TheBo
(TheBo)
July 27, 2017, 3:01pm
135
I'm not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and compensate for that so, should be legit. I repeat, mereley looking at the spec...i could be worng, since i read the review long time ago
Pete7874
(Pete7874)
July 27, 2017, 3:08pm
136
TheBo:
Iām not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and compensate for that so, should be legit. I repeat, mereley looking at the specā¦i could be worng, since i read the review long time ago
Yes, Iāve seen mfg specs that state it can do 3A per slot, but HKJ review only indicates 2A per slot. Not sure why the discrepancy.
HKJ
(HKJ)
July 27, 2017, 3:22pm
137
I do have a 3A discharge curve:
!http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png !
There was a bug in my table with all chargers, it is fixed (There is probably more bugs in the table and I will fix them as fast as I know about them).
I am not going to fix the broken link.
Pete7874
(Pete7874)
July 27, 2017, 3:37pm
138
Thanks, HKJ. There is this table in your review that only shows current values up to 2A, and not even for 18650 batteries, so I wasnāt sureā¦
HKJ
(HKJ)
July 27, 2017, 4:00pm
139
Pete7874:
That is the recommended charger current for different cell sizes.
Pete7874
(Pete7874)
July 27, 2017, 4:31pm
140
Got it. Thanks for clarification. Looks like MC3000 is still the king.
will34
(will34)
August 6, 2017, 9:14am
141
It really is, the more time I spend with it the more I like it. The UI feels so easy to use nowā¦ (after a year)
rizky_p
(rizky_p)
August 6, 2017, 4:26pm
142
to go beyond 3A i think youāll need hobby charger + 18650 holder and MC3000 is already expensive, but i dont charge my 18650s beyond 3A anyway, tried on 4A but got rather hot (samsung 30Q got 41C)
Barkuti
(Barkuti)
August 6, 2017, 4:46pm
143
HKJ:
I do have a 3A discharge curve: !http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png!
Fixed link. ;-)
You may want to switch to the advanced post editor , HKJ. Getting used to it may take some time, but the rewards are substantial.
hank
(hank)
August 10, 2017, 9:32pm
144
The email ad I got from illumn says:
A4 is a 4 slot smart charger with the capability of charging all 4 slots at 2A per slot. The outer two slots (slot 1 and slot 4) are capable of charging up to 3A when charging fewer than 4 batteries for your larger 26650 capacity batteries. Packed full of features such as LiFePO4 support, NiMh/NiCd charging capabilities, and 0V activation
Pete7874
(Pete7874)
August 12, 2017, 1:09am
145
Adding an official request to test the new Miboxer C4-12, if itās not on your list already. Sounds like they may be sending you one soonā¦
Miboxer C4-12
3A/slot, total MAX 12A
only takes 50 minutes to charge 4 pcs 3000mAh IMR battery to 85%
With power bank function,Out Put 5V*1.0A
We want you review this charger, If you are interested in Miboxer C4-12, sent me email: sales@miboxer.com
As we are busy to get ready for ECC show(August 25rd-27th Ontario California, USA.)
The samples will sent out after two or three weeks,
And welcome you stop by our booth (A28)
[image]
[image]
[image]
[image]
[image]
Trevi_lux
(Trevi_lux)
August 15, 2017, 9:09am
146
Hello HKJ, is in queue the Zanflare C4?
HKJ
(HKJ)
August 15, 2017, 3:17pm
147
No, at least not anymore: Test/review of Zanflare C4
Trevi_lux
(Trevi_lux)
August 15, 2017, 3:22pm
148
You are the best, thanks for your reviews!
RapidLux
(RapidLux)
August 18, 2017, 2:14pm
149
Can LiitoKala Lii-402 charge Keeppower 26650 5200 mAh protected batteries, or not? There is only up to 18650 in itās specifications. This is strange because Lii-202 can charge 26650. I also see some users are using it to charge other 26650 batteries.
HKJ
(HKJ)
August 18, 2017, 3:01pm
150
On the photos it looks like it has two wide slots.
specialk
(specialk)
September 1, 2017, 10:13pm
151
specialk
(specialk)
September 16, 2017, 11:51pm
152
HKJ
(HKJ)
September 17, 2017, 5:42am
153
Folomov has talked about sending me one, this makes it very likely I will review it.
Pete7874
(Pete7874)
September 17, 2017, 1:41pm
154
Have they sent you the A4 already?
