Nice, I have stainless and a crap load of wire. Shattered C1 back in 94’. 6 months in a halo. You’ll probably have a year to get back to normal. Good luck…
HKJ, I was wondering if you could help me to - theoretically - solve this doubt (originally placed here )
The new Vapcell 18500 M12 1200mah 10A Li Ion, wasn’t tested yet, but I would like to know, theoretically:
having the same capacity as an Aspire 18350 (between 1100-1200mAh), both cells being rated to +10A, the Vapcell to 4.44Wh and the Aspire to 4.07Wh, will there be any substantial difference when pushing these cells to their max?
Using a flashlight with FET driver, triple emitters, and so on…a pocket rocket! Will there be substantial differences?
I know it maybe tricky to answer without a test but any help is appreciated.
It is impossible to answer without tests. The higher energy rating on the Vapcell may mean it maintains a higher voltage, but that may only be valid at lower loads.
