboxer C4-12, if it’s not on your list already. Sounds like they may be sending you one soon…
Miboxer C4-12 3A/slot, total MAX 12A only takes 50 minutes to charge 4 pcs 3000mAh IMR battery to 85% With power bank function,Out Put 5V*1.0A We want you review this charger, If you are interested in Miboxer C4-12, sent me email: sales@miboxer.com As we are busy to get ready for ECC show(August 25rd-27th Ontario California, USA.) The samples will sent out after two or three weeks, And welcome you stop by our booth (A28) [image] [image] [image] [image] [image]
Hello HKJ, is in queue the Zanflare C4?
No, at least not anymore: Test/review of Zanflare C4
Trevi_lux:Hello HKJ, is in queue the Zanflare C4?
You are the best, thanks for your reviews!
Can LiitoKala Lii-402 charge Keeppower 26650 5200 mAh protected batteries, or not? There is only up to 18650 in it’s specifications. This is strange because Lii-202 can charge 26650. I also see some users are using it to charge other 26650 batteries.
On the photos it looks like it has two wide slots.
If you could review this please https://www.amazon.ca/gp/aw/d/B0746G57G6/ref=mp_s_a_1_2?ie=UTF8&qid=1504303443&sr=8-2&pi=AC_SX236_SY340_QL65&keywords=18650%2Bcell%2Bphone%2Bcharger&dpPl=1&dpID=51PFTtdOeLL&ref=plSrch&th=1&psc=1
Could you review this please? https://www.illumn.com/folomov-a1-magnetic-charger-with-output-feature.html
