I got 3 on the way! 2 bought, 1 as an offer! They may arrive next week, I hope!
When I get them I can make a “sort” of review. Not that technical, of course
But for the comments on their store, it seems to be a nice light!
A similar model is/was sold in Amazon, I guess, but this seems to be better and made by a “professional” company! The other lights on their store are quite nice too!
EDIT: I asked the seller if they take 14500 batteries, and the answer was “No”! However, a buyer mentioned he was using 14500 batteries without burning the driver! So…this may be a really nice deal, if one can use them with AA (alkaline, Ni-MH) and 14500 Li-Ion!
Looks good! Though I think I’ll prefer function over form and get a Zanflare F2, unless a review shows that comparatively speaking, it is a bad idea because this one is AMAZING
I don’t know for sure about the F2, but the F2S has a XP-G2 not XP-G3 as this light has. It is also a 2AA light, whereas this one uses single AA. And, this light is steel, compared to the anodized Aluminum F2S. The Zanflare F2S seems to me to be a very well-made light, but it isn’t directly comparable to this one in any way. What is it that you’re going for?
Well, in that case, the Zanflare is probably a better light for you. It takes 2xAA, so it will have better run time than this light. And it’s cheaper than this one by a couple USD. More-for-less! :money_mouth_face:
I was going to say something a couple days ago regarding the use of a 14500 cell, but I forgot. If you want a little more output without burning up the driver, you should try a LiFePO4 14500. Most of these boost drivers are actually rated for either 1S or 2S alkaline. So, the LiFePO4 max charge voltage of ~3.6V is close enough. Most of these boost drivers do happen to survive the 4.2V Li-Ion max charge as well, but that’s way outside the range and could cause problems.
Yep, getting to that conclusion Should’ve tried to compare it to the Thrunite T10 as well (more fitting, as it’s the exact same 1xAA platform), but all is good in the hood.
